Yes, I see the chart. So would that be 13 Minutes? Not quite 16 minutes.
Looks like 16:36 it dives and does not make it back to turbo.
One question. That is NOT totally dependant on the battery is it?
If a different driver was put in could the PLB-55A possibly sustain more turbo? I would think there would be enough voltage after 13 minutes to do this.
Just my guess as the guy who modded it is working on another driver.
Just received mine from joker145 in pristine condition. Thank you joker. With the stock battery the throw lives up to spec according to my meter (calibrated to known lights). The switch feels good and solid.
It does get a bit uncomfortable before the turbo/temp control kicks in but not so hot that you want to drop it. All in all a nice handheld shooter with great neutral white beam. It will be used primarily onboard the ship I currently work on by others so the usb charging makes it mostly idiot proof.
Kudos to Thrunite for making a nice compact 26650 thrower.
It might fit. It is ~2.8mm More than the 5750mAh Orbtronic cell that I am using. I would certainly go with that one. It has more capacity/More amps/Definitely fits and a few $’s cheaper.
The 5750mAh cell is 5mm from the top of the tube [see pic. below]
That would tell you that the protected Orbtronic 26650 [68.8mm] should fit but you have to take the compressed Negative “Tail cap” spring into account.
Here is the supplied Thrunite battery. If Orbtronics measurement for the protected battery is correct, then it should indeed fit with some room to spare as you can see in the photo of the Thrunite battery which is basically the same size and obviously works in the light.
Swib gets credit for pointing out the supplied Thrunite battery.
I did measure the Thrunite battery [with a ruler!] and even though I was not using a micrometer, it indeed seems like it is ~68.9 mm.
I would still go w/ the Orbtronic 5750 20A[PLB-55A].
I agree about the Orbtronic 5750 20 PLB-55A. From toobadorz’s graph it seems to be a better choice. However it appears to be a non protected cell. Not sure if that is really important to you.
Yes,that would be a personal choice for him. When I started this hobby 90% or more of my cells were Protected. Now it is the opposite.
Unprotected cells, especially IMR and similar ones, are unprotected for a reason. they are safer and do not need protection. As long as we have common sense, do not drain them too far, have a DMM and know our run times w/ each torch, then the Unprotected high drains are certainly a better choice. I have not had one safety issue with them.
Nor have I had any issues with unprotected cells. In the lights that I make for others I just make sure to use a driver with LVP so they can’t over discharge the battery. I’m just about to push the button on flat top Orbtronics. Is that what you are using?
I do not seem to be able to get a video on here from my Google account. All my pics and videos from my phone go to Google photos.Then I copy/paste on here and I am the Only one able to view it.
