I have one as well, really love it , and it’s very compact for the power…Does anyone know if a protected Orbtronic 26650 will fit ??
The supplied Thrunite battery is 68.78 mm long if that helps. The Orbtronic site says 68.8 so I don’t see why not.
It might fit. It is ~2.8mm More than the 5750mAh Orbtronic cell that I am using. I would certainly go with that one. It has more capacity/More amps/Definitely fits and a few $’s cheaper.
The 5750mAh cell is 5mm from the top of the tube [see pic. below]
That would tell you that the protected Orbtronic 26650 [68.8mm] should fit but you have to take the compressed Negative “Tail cap” spring into account.
Swib and Wolfdog… thank you both !
Here is the supplied Thrunite battery. If Orbtronics measurement for the protected battery is correct, then it should indeed fit with some room to spare as you can see in the photo of the Thrunite battery which is basically the same size and obviously works in the light.
Swib gets credit for pointing out the supplied Thrunite battery.
I did measure the Thrunite battery [with a ruler!] and even though I was not using a micrometer, it indeed seems like it is ~68.9 mm.
I would still go w/ the Orbtronic 5750 20A[PLB-55A].
I agree about the Orbtronic 5750 20 PLB-55A. From toobadorz’s graph it seems to be a better choice. However it appears to be a non protected cell. Not sure if that is really important to you.
Yes,that would be a personal choice for him. When I started this hobby 90% or more of my cells were Protected. Now it is the opposite.
Unprotected cells, especially IMR and similar ones, are unprotected for a reason. they are safer and do not need protection. As long as we have common sense, do not drain them too far, have a DMM and know our run times w/ each torch, then the Unprotected high drains are certainly a better choice. I have not had one safety issue with them.
Nor have I had any issues with unprotected cells. In the lights that I make for others I just make sure to use a driver with LVP so they can’t over discharge the battery. I’m just about to push the button on flat top Orbtronics. Is that what you are using?
Yes.Will they ship to Canada at a reasonable price or are you getting them elsewhere? Shockli 5500 is also the same cell and so is the KP 6000mAh.
Thank you wolfdog1226. I will have them sent to my US shipping point. Less hassle, cheaper, and I’ll get them quicker.
Here is a beam shot of the Catvn V6 1988L/194Kcd
I cannot see it.
EDIT: I get a 404 error.
asks me to sign in to my Google account then shows an error
Ok,Thanks.
I do not seem to be able to get a video on here from my Google account. All my pics and videos from my phone go to Google photos.Then I copy/paste on here and I am the Only one able to view it.
Next time, upload to YouTube…
Thanks NL. I knew I needed to do that but kept trying w/ google photos!
I hope this works,CATvn V6 NW 5000K 1988L/194Kcd w/ average video on my camera!
Thanks for the video… why do you have to double click again at 1:05 ? Was there a stepdown?
I want to make sure it was on turbo. It steps down at first ~ 2 minutes,then about every 75 seconds after that. That is with the Orbtronic 5750 battery,same as shockli 5500 cell.[PLB 55A]
Thanks for the testing,that is almost the exact numbers on mine,turn on and 30 seconds. But V54 used the Thrunite battery for my specs. Shockli/Orb. probably a bit higher.
New V6 video w. special guest coming up. Probably tomorrow because it still is not on my Google photos yet.only on my phone.
Time to go to bed here in the suburbs of Philly,SUPER BOWL CHAMPS! Time will tell,they may do it again! :sunglasses:
