Spring bypass question
39 posts / 0 new
vt2nv
Last seen: 1 year 4 months ago
Admittedly, I’ve only been here a short while and I have a lot to learn, but something is gnawing at me..
You folks are bridging negative-side springs with heavy wire, and that seems silly to me. What’s gauge wire is a spring turned from? Maybe 22AWG or so. Next: pull the spring and measure it’s length. How long is the spring wire? Two or three inches maybe? Consider this- 1000 feet of #22 AWG has a resistance of 16.14 ohms (copper conductor. Alloys will have more resistance, but not enough more to make a difference). So how much resistance would 3 inches or so of #22 AWG coated copper or alloy wire have? Not very much. Measuring voltage drop across the spring would probably require a 6 1/2 digit DMM.
I’ve seen springs bypassed with really thick wire which seems silly. That coiled wire (the spring) is somehow detrimental doesn’t seem to fly either, as there is only DC across the spring. No AC component to supply voltage means that even if the spring capacitive or inductive properties it means nothing whatsoever.
Someone please explain to me the performance benefits I’ll see by bypassing the springs in my high-current lights.
Cheers
MRsDNF
MRsDNF's picture
Last seen: 8 hours 27 min ago
There is some interesting reading and testing here from djozz which may help to answer your question.
http://budgetlightforum.com/node/35228
Lightbringer
Lightbringer's picture
Last seen: 8 hours 19 min ago
I was an Unbeliever, too (well, just a bit skeptical), ‘til it was pointed out that typical springs are steel-based with a fairly high unit-resistance. So at high currents, voltage drop across a spring can be a fractional-volt, vs bypassed where nice conductive Cu reduces that to mV instead.
Swib
Last seen: 1 day 13 hours ago
The thing you need to look at is the voltage drop. As mentioned above djozz spring measurements are a good place to start.
Your battery will immediately sag to maybe 4.1 volts if it’s a good one under a 5 amp load. The internal resistance of all the components in your light will contribute more drop in voltage. Why is this important? If you look at either djozz or texas ace charts for specific leds you will see that they need a certain voltage to allow maximum current flow for that led. This translates into the lumens/lux you will get.
So a spring bypass will effectively reduce the voltage drop and give you increased current and output in your light.
One way to get around this is to use a buck driver with two cells in series. Now you have either a long tube light or lower mah capacity with 18350’s or 26350’s.
If you don’t like what it looks like on the wall, take it outside.
led4power
led4power's picture
Last seen: 1 hour 36 min ago
Copper alloy springs usually have resistance in range 10-25mOhm, steel based springs 40-80mOhm, bypassed steel springs 1-2mOhm.
Nooner
Last seen: 1 hour 14 min ago
I’ll piggy back a question on this thread.
Why do I not see copper braid used for bypasses on the driver spring? Is it to avoid potential grounding? Anyone try it?
I always do braid on tail and wire on driver. But that’s because I see that’s what all the cool kids are doing. I’ve been tempted to use braid both ends.
Jaded
Jaded's picture
Last seen: 10 months 4 days ago
This pretty much answers the question. It doesn’t matter even if it is the negative current flow in a circuit. Most of us measure AMP draw via the tail cap afterall. It’s all comes down to reducing electrical resistance for better conductivity, whether or not the improved conductivity gives any noticeable improvement in light output.
Enderman
Enderman's picture
Last seen: 10 hours 2 min ago
If your flashlight is pulling 20 amps, 10mOhms is a .2v loss, which is 4 watts of additional inefficiency.
A .2v loss could also mean much lower output from fet/direct drive flashlights since the available voltage under load could be 3.8 instead of 4v (for example). Or shorter regulated output time.
And also springs are not made of pure copper like a wire is, since it needs to have a high elasticity. The alloys they are made from is often much worse than copper conductivity. Using a wire as the conductor and spring as the pressure medium solves the problem easily.
Another solution is to use a special alloy of copper spring such as the one in the BLF high current spring group buy that’s currently happening. Few flashlights come stock with springs made from those alloys.
Zulumoose
Zulumoose's picture
I would think the most relevant thing regarding spring resistance is the fit. If the springs are 90% crushed by the battery, then it doesn’t much matter how long or thin they are, the current is going to be going sideways through a cone of crushed metal. Under those circumstances only experimentation with careful measurements is going to determine if a bypass will make any difference or not.
I wonder If it might be better sometimes to push a small amount of something metallic into the centre of the springs so that they crush harder together, instead of soldering a wire. I’m thinking of something similar to wire wool, but not as prone to breakage, wouldn’t want those small particles floating around and shorting things out.
Beam me up!
matg
Last seen: 2 days 16 hours ago
This thread made me a believer. I plan to do a spring bypass soon to try it out!
Cereal_killer
Cereal_killer's picture
Last seen: 2 weeks 6 days ago
I don’t use Cu braid anywhere anymore, it always fatigues and breaks after not very many battery changes at all compared to wire.
I use 24 or 26AWG Teflon coated, stranded wire at the head and tail in most cases, some super high current builds get 22 or even 20AWG.
luminarium iaculator
luminarium iaculator's picture
Last seen: 18 hours 5 min ago
If you are talking for single 18650 lights than you may be right…
You can do such modd but then you’ll loose some wire flexibility which means protected 18650 cells won’t fit any more?
Most drivers have spring on the driver and on switch.
So make tail switch spring direct or stiffer with something(make 18AWG snake inside that spring) and then it will push unprotected 18650 battery harder or more directly on driver spring making better + “crushed” contact as you said.
I found out that Amperage readings are greater when I savagely press 18650 cell to drivers + contact. So yes I agree if you make more solid plus contact it will be better imho.
Firelight2
Firelight2's picture
Last seen: 5 hours 29 min ago
I used to braid both ends, but the results weren’t great. The braid would tend to fray and then the connection would break.
I get much better results using 22 AWG copper with with silicone wrap. I bend the top end of the wire so it can hook over the top of the spring. The bottom wire goes below the spring or is tucked into the bottom-most coil. I then solder the wire on.
I typically do both head and tail springs the same way: with the wire inside the spring.
To prevent the solder at the top of the spring from wearing out and breaking off, I now always solder a small copper disk to the top of the spring on top of the wire. This greatly extends the lifespan of the bypass and lasts much longer than solder braid.
I have some 18 AWG wire but have never used it. It’s so thick, I don’t think I could get it inside the small EDC lights I tend to mod.
For drivers with a particularly small or hard to access contact pad, like the H17F, I use the same technique as above, but might install the spring inverted so it’s wider at the top. I still have a copper disk for where it touches the battery though.
eas
eas's picture
Last seen: 6 days 14 hours ago
I do spring bypasses, but I hate them. They will break, it’s just a matter of when.
caplang
Last seen: 3 months 4 weeks ago
Which one is better and in what condition: spring bypass or beryllium copper spring?
Firelight2
Spring bypass is lower resistance so your lights should be slightly brighter. However, as a previous poster mentioned, they do tend to break after awhile and need to be redone.
In contrast, a beryllium copper spring should last for the life of the light.
caplang
Thanks. Guess I’ll try with beryllium copper spring. The reason I ask about condition is because I remember reading someone (forgot who it was) said he didn’t want to put too much stress to the LEDs so he didn’t do spring bypass.
led4power
led4power's picture
I use lead free solder exclusively for >2years, mechanically it's much stronger and harder than lead based solder, so I recommend it for bypassing, reliability should be better than with lead PbSn solder which is very soft and more prone to break.
vt2nv
Gentlemen,
I didn’t abandon my own thread, that would be rude. I was out doing photography in an area that doesn’t have cell service… No texts, no internet, no phone. God, it was wonderful looking up and observing Perseid meteorites…
I understand and appreciate everything you’ve said, but I would imagine that contact resistance would be more of an issue that spring resistance. Only the smallest part of the spring actually touches the battery. I would rather see a pair of concentric springs than a single bypassed spring. Concentric springs would be less resistive, but the real benefit of concentric springs would be more spring in contact with the battery.
Bypassed spring may be more harmful than helpful. Consider that the bypass wire may cause axial misalignment between the spring and the battery. Less of the spring contacts the battery = increased contact resistance = more heat = loss of efficiency.
My profession requires that I use a good LCR meter. When I get a chance I’ll measure the resistance of several springs taking a 4-wire bridged measurement.
I appreciate the information and comments presented here, but I’m still a non-believer, until I prove that spring resistance results in a meaningful loss of efficiency.
Cheers
Lightbringer
I’m just wondering why small brass pills aren’t soldered directly to the driver vs a spring (get ‘em by the dozens at FT and the like). Have a big-ass bypassed spring in the tail, but the solid flat brass pill soldered to the driver should be seriously low-resistance.
vt2nv
1000% agree with you.
(Sheesh I haven’t used FT in years. Forgot all about them)
But there may be more (with me there usually is)…
Depending on the material used to make the spring, it may be difficult or impossible to make good bypass-wire solder joints. Assuming that the spring is solder-able I would prefer something like a #14 brass washer (or something like that) soldered to the spring (using a washer thin enough to allow the continued use of protect batteries, if necessary) much more contact area, which can’t be a bad thing.
Cheers
Swib
It’s not efficiency we are concerned about here, it’s output. If you look at djozz thread on springs you will see that a normal steel spring will have a voltage drop of near 300 millivolts. Add another 100 mV for driver and wire resistance if everything is done well. Taking into account the battery sag you now have a maximum of 3.7 volts available to the emitter.
An XPL-Hi at 3.7 volts will take roughly 4.5 amps producing about 1500 led lumens. Done properly, the same led given 4.0 volts will take about 6.5 amps giving 1800 plus led lumens.
For me candela is more important than lumens as I build primarily throwers and I can tell you from personal experience that the difference is substantial. For leds with a higher forward voltage like XP-G2 I like to use the 45% IACS springs because in my applications I can accept a roughly 11 mV drop.
By all means do the tests on various springs yourself and please post the results. We are always happy to have more resources.
Swib
Mountain Electronics sells brass buttons specifically for this purpose although I find it difficult to solder both the button and a wire bypass on the tail spring. If done properly a dome of solder can be applied to the top of the spring and sanded flat giving good contact.
The stock springs are solder-able as they need to be soldered to the switch board.
vt2nv
I respectfully disagree.
When efficiency is increased all kinds of good things can happen. Goodness = efficiency.
You’re assuming that supply voltage and emitter output are directly proportional. The electronics in between the battery and emitter negate the possibility of the proportional relationship you’re assuming. Of greater consideration should be emitter efficiency (lumens/watt) and/or efficiency of voltage/current regulators and/or efficiency of the processor itself along with the quality of PWM and PWM pulse integration and/or the on resistance of the low-side mosfet switch, along with transfer of heat from the emitter to the outside world.
Cheers
Swib
Ok, correct me if I’m wrong but the battery is connected directly to the emitter on the positive side (at least in the lights I build) and the electronics follow after on the negative return from the emitter. Or am I missing something here.
Edit: for clarity
Swib
As I mentioned earlier we are not concerned with efficiency when we do a bypass, just raw output.
vt2nv
Swib wrote:
Ok, correct me if I’m wrong but the battery is connected directly to the emitter on the positive side and the electronics follow after on the negative return from the emitter. Or am I missing something here.
V+ goes to voltage/current regulators . From there, regulated Vcc (usually 3.3 volts) goes to the processor. Buck regulation is easy. The processor looks at Vcc through a simple voltage divider. Next, the processor delivers PWM based on battery voltage and user input. That is the best case scenario, based on buck regulation for the electronics and an emitter that can be directly driven by the battery. All of that goes out the window when the emitter requires a supply voltage higher or lower than what the battery provides.
Next comes thermal sag. This is a very big deal as flashlights become brighter and smaller.
The point of diminished returns can happen when emitters are over driven. It can become impossible to remove heat fast enough, and the emitter dims as a result. I’ve proven this by driving a loose XHP70 on my bench. Driving the XHP70 at 12.2 volts resulted in more heat than I could remove using a fan-cooled heatsink. This is why turbo is usually limited to just a few minutes, but it doesn’t end there. Thermal sag must always be factored in.
Getting this stuff right requires a thoughtful, sensible design, especially now when flashlights are sold based on output lumens. When all of this is considered, soldering a bypass wire across the spring becomes a non-issue. The watt or two that’s lost across the spring is not a big deal when overall input wattage is considered.
Battery voltage stays flat up until the point when voltage drops very quickly. Bypassing the spring may result in an additional handful of seconds of useful light. IMO not enough justification for me to trash my springs.
So there you have it. Now harry steps off soapbox and slithers away. Cheers.
EasyB
Last seen: 25 min 57 sec ago
Cheers
For a FET/direct drive situation bypassing the springs can result in significant performance increase, which is what Swib and others are referring to when they talk about performance increase. The spring resistance is a significant portion of the total circuit resistance. A good 18650 cell has 15 to 30 mOhms, FET has ~5 mOhms. So when you take out the 70+ mOhms of the springs it makes a big difference. I don’t think contact resistance is usually more than a few mOhms.
Edit. To summarize, bypassing the spring can result in more current to the emitter, which usually means more output.
BlueSwordM
BlueSwordM's picture
Last seen: 11 hours 15 min ago
Contact resistance is usually in the 1-4mOhm mark depending on materials used.
In that case, gold is usually 1mOhm due to its high conducivity and softness, nickel is usually 2MmOhm, and steel can be even worse at up to 3,3-3,9mOhm, or even higher in some cases.
Or even worse. A copper alloy spring which is oxidized can be worse than that with no coating
This is why I chose a nickel plating: most cost effective while still having low contact resistance.
In most cases, like the BeCu spring I made, I chose mechanical properties over pure conductivity. I could have went with BeCu C17500 instead of BeCu C17530.
I could have gotten an even lower voltage drop at 0.045V at 6A had I changed the material, but at that point, it would be way worse mechanically, and a 0,007V difference is quite small.
That’s the whole point of why I made this specific spring: to get a spring good enough for 95% of cases where you don’t need more than 13-14A of current, and easy to bypass copper alloy spring.
Using higher conductivity parts is also crucial in FETs, but also regulated linear drivers, but most importantly, boost drivers.
TLDR: A nice phosphor bronze spring, or even BeCu spring if you want even higher power, is usually great in most cases.
If you want uttemost performance, while sacrificing mechanical properties, go with a spring bypass!
Swib
Take a look here and you will see that in fact V+ does go directly to the led+ in the builds I do.
We all understand the issues with heat and this has been addressed by one of our own members (Toykeeper) who has done a phenomenal job programming driver software to include thermal management.
vt2nv
“In the builds you do”. That’s what you said. I thought you were referring to products designed by engineers. The products that we pay good money for, I was not referring to designs created by electronics enthusiasts. How, exactly, would you drive a 6 volt XHP70 from a single cell? How would you make that regulator small enough to live inside a flashlight tube? I commend you for getting your design to work. Did you us a a spring bypass wire?
