Fireflies ROT66 Flashlight
974 posts / 0 new
maukka
maukka's picture
Last seen: 1 hour 19 min ago
Just like in the code shared previously, you can visually see that the low levels PWM between zero and 1×7135 at 16 kHz. 100% 1×7135 is of course without PWM. Mid modes above the single 7135 are PWM’d between that and the 6×7135 channel at 16 kHz. (1+6)×7135 is again without PWM. Then it PWMs at 32 kHz between the 1+6 and FET and finally transitions to full FET.
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 6 min ago
On a side note, at some point I’d like to reduce that 32 kHz to 16 kHz, but the attiny85’s second PWM counter works differently than the first. I’m not entirely sure it can run at the same speed.
(pins 5 and 6 share PWM counter 1, pin 2 or 3 uses PWM counter 2)
toobadorz
toobadorz's picture
Last seen: 1 day 19 hours ago
It looks like the Mid modes are PWM’d between 1×7135 and (1+6)×7135 (i.e., the 1×7135 channel is always 100%), aren’t they?
maukka
maukka's picture
Oh yeah, exactly like that.
ToyKeeper
ToyKeeper's picture
Yes, the 1×7135 power channel stays on, steady, when the Nx7135 channel is active. And both stay on, steady, when the FET is active… Except for the very last ramp step, where it’s FET-only.
Nearly all multichannel lights since the BLF-A6 have done things this way, because nobody has found a better solution yet without major hardware changes.
Lexel
Lexel's picture
Last seen: 5 days 3 hours ago
it would be possible in the ramping table when the FET gets active after like 25% FET slowly decrease the AMC output level, but in fact of having them on reduces PWM on the light output and different PWM frequencies dont interfere with each other
Tom E
Tom E's picture
Last seen: 4 hours 19 min ago
Just fyi here, I recently, like last week, tweaked NarsilM to run FET+1 on a triple channel driver. I did this in order to use a TA 30 mm triple driver, sanded down to 28 mm, in a Maeerxu M8 without using up my very limited supply of the "good" 7135's.
So in theory if this flashlight uses the regular design "TA" design for the triple channels, it can also run as a FET+1, Q8 style, just not taking advantage of the bank of 7135's. Wish I could find a source to buy the good 7135s at reasonable pricing.
Lexel
Lexel's picture
Tom E wrote:
Just fyi here, I recently, like last week, tweaked NarsilM to run FET+1 on a triple channel driver. I did this in order to use a TA 30 mm triple driver, sanded down to 28 mm, in a Maeerxu M8 without using up my very limited supply of the “good” 7135’s.
So in theory if this flashlight uses the regular design “TA” design for the triple channels, it can also run as a FET+1, Q8 style, just not taking advantage of the bank of 7135’s. Wish I could find a source to buy the good 7135s at reasonable pricing.
Those here seem to be good
https://de.aliexpress.com/item/20PCS-LOT-AMC7135PKFT-AMC7135-7315-SOT89-new-and-original/32802106042.html
Tom E
Tom E's picture
That's the German Ali, to US, shipping more than doubles the price. For the global site at the same named store, it's a different deal qty 10 for $1.51 no tracking, or if I order 100 (10 of qty 10), it's about $20, 0.20 each with tracking. Think I'll order the 100 deal w/tracking.
Hope I get what they pictured though - the "raptor claw" versions? Last batch I ordered from somewhere sent me the bad versions. Ali had been real good though with refunds when you don't get what you expected.
Thanx!!
steel_1024
steel_1024's picture
Last seen: 2 weeks 16 hours ago
I wish do that for you.
How much?
I will inquire first.
Edit: 100=$5.41
Sorry for my poor english.
Tom E
Tom E's picture
steel_1024 wrote:
I wish do that for you. How much? I will inquire first. Edit: 100=$5.41
I just paid bout $20 for 100 shipped w/tracking. Might be able to find them cheaper. Old pricing for us used to be 50 cents (Illumn, IOS, etc.), than FastTech became the defacto standard supplier here: fasttech-qty100-amc7135-350ma, for like 8 cents each at this qty, but no longer could guarantee what version they would send you. I'm hoping this Ali store will at least ship out what they show in the picture.
Tom E
Tom E's picture
JasonWW wrote:
maukka wrote:
What I don't particularly like is that changing the batteries resets the light back to ramping mode.
It definitely should not do that. All settings (modes, thermal, etc...) should be stored permanently unless you go into the menu and change them. This will need investigating.
I found one potential bug in this are. This is a triple channel driver, so in this state, it's possible to choose mode sets 9 to 12, except they don't exist for a triple channel configuration. What happens as a result is uncertain - it accesses invalid locations in memory, so who knows what bad data references will result in.
Is it possible you tried selecting a mode set above 8?
maukka
maukka's picture
No, I’ve only used the default mode set (4) with four modes + moon.
Tom E
Tom E's picture
maukka wrote:
No, I've only used the default mode set (4) with four modes + moon.
Ok, back to the drawing board... cry
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 hour 29 min ago
charles lin wrote:
SKV89 wrote:
Thanks Charles Lin! You post some of the best comparisons I’ve seen! I’m surprised the MF01 looks so much brighter than the Fireflies XPL-HI version. The MF01 219C makes about 7k real lumens. Whereas the XP-L hi ROT66 is supposed to make 10k lumens. Do you have a TA lumen sphere to compare the two?
My MF01 is running Lexel FET driver with NarsilM v1.2, it should output around 9000~10000 lm. The best output munber I can get from ROT66 XP-L hi is 7480lm 0 second & 6650lm30 seconds with VTC5A.
Actually, I’m a bit worried about the extreme difference between advertised and measured lumen output of the XP-L HI NW. If I recall correctly the ANSI method states lumen output at/after 30s of runtime. So, we have 6.650lm vs. 10.000lm (for the cw V3 1A), i.e. this flashlight only achieves 66.5% of its advertised specs, is that correct? Okay, one could say the nw version might have A BIT lower output – even though it’s the same V3 binning – but 33,5% less seems far too much to me. I’m not even using those expensive VTC5A with low internal resistance but the usual VTC6. Thus I might experience even less lumens than charles lin did with his light.
I’m also wondering how much regulated output would remain with 14 AMCs on the board.
Tom E
Tom E's picture
Fireflies test of the 219B version in a 1.5 meter integrating sphere reports a peak reading of 5236 lumens running on 3 VTC6 cells.
So what is the equivalent peak lumens reading Maukka got? I can't find it in the posted result in post #135.
I think first we need to see apples to apples. Then take a look at what that reading really means - Fireflies posted integrating sphere report is probably instantaneous, not at 30 seconds.
Of course it would be great if Fireflies and Maukka used the identical light, identical cells at the same charge level, but I suppose that's not happening? If not, we should expect a possible swing of 5-10% but I think it should be closer than that. Even if you have 7% LED variance, the chances of all 9 LED's varying the same way is pretty remote.
 These integrating sphere are all terrific, but they require meticulous usage, regular calibration, and understanding and proper reporting of the results.
Looking at the XPL-HI V3 CW report, it's 9660 lumens at the peak. So I guess Fireflies rounded up to 10000 lumens, but still it's a peak, not after 30 seconds. So Charles lin reported in post #197 he measured 7480 lumens at the peak on VTC5A cells. That's still a big difference of 22.6%, so the questions are is someone's measurements tools way off or are the 2 lights compared different in some way?
toobadorz
toobadorz's picture
So what is the equivalent peak lumens reading Maukka got? I can’t find it in the posted result in post #135.
I think first we need to see apples to apples. Then take a look at what that reading really means – Fireflies posted integrating sphere report is probably instantaneous, not at 30 seconds.
Of course it would be great if Fireflies and Maukka used the identical light, identical cells at the same charge level, but I suppose that’s not happening? If not, we should expect a possible swing of 5-10% but I think it should be closer than that. Even if you have 7% LED variance, the chances of all 9 LED’s varying the same way is pretty remote.
And the step-down setting should also be taken into consideration. My ROT66 will step-down before 30s when the default is used. And, with three VTC6s, when step-down is completely disabled, I got ~5050 lumen at 0s and ~4500 lumens at 30s. My DIY sphere is not supposed to be accurate but the relative difference between 0s and 30s was ~10% then.
maukka
maukka's picture
Still testing, but I get 4325 lm at turn on, 3860 lm at 30 sec with 3×30Q. Complete review coming in a couple of days.
I changed the temp limit. Mine was stepping down a bit too prematurely with factory settings. Now it steps down at about 60 sec. Should back up a bit since it’s getting up to 65°C right now.
toobadorz
toobadorz's picture
Wow, that’s lower than my expectation. Since the Turbo is driven by pure FET and thus can vary greatly due to numerous reason, maybe we should take the max regulated brightness (7×7135) as a base. On my ROT66, the peak output is 5050 / 715 = ~700% if compared with the stabilized 7×7135 brightness. Or 5050 / 740 = ~680% if compared with 7×7135 at 0s.
Tom E
Tom E's picture
30Q's should get lower results than VTC6's, but not that much lower based on my Q8 tests - this is 17.4% lower than Fireflies integrating sphere results. So something is off, or the lights tested are different, or little of both.
maukka
maukka's picture
On 7×7135 mine is 710 at 0 sec. So peak is 609% (6.09*710=~4325).
toobadorz
toobadorz's picture
maukka wrote:
On 7×7135 mine is 710 at 0 sec. So peak is 709% (6.09*710=~4325).
I suppose you mean 609%, right? My 7×7135 was close to 730 740 at 0s, and it stabilized at 715 after an hour. My numbers are probably on the higher side, however the peak to 7×7135 ratio seems not as high as expected on your sample Shocked
maukka
maukka's picture
Of course, typo.
maukka
maukka's picture
After several tests with cooling the light in between the most I got at 0 sec was 4413 lm. The 4325 lm is an average out of three. Using VTC5A didn’t make any real difference, 4440 lm on average with a max of 4500.
twisted raven
Last seen: 15 hours 31 min ago
What is the actual lumen number you got on the max regulated with your integrating sphere?
toobadorz
toobadorz's picture
So that’s ~630% of 7×7135 at 0s. With 3 x NCR18650GA cells, I got ~4650 at 0s, which is ~630% of 7×7135 at 0s. With VTC6’s, that ratio is ~680% (5050 / 740).
maukka
maukka's picture
Some white wall beamshots from TIR lights.
The_Flashaholic
The_Flashaholic's picture
Last seen: 21 hours 43 min ago
The ROT66 will be great for night photography in a US ghost town.
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - http://www.youtube.com/c/FLASHAHOLIC_TV
twisted raven
Wonder what a minus pink filter would do for it in terms of subjective and objective differences? Of if the AR coated lens has a tint that’s green/magenta that also slightly affects tint?
charles lin
charles lin's picture
Last seen: 2 days 6 hours ago
My calibrated TA tube measurement for Nichia 219b version is
4740lm 0 sec, 4300lm 30 sec. with VTC6 @ 4.2V
Similar test result with either VTC5A or GA.
I took time redo calibration for my TA tube. Now, my 219B ROT66 with 30Q’s measures 4440 lumen at 0 second, 3910 lumen at 30 seconds.
