I guess the $2 extra shipping I paid was for an extra trip around the parking lot at the Guangzhou航站 Guangdong shipping center—it seems it has been there since the 1st but finally has been accepted—-
Just received my mini GT. At first I kept measuring about 500 lumens with every battery I had and freaked out. Then I wiped down the springs with alcohol and got 1,140 turn on lumens using the TA lumen sphere. In comparison, my D1S measures 862 turn on lumens. I don’t know why it measured so low even after I wiped the springs with alcohol. The hotspot on the D1S is smaller than the Mini GT though. The Mini GT NW tint is actually as warm and rosier than the 5D D1S so it is definitely a 5D tint. Looks great.
Thank you Neal for quick dispatch, my NW just arrived in Melbourne, Australia. No trips around the car park for this one. It’s beaten some Bang good orders placed the week before I ordered the GT mini.
Tested with 3500mAh protected battery, nice little hotspot in well lit office, included 30Q is charging for after dark.
Javisst! Will have to charge up my old Canon G3 and take some snaps. Was lighting up some eucalyptus trees earlier this evening, comparing GT mini NW to ThorFire C8s which is quite cool. The NW brings out the browns and greens very nicely. Also received 4x VTC6 for Q8 to replace Imalent MRB-186P30. 750lux to 970lux with my Samsung phone ceiling bounce test
GT mini has joined ThorFire family with bastard step child cheapy UltraFire knockoff in the background
Quick question: I’m trying to set the moonlight mode to “1”. When I click to set “1” as the desired moonlight level, the light starts up brighter than the “default 3” level. When I click to set moonlight to “2,” it is noticeably dimmer than “3”. Am I doing something wrong?
Thanks for the help and putting this buy together!
Are you in ramping mode? Are you pressing and holding from off to get to moonlight? You have to release the button as soon as the light turns on otherwise it starts ramping up. It just stays at moonlight for maybe 0.5 second.
The bottom of the ramp seems to be about moonlight 4 brightness level.
I checked moonlight levels 1-4 and all seemed to work as they should. Moonlight 1 just barely had the led glowing. I had to turn off the room light just to see if it was on or not.
I’m wondering whether I can use a Convoy C8 lens as a replacement for the lens in my GT mini. I don’t have a Convoy C8 lens at the moment but I am planning to buy one since I couldn’t find a replacement lens for the GT mini in Banggood.
I received my GT Mini today. I didn’t receive my GT Mini holster and my GT Mini didn’t work. I tried with all the 18650 still nothing. One very dim light came on for 1 second when I pushed the button then nothing after that. The rubber button has a green light when I click on it, it flashes then stop then flash couple time but still no light. I tried following the user manual still nothing. I emailed Martin. What do I do now?
