Ended
887 posts / 0 new
praveendk
Last seen: 9 months 2 weeks ago
freeme wrote:
Glad hear that the new one is working.
Thanks again freeme
bikedave99
Last seen: 3 weeks 1 day ago
Thanks for the code Freeme, I just tried to use it and GB said the “coupon maximum limit has been reached” and wouldn’t let me proceed. Will there be another buy?
freeme
freeme's picture
Last seen: 25 min 6 sec ago
Temporarily out of stock.
Pugna
Pugna's picture
Last seen: 3 days 14 hours ago
I received my lamp today. It only took 7 days after I ordered one. I am very impressed with the lantern. It is a lot brighter than I thought. Also being able to change the tints is amazing. The magnet is as strong as on my more popular name brand lights. These would make a great Christmas gift.
If the deal does pop back up, I would be interested in purchasing 2-3 more. Thank you Freeme.
jmbow24
Last seen: 6 days 19 hours ago
Wow it took less than 10 days to get mine. So far i liked it
Paul321
Paul321's picture
Last seen: 1 day 3 hours ago
I have the same thoughts I bought two already and two more on the way.
Paul-
FBsLights
Last seen: 7 months 1 day ago
Ordered two. Coupon worked.
FB
flashiman
Last seen: 1 year 6 months ago
Looks a good deal. Thinking to buy one for testing purpose.
Jubjub
Last seen: 2 years 1 month ago
Interested, thanks.
vyvyra
Last seen: 1 month 1 week ago
Thank you. I got it in 6days
bikedave99
Are we still out of stock? Just noticed the thread title is “Active” now. Is there a new code?
TheShadowGuy
Could I get a new code?
JasonWW
JasonWW's picture
Last seen: 15 hours 53 min ago
I just recieved my two. They are working fine. Very nice design. They even have a blinking side light for when the battery level is below 30%. I have not heard that before, so I thought I’d mention it.
My only minor issue is the coating on the springs is not fixed. On one spring I see several ares where it’s peeling. The other spring has a couple of barely noticable spots. Maybe the next time I have my soldering iron out I’ll add a little bypass wire.
DB Custom
DB Custom's picture
Last seen: 2 days 14 hours ago
Got my T1 today as well. Figure I’ll give it to my son on his 11th birthday later in the month. The tint ramping is pretty dang cool, pick your poison as it were… Smile
Xikex
Last seen: 12 min 33 sec ago
Got my order today, neat little thing it is. Good thing I ordered 4. Big Smile
siata94
siata94's picture
Last seen: 2 weeks 13 hours ago
rec’ed my 2, all I can say is WOW. Not that I’d want my kids to lose more lanterns but I’ve been supplying them
with the 3xAA lanterns; they’re not worth the 3xAA Eneloops I put in them. And the Blitzwolfs, yea they’d be good night lights Smile
freeme
freeme's picture
Hope he likes it.
DB Custom wrote:
Got my T1 today as well. Figure I'll give it to my son on his 11th birthday later in the month. The tint ramping is pretty dang cool, pick your poison as it were... :)
AlexGT
AlexGT's picture
Last seen: 6 days 14 hours ago
I just got mine as well, Used it a little bit and now I have it charging. With the risk of sounding dumb Facepalm I have a question, to turn off the light can you do it from the top metal switch or do you have to do it from the bottom (next to the tailcap) switch? I tried to turn it off from the top switch but it just kept changing color or brightness, maybe I just haven’t got the hang of it yet.
So, can someone tell me How do you turn it off using only the top switch? Grad
Thanks!
hIKARInoob
hIKARInoob's picture
Unfortunately, it can only be switched off using the bottom button…
JasonWW
JasonWW's picture
Thanks!
If you press and hold the bottom button to turn it off, it should memorize your previous color and brightness level.
Cereal_killer
Cereal_killer's picture
Last seen: 8 months 4 weeks ago
I received my light yesterday and it seems to have some issues…
First is I can’t turn it off without totally removing the battery compartment cap (boy not having anodized threads for a lockout is annoying) but the bottom button doesn’t do anything. Seems like there’s a bad connection at the driver / button or a broken wire inbetween.
I was thinking I could spray paint the threads to try to make it so I could just crack the tail to shut it off. I like the light and definitely want to be able to use it… Does that sound like it’ll fix it make it usable?
Second (and it may be related) is that I can’t ramp brightness in the tint mixing mode. Have I just not figured out the UI yet or does ramping brightness in tint mode require that bottom button again (which wouldn’t be fixed by my proposed solution for shutting it off above)?
I really don’t want to try to open up a glued together plastic bodied light…
Aleister
Aleister's picture
The bottom button is used only for red modes and off, everything else is done by the top touch-button
Let a flooder be my wife and a thrower be my mistress
Aleister
Aleister's picture
I would open a ticket and ask for a replacement, never had a problem with GB when I received a DOA, they always refunded me
Pugna
Pugna's picture
Coupon is no longer working. “This coupon has reached its maximum limit.”
sandanbob
I found that out!
lionheart_2281
lionheart_2281's picture
Last seen: 12 hours 7 min ago
Such a shame you can’t turn it off from the top button
JasonWW
JasonWW's picture
Yeah, the whole UI is pretty wonky. I’d much rather have an extra color temp button on the bottom. Then the top can be brightness and off.
Then they need to anodize the battery cap threads so it can be transported while easily locked out.
finnegans
Interested in a couple!
sandanbob
Now it says “discontinue.”
apt323
apt323's picture
interested could I get a code.
thank you
