Been think'n bout it more - might have seen this... pm sent to Fireflies and TK. I guess the Q8 is the largest deployment of NarsilM and don't think I've heard of it happening with the Q8, though that was an earlier version. Dunno if I only saw it while in development/debug or what...
Near 4 full hours of fully regulated 750 lumens of 9080 goodness! Very nice! The max output drops very fast, but I wonder how long it to drop if it starts at 1500 lumens?
4 hours at 700 lumens of 219B 9080 makes this an extremely practical light. When did you guys order? Howcome you got it so fast? I ordered mine on the first or second day it was announced but tracking status says “2018-08-10 06:02 - Origin Post is Preparing Shipment, We have received notice that the originating post is preparing to dispatch this mail piece”
Also Fireflies does not respond to my multiple emails. How did you guys get a hold of him?
I suppose those percentages are estimations, and may probably vary due to different LED/number of 7135 used in the bank/etc.
You may refer to the NarsilM source code, more specifically the mode-set definitions for 3 channels (OUT_CHANNELS == 3 in file ModeSets.h). The default mode-set (4) is defined as:
I’m curious how long it takes to heat up if you disable the thermal stepdown. I don’t really like the behaviour with the Q8 because it never steps back up, so I just have it disabled and can generally get pretty decent usage out of turbo before it gets too hot to hold (i.e. high 50s C). Certainly more than 24 seconds.
Good! This is taken from the last version used in ROT66, right? The mode configurations appear slightly adjusted. Will this modified NarsilM become available for download?
Mostly I just want to make sure people understand and follow the license, which requires publishing the code used in the product. I wouldn’t complain about a free light, and if I had one I’d probably port other code to run on it, but my main concern is that everything stays open.
ROT66 heated up really quickly. If you don’t like the default thermal step-down, you may set it to a higher value, or pick one of those NarsilM pre-defined step-down timers (60secs, 90secs, 2 mins, 3 mins, 5 mins, 7 mins). But do not disable it completely. I once tried to disable the step-down and cooled the light with two fans. However the surface temperature still went up and up, to 108°C, when Turbo was on. That’s dangerous…
The size comparison is really useful. Definitely a bit more pocketable than the Q8, though I can see why it heats up faster on turbo. I’m always surprised by how chunky the M43 is.
Thanks Charles Lin! You post some of the best comparisons I’ve seen! I’m surprised the MF01 looks so much brighter than the Fireflies XPL-HI version. The MF01 219C makes about 7k real lumens. Whereas the XP-L hi ROT66 is supposed to make 10k lumens. Do you have a TA lumen sphere to compare the two?
