Thanks for the code Freeme, I just tried to use it and GB said the “coupon maximum limit has been reached” and wouldn’t let me proceed. Will there be another buy?
I received my lamp today. It only took 7 days after I ordered one. I am very impressed with the lantern. It is a lot brighter than I thought. Also being able to change the tints is amazing. The magnet is as strong as on my more popular name brand lights. These would make a great Christmas gift.
If the deal does pop back up, I would be interested in purchasing 2-3 more. Thank you Freeme.
I have the same thoughts I bought two already and two more on the way.
I just recieved my two. They are working fine. Very nice design. They even have a blinking side light for when the battery level is below 30%. I have not heard that before, so I thought I’d mention it.
My only minor issue is the coating on the springs is not fixed. On one spring I see several ares where it’s peeling. The other spring has a couple of barely noticable spots. Maybe the next time I have my soldering iron out I’ll add a little bypass wire.
Texas Ace Lumen Tube calibrated with Maukka lights
Got my T1 today as well. Figure I’ll give it to my son on his 11th birthday later in the month. The tint ramping is pretty dang cool, pick your poison as it were…
rec’ed my 2, all I can say is WOW. Not that I’d want my kids to lose more lanterns but I’ve been supplying them
with the 3xAA lanterns; they’re not worth the 3xAA Eneloops I put in them. And the Blitzwolfs, yea they’d be good night lights
Got my T1 today as well. Figure I'll give it to my son on his 11th birthday later in the month. The tint ramping is pretty dang cool, pick your poison as it were... :)
I just got mine as well, Used it a little bit and now I have it charging. With the risk of sounding dumb I have a question, to turn off the light can you do it from the top metal switch or do you have to do it from the bottom (next to the tailcap) switch? I tried to turn it off from the top switch but it just kept changing color or brightness, maybe I just haven’t got the hang of it yet.
So, can someone tell me How do you turn it off using only the top switch?
Thanks!
If you press and hold the bottom button to turn it off, it should memorize your previous color and brightness level.
I received my light yesterday and it seems to have some issues…
First is I can’t turn it off without totally removing the battery compartment cap (boy not having anodized threads for a lockout is annoying) but the bottom button doesn’t do anything. Seems like there’s a bad connection at the driver / button or a broken wire inbetween.
I was thinking I could spray paint the threads to try to make it so I could just crack the tail to shut it off. I like the light and definitely want to be able to use it… Does that sound like it’ll fix it make it usable?
Second (and it may be related) is that I can’t ramp brightness in the tint mixing mode. Have I just not figured out the UI yet or does ramping brightness in tint mode require that bottom button again (which wouldn’t be fixed by my proposed solution for shutting it off above)?
I really don’t want to try to open up a glued together plastic bodied light…
RIP SPC Joey Riley, KIA 11/24/14. Now I am become death, the destroyer of worlds.
The bottom button is used only for red modes and off, everything else is done by the top touch-button
Let a flooder be my wife and a thrower be my mistress
I would open a ticket and ask for a replacement, never had a problem with GB when I received a DOA, they always refunded me
Thanks again freeme
Temporarily out of stock.
Wow it took less than 10 days to get mine. So far i liked it
Paul-
Ordered two. Coupon worked.
FB
Looks a good deal. Thinking to buy one for testing purpose.
Interested, thanks.
Thank you. I got it in 6days
Are we still out of stock? Just noticed the thread title is “Active” now. Is there a new code?
Could I get a new code?
Click this to go to signature links.
Got my order today, neat little thing it is. Good thing I ordered 4.
Hope he likes it. ♥
Thanks!
Unfortunately, it can only be switched off using the bottom button…
fix itmake it usable?Second (and it may be related) is that I can’t ramp brightness in the tint mixing mode. Have I just not figured out the UI yet or does ramping brightness in tint mode require that bottom button again (which wouldn’t be fixed by my proposed solution for shutting it off above)?
Coupon is no longer working. “This coupon has reached its maximum limit.”
I found that out!
Such a shame you can’t turn it off from the top button
Yeah, the whole UI is pretty wonky. I’d much rather have an extra color temp button on the bottom. Then the top can be brightness and off.
Then they need to anodize the battery cap threads so it can be transported while easily locked out.
Interested in a couple!
Now it says “discontinue.”
interested could I get a code.
thank you
