also I belive 90% of the narsil users will find more information than needed and for playing with the new light once to set it up its ma be a good way to visualize how it works.
any better way to help muggles to use the potential of narsil is highly appreciated :)
I have just received my 2 GTminis but there is something wrong with one of them. It has no turbo mode! After a double click the output power is the same as in high, only the color temperature gets a little cooler. Also the defective one has worse centered LED in the reflector.
Both lights were ordered NW and they are the same color temperature all the way through ramping, both powered with freshly charged sanyo 18650GA
If the ramp ceiling and a double click Turbo appear to be the same output, the cell choice could be the culprit. Some cells, especially protected cells, can’t deliver the higher Turbo amperage requirement.
I guess the $2 extra shipping I paid was for an extra trip around the parking lot at the Guangzhou航站 Guangdong shipping center—it seems it has been there since the 1st but finally has been accepted—-
Just received my mini GT. At first I kept measuring about 500 lumens with every battery I had and freaked out. Then I wiped down the springs with alcohol and got 1,140 turn on lumens using the TA lumen sphere. In comparison, my D1S measures 862 turn on lumens. I don’t know why it measured so low even after I wiped the springs with alcohol. The hotspot on the D1S is smaller than the Mini GT though. The Mini GT NW tint is actually as warm and rosier than the 5D D1S so it is definitely a 5D tint. Looks great.
