GearVita Daily Deal: Xiaomi Xiaobai Smart 1080P IP Camera - Panoramic HD, AI Humanoid Detection, Remote Alarm
Klarus XT12GT flashlight, one of the the Klarus's XT series flashlights, has been developed with tactical use and self-defense in mind, is a precision-engineered illumination tool. Featuring 1600Lm impressive output and 603m exceptionally long-range throw, it is one of the most powerful tactical lights on the market today! Additionally, the XT12GT employs an innovative magnetic charging connector, which doubles as charging connector and keychain light. The patented dual tail switch design gives you full control over the light, allowing fast mode change - instant access to Turbo, Low, Strobe or SOS from any mode. This makes it an incredibly effective tactical torch for daily and emergency use.
$10 discount and free shipping coupon code of GearVita: KRXT12GT
Coupon price: $79.99
Coupon time: Aug 7 - Aug 16
Product link: https://gearvita.com/klarus-xt12gt-rechargeable-tactical-led-flashlight-1600-lumens.html
Product Features:
● Body crafted from aircraft-grade aluminium alloy with hard-anodised finish.
● Toughened ultra-clear mineral glass lens with anti-corrosion coating.
● Stainless steel strike bezel used to break glass, as a self defense tool.
● Dual tactical switch interface can be operated using just one hand.
▹ Primary switch: used to turn the light ON/OFF. While light is OFF, can be lightly pressed to temporarily access Turbo mode.
▹ Mode switch: While light is ON, used to cycle through outputs. While light is OFF, used to temporarily access either Low mode or Strobe mode.
● Features a pair of programmable settings for multi-purpose use.
▹ Tactical setting - access to Turbo, High, and Low modes, temporary access to Strobe mode.
▹ Outdoor setting - access to Turbo, High, Medium, Low, and S.O.S. modes, temporary access to Low mode.
● Can be recharged internally using the one-of-a-kind magnetic charging connector.
▹ Plug micro-USB cord into connector and attach connector to light's magnetic. charging surface to charge the light (only when equipped with a 18650 battery).
▹ Connector also functions as a 10 Lumen keylight.
● LED power indicator ring around charging surface displays battery's remaining charge.
● ITS temperature control and heat-dissipating fins help prevent overheating.
● Springs at bezel and tail help prevent damage from impacts, drops.
Related products:
https://gearvita.com/klarus-xt1a-tactical-led-flashlight-1000-lumens.html
https://gearvita.com/nitecore-srt9-smartring-tactical-led-flashlight-xhp50-2150lm.html
Feast your eyes on the Klarus XT11X flashlight, the world's brightest single 18650 light on the market today! This monster torch measures just 6 inches long and weighs less than half a pound, making it an easy carry for law enforcement, search and rescue, or even everyday users. Despite its incredibly average size, the flashlight's power is anything but average, able to output a ridiculous 3200 Lumens of brightness that can throw further than 300 yards! Such power is typically unheard of in such a compact light, but thanks to its powerful IMR 18650 power source (included) and it's efficient circuitry, thew XT11X is able to outshine all its competitors!
The XT11X does only wield immense power, it also sports one of the most innovative and user-friendly interfaces of any tactical torch. The flashlight is designed with two different methods of operation; a simple side switch better suited for normal everyday applications and a dual tailcap switch tailored for more tactical operations. Both methods of operations grant access to all of the flashlight's output modes, including its blinding strobe function and its efficient S.O.S. mode for emergency situations. The XT11X is able to grant instant access to both Strobe Mode and Low Mode and even allows for momentary activation for brief bursts of light.
The intelligent interface isn't the only feature that makes the XT11X user-friendly. The practical light is designed with a handy micro-USB charging port that can be used to recharge the included IMR 18650 internally, so there is no need for a separate designated charger! Charging progress can be easily monitored thanks to the multi-color LED indicator built right into the torch's side switch, glowing red while charging and green once charging is complete. The LED indicator can even be used to check up on the XT11X's remaining charge while in use so you're never blindsided by a dead battery!
$10 discount and free shipping coupon code of GearVita: KRXT11X
Coupon price: $78.68
Coupon time: Aug 8 - Aug 17
Product link: https://gearvita.com/klarus-xt11x-rechargeable-led-flashlight-3200-lumens.html
Main Parameters:
LED: CREE XHP70.2 P2 LED, lifetime up to 50,000 hours
Compatible Batteries: 1 x 18650 or 2 x CR123A or 2 x Klarus 16340.
Reflector: Orange Peel
Lens: Hardened mineral glass, AR coated, scratch resistant
Switch: Tactical tailcap dual-switch + side switch
Dimensions:
Head - 41.0mm (1.61”) diameter
Body - 25.4mm (1.00”) diameter
Length - 150.8mm (5.94”)
Brightness Outputs (using included IMR 18650*):
Turbo - 3200 lumens / 45 minutes
High - 400 lumens / 4 hours
Medium - 100 lumens / 16 hours
Low - 15 lumens / 82 hours
Strobe - 3200 lumens / 1 hour 30 min
S.O.S. - 100 lumens / 48 hours
Product Features:
● CREE XHP70.2 P2 LED with max output up to 3200 lumens (with included 18650 battery), far exceeds the competition.
● Easy Interface: one touch Strobe, one touch Turbo, one touch Low, mode memory function, SOS, switch lock-out function, quick settings switch.
● Multiple Safety Systems: Intelligent Thermal Protection System (ITS), Intelligent Battery Identification System (IBIS), Intelligent Charging System (ICS).
● Patented tail cap dual-switch and side switch design, adaptable for different scenarios, easy to use.
● Patented tactical tailcap dual-switch control; non-visual tactile one-handed operation in the dark with intuitive control.
● Two Interfaces: tactical setting and outdoor setting.
▹ Tactical Setting: specially designed for self-defense and tactical use. Classic KLARUS XT series control interface, one touch Strobe, one touch Turbo, perfect candidate for any mission.
▹ Outdoor Setting: designed with the wilderness in mind. One touch Low, one touch Turbo, multiple output levels with memory, SOS function, suitable for all needs in hunting, hiking, camping or search and rescue.
● Intelligent Thermal Protection System (ITS): monitors and auto-adjusts output levels in real-time in order to keep crucial components safe for the optimal balance of performance and safety.
● Intelligent Battery Identification System (IBIS): adjusts the output according to the currently installed 18650 battery discharge rate, compatible with 18650 Li-ion batteries, CR123A batteries and Klarus 16340 batteries.
● Intelligent Charging System (ICS): micro-USB charging port with real-time monitoring of charging status to prevent overcharging, limits max charging current to 1A to avoid damage to charging devices.
● Unique lock-out mode of both side and tail switch prevents accidental activation, this stops battery drain during storage or travel and avoids eye injuries.
● Springs at bezel and tail end resist shock and drop damage.
● Reverse Polarity Protection eliminates damage from incorrect battery orientation.
● Aero-space aluminum alloy body with CNC machining, Mil-spec hard anodizing (HA III), lightweight yet robust construction.
● Stainless bezel ring offers protection from impact.
● One-piece integrated head bezel design for high efficiency heat dissipation.
● Hardened glass lens with scratch resistant AR coating.
The Klarus XT11X flashlight is an impressive tactical flashlight that delivers 3200 lumens of amazing power. It’s designed with versatility and is packed to the brim with features so you can have the flashlight that you need at any given time. It features a side switch and dual tail switches that function independently allowing you to choose how you’d like to operate the flashlight. With the six total outputs including a strobe and an SOS mode, you’re ready for any situation. The two programmable settings are the Tactical Setting and the Outdoor Setting. Both are excellent and you can switch between them at any time or pick your favorite and leave the flashlight in that setting. Whether you’re a flashlight enthusiast, in law enforcement or security, or an outdoor enthusiast, you can’t go wrong with the Klarus XT11X.
Related products:
The Manker U22 flashlight is the latest flashlight from Manker, continuing the U21 model launched in spring 2016. Manker brings some improvements to the new flashlight. The Manker U22 uses the Cree XHP35 HI LED, which has two color temperatures: 5000 and 6500K. The flashlight has a maximum power of 1500 lumens, and at 65,000 cd, the illumination distance easily exceeds 500 meters. The flashlight reflector is one of the lustrous aluminum alloys, so the beam is concentrated and the halo around the spot reaches a maximum of 100 meters. The base of the base contains four heat sinks for optimal cooling, with control buttons between the heat sinks on one side and a charging plug on the other. The control buttons illuminate and we can turn on/off or change the steps and modes of the lantern through various push modes. During operation, the button will change color based on battery level.
The lantern charging plug is USB Type-C, and can be charged from different devices: 5V minimum 1Ah adapter, portable charger, computer, car adapter. Charging the battery from the flashlight is at 1.4Ah when using a 2Ah adapter. The battery with which the flashlight can work is a new one, its type being 21700, and the battery power reaches 4800mAh. Due to the high power, the torch has a very good autonomy on every stage: in turbo mode at 1,500 lumens, the torch will work for 4 linear minutes, after which it will continue to operate at 630 linear lumens over three hours. The dimensions of the Macker U22 are much lower than the older U21 version, hence the lower and lower beats of the new U22. The torch's weight is only 254gr with the 21700 battery.
The new Manker U22 is much easier to wear in hiking, guarding / searching, or used daily around the house. In addition to generous autonomy, the U22 delivers high power and high beating distance at an affordable price.
$5 discount and free shipping coupon code of GearVita: MANKU22
Coupon price: $57.95
Coupon time: Aug 9 - Aug 17
Product link: https://gearvita.com/manker-u22-led-flashlight-1500-lumens.html
Flashlight Interface:
● To turn on the flashlight, press the button on the head, the torch will start firefighters, press the button for 2 seconds to stop.
● To change the light steps, press the button briefly until you reach the desired level, the torch will start firefighting and after the end of the cycle the flashlight will return fireflies like: firefighters - step 1 - stage 2 - high gear - stage 2 - stage1 - fireflies.
● To use the torch at the last used stage, hold the button for 2 seconds - when the torch is off. To stop, press and hold for 2 seconds, and to return to the initial step, press the button for 2 seconds.
● For direct access to Turbo mode, press the button twice quickly when the torch is off, so do whatever you want to activate Turbo mode.
● To activate special modes, quickly press the power button twice to activate turbo mode, every press on the button will change the available modes: Strobe, SOS, Flicker, Pulse Button. After flashing the button, the torch will go on the fireball.
● To set the intensity of the firefighting mode (general mode - engineer mode), in this way the engineer can set the intensity of the firefighting step by choosing from the four available options. Turn off the flashlight and hold down the button until the button lights up and then press the four-way button quickly, go through the four available options and to memorize an intensity press the lantern button a long time.
Main Parameters:
● Emitter: CREE XHP35 HI (choice of Cool White or Neutral White)
● Maximum output: 1500 lumens
● With Type-C USB charging function
● Power by 1x Manker 4800mAh 21700 rechargeable battery (battery has Included)
● Maximum beam intensity: 65000cd
● Maximum beam distance: 509meters
● Working voltage: 2.8v - 4.35v (over discharge protection)
● Driver: Most efficiency constant current circuit
● Material: Aircraft-grade aluminum body
● Surface treatment: Premium type III hard-anodized anti-abrasive finish
● Lens: Toughened ultra-clear glass lens with anti-reflective coating
● Waterproof: IPX8 (2 meter under water)
● Impact resistance: 2meters
Brightness Levels and Runtime:
● Moonlight: 1-5lm / 960h
● Low: 90lm / 25h
● Medium1: 250lm / 8.5h
● High: 630lm / 4.2h
● Turbo: 1500-630lm / 3min-4h
● Strobe: 1500lm
Related products:
https://gearvita.com/klarus-xt11x-led-rechargeable-tactical-flashlight-3200-lumens.html
https://gearvita.com/wuben-a21-portable-led-flashlight-4200lumens.html
Below is the picture of U22 and the comparing picture of U21 and U22:
The Manker PL21 penlight is a practical pen lamp that is always at hand thanks to the clip in the shirt or in the trouser pocket. The penlight benefits from a slim body which can get into those tight corners a larger flashlight would struggle with. It adds to this feature with three light levels, the lower of which will not blind you when you're in that tight corner searching for a contact lens! However, turn it to the higher 200 lumen output and it will light up a room.
Powered by just two AAA batteries (not supplied), with an aircraft-grade aluminium body and a runtime of 47 hours on the low setting, this is all the lighting you'll need during your working day.
It is now available for purchase on GearVita with the price of only $24.68 by using the coupon code "MANKPL21", offer lasts until 20th.
Main Parameters:
Emitter: CREE XPG3 / Nichia 219C LED
Maximum 200 lumens output
Maximum beam intensity: 1000cd
Maximum beam distance:63meters
Working voltage: 1.8 - 3.2v
Power by 2x AAA batteries (battery not included)
Driver: most efficiency constant current circuit
Surface treatment: premium type III hard-anodized anti-abrasive finish
Aerospace grade aluminium alloy construction
Waterproof: IPX-8 (2 meter under water)
Size: 133mm length x 14mm head diameter
Weight: 29g (without battery)
Low: 4lm / 47hrs
Mid: 58lm / 4.5hrs
High: 200lm / 40min
Strobe: 200lm
Product Features:
● Unique design with simple but beautiful handles, easy to use, just like a pen.
● Made of durable aircraft grade aluminum.
● Adopts CREE XPG3 LED, maximum 200 lumens output.
● Maximum light duration of 47 hours.
● Peak beam intensity 1000cd, max beam 63 meters, impact resistance 2 meters.
● Bottom switch and clip is stainless steel, strong and durable.
● Three different light modes and strobe mode.
● High-quality processing water and shock resistant.
● Driver is the most efficiency constant current circuit.
Product link: https://gearvita.com/manker-pl21-led-penlight-200-lumens.html
Manker PL21 is a light, small and powerful penlight, although the body is small that may look unremarkable, but it can provide sufficient light. With it, you won't worry about working on the vehicle or taking a walk at night because it will always illuminate your surroundings.
The Manker MK39 Ranger flashlight is one impressive chunk of aircraft-grade aluminium with premium Type III hard-anodized anti-abrasive finish. Despite its awe inspiring stature is sits very comfortably in the hand and thanks to the positioning of the handle the thumb naturally engages with the operating controls seamlessly. For long periods of use a shoulder strap is provided for easy carry.
The MK39 has a lumen output of 6000 lumens with a choice of flood or focused beam making it a very adaptable lighting tool. Search and rescue teams take note, this torch is capable of an incredible 1100 metre throw. At the touch of the button the beam will ramp up from one lumen all the way to 6000 in unnoticeable increments, allowing the user to halt the process and choose the right amount of light for the job in hand. Plus it has a strobe which can be a very handy tool in an emergency.
Runtimes vary depending on the output being used but the Manker MK39 features a automatic cut out to preserve battery life and prevent overheating during heavy use. Whilst the 6000 lumen output is chosen the torch will drop to a lower level of power after three minutes, which will ensure a longer period of usage on one battery charge.
Main Parameters:
Emitter: Emitters:
- CW: 1* Cree XHP35 HI+8* Cree XPG3
- NW: 1* Cree XHP35 HI+8* Nichia 219C
Maximum output: 6000 lumens
Maximum beam intensity: 305000CD
Maximum beam distance :1100 meters
Working voltage: 11.2V - 16.8V (over discharge protection)
Water proof: IPX-8 (2 meter under water)
Impact resistance: 1 meters
Throw mode (ramping adjustment): 1-2000lm / 48hrs - 3min + 2hrs
Flood mode (ramping adjustment): 1 - 4000lm / 48hrs - 3min +1.5hrs
Throw and Flood mode (ramping adjustment): 2 - 6000lm / 24hrs - 3min+1hrs
Strobe mode: 6000lm
Product Features:
● Made of durable aircraft grade aluminum material, the surface is treated with premium Type III hard-anodized anti-abrasive finish, lens are toughened ultra-clear glass lens with anti-reflective coating.
● Power by 4x 18650 batteries, maximum 6000 lumens output.
● Maximum light duration of 48 hours.
● Peak beam intensity 30,5000cd, max beam 1100 meters, impact resistance 1 meters.
● Four different light modes and strobe mode.
Get it with the price of $173.99 at GearVita.com by using the $25 discount and free shipping coupon code "MK39RANG" when you checkout: https://gearvita.com/manker-mk39-ranger-led-flashlight-6000-lumens.html
Related products:
https://gearvita.com/acebeam-x80-gt-rechargeable-flashlight-32500-lumens.html
Lumintop ODL20C flashlight is a throw flashlight by utilizes a Cree XHP35 HI LED and adopt the aluminum flat and deep reflector, it emits a max 2,000 lumens output and creates an 860 meters long-range throwing distance by running on a 26650 cell. Five output levels plus Strobe, SOS and Beacon modes are more fit for various lighting demands. The USB Type-C charging enables a 2A current charging current and it takes only three hours to fully charged the battery. The humanized breath lamp allows easily locate the flashlight in the dark. Lock-out function, charging indicator, low battery reminder, tail standing ability and IP68 classification protection etc. makes ODL20C indispensable in your searching, rescuing, hiking activities and so on.
Main Parameters:
Light Tint: 2A
Light Source: Cree XHP35 HI LED
ANSI/NEMA FL1: Low / Med / High / Turbo / Eco / Strobe, SOS, Beacon
Output: 100LM / 350LM / 1000LM / 2000LM / 8LM / 2000LM
Runtime: 22h 55min / 6h 5min / 2h 30min* / 2h*/9 days / /
Maximum Output: 2000 lumens
Maximum Beam Distance: 860 meters
Maximum Beam Intensity: 184,500CD
Impact Resistance: 1.5m
Waterproof: IPX-8
Low: 100LM ( 22h 55min )
Med: 350LM ( 6h 5min )
High: 1000LM ( 2h 30min* )
Turbo: 2000LM ( 2h* )
Eco: 8LM ( 9 days )
Strobe / SOS / Beacon: 2000LM
Product Features:
● Utilizes Cree XHP 35 HI LED with a lifespan of 50,000 hours.
● Powered by one 26650 rechargeable Li-ion battery.
● High-efficiency circuit with a max runtime up to 9 days.
● Smooth and deep aluminous alloy reflector creates a max 860 meters beam distance.
● 5 output levels plus Strobe, SOS and Beacon with a max output of 2000 lumens.
● Humanized breathing light inside the switch, indicates the light location in the dark.
● Durable USB Type-C charging with 2A max charging current, 3 hours to fully charged a 5000mAh Li-ion battery, fast and convenience.
● Red and blue charging indicator visually shows the charging conditions.
● One side switch operation within one hand control.
● Lock-out function prevents accidental activation.
● Enhance cooling fins ensure a comfortable holding.
● Low voltage indicator reminds to change or charge the battery in time.
● Flat tail cap with tail standing ability to serve as a candle.
● Toughened and ultra-clear glass lens with anti-reflective coating.
● Made of aerospace-grade aluminum alloy, premium Type III hard-anodized anti-abrasive finish on the surface.
● Waterproof to IPX-8 standard, 2 meters underwater (ensure the waterproof cover is in sealed condition).
Get it with the price of $61.99 on GearVita by using the $8 discount coupon code "LTODL20C" when you checkout: https://gearvita.com/lumintop-odl20c-rechargeable-flashlight-2000lumens.html
Related products:
If you're going to be carrying a flashlight everyday, you'd better make sure that it's got all of the best features available. Fortunately the Sunwayman C23C flashlight is jam packed with the best LED flashlight technology available, equipped with a CREE XM-L2 U2 LED that allows it to emit a stunning 1000 Lumens of bright white light. With a polished smooth reflector in a slim styled housing, this flashlight is capable of throwing a beam up to 203 Meters, crushing similarly sized competitors. Available in black and natural color bodies, the C23C is a perfect choice for as a light for work, home or emergency situations.
You don't have time to waste taking batteries in and out of your vital electronics, and the folks at Sunwayman recognize just how valuable your time is. With that in mind the C23C has been made capable of charging your 18650 battery right inside the light and without any fuss. The intelligent charging system detects the voltage and capacity of your individual battery and provides rapid yet safe charging. An integrated indicator lamp located under the side switch gives a clear visual cue for when the battery is charging and fully charged.
If you thought that Sunwayman was going to make a light that didn't integrate the very best construction features known to LED flashlight, you thought wrong. The C23C is constructed from high-quality aerospace-grade aluminum that is both lightweight and durable, capable of withstanding any sort of everyday bump or drop you can throw at it. A stainless steel retaining ring holds the tempered glass lens in place which protects solid state LED technology that is virtually shock proof. Additionally this light is rated IPX-6 Waterproof and is ready for use in any sort of weather condition.
Offering 1000 Lumen output in a compact body, the Sunwayman C23C is the latest in Sunwayman's line of rechargeable EDC LED flashlights. This light allows for internal recharging of 18650 batteries utilizing a micro-USB cord, a quick and easy way to power up your every day carry. Available in either black or natural coloring, this light makes a great companion for workers, emergency responders or just every day home use.
Main Parameters:
Light Source: CREE XM-L2 U2
Output Modes: Turbo, High, Mid, Low, Moon + SOS, Aviation Signal, Strobe
Maximum Output: 1000 lumens
Max Throw Distance: 208m
Impact Resistant: 2 meters
Waterproof: IPX-6
Product Features:
● CREE XM-L2 U3 LED, with a lifetime of up to 50,000 hours.
● Slightly depress the side switch to turn on/off the flashlight as well as selecting desired output mode:
- Turbo (1000 lumens, automatically lowers to High after 3 mins continuous use)
- High (580 lumens, 2 hrs )
- Mid (130 lumens, 10 hrs )
- Low (40 lumens, 35 hrs )
- Strobe, SOS, Aviation Signal
● USB charging interface, can be charged by laptop, charger baby or direct power supply.
● Constant current circuit, constant output.
● Effective range of 208 meters.
● Uses one single 18650 or two CR123A batteries.
● High quality metal smooth reflector maintains great throw distance and spread with an ideal beam pattern.
● Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top.
● Military Specification Type III- hard anodized body.
● Waterproof, in accordance with IPX-6 standard .
● Ultra-clear tempered glass lens resists scratches and impacts.
Available in black and silver color at GearVita.com, Sunwayman C23C makes a great companion for workers, emergency responders or just every day home use. Using the coupon code "SWMC23C" before 27th, spend $52.88, you can bring it home to accompany you: https://gearvita.com/sunwayman-c23c-multi-functional-flashlight-1000-lumens.html
Related products:
https://gearvita.com/olight-m2t-warrior-tactical-led-flashlight-1200lumen.html
https://gearvita.com/fenix-uc35-v2-0-usb-rechargeable-flashlight-1000-lumens.html
Sunwayman G20C flashlight, a compact, yet powerful tactical LED flashlight that is sure to blind anything in its way. The G20C measures in at 5.5" and is constructed from aerospace aluminum alloy with a military grade hard-anodized finish, making it extremely durable and reliable. The innovative and stylish design makes the G20C a pleasure to hold, whether you're camping or on duty. With its powerful LED, dual-button switch interface, and compact size, the G20C is sure to appeal to police officers, military personnel, and hunters.
A CREE XM-L2 (U2) LED churns out a blinding 400 lumens with a maximum beam distance of 208 meters. To cycle between the different output modes, you use the dual-button tailcap switch on the back of the light. The main button will momentarily turn on the light, as well as constant on/off, while the secondary stainless steel switch cycles between modes. With the light off, the secondary switch gives you instant access to strobe, for those emergency situations. Mode memory will automatically memorize the last mode used, so there are no surprises when reactivating the light.
Powering the G20C are either two Lithium CR123A batteries, two rechargeable Li-Ion 16340 batteries, or a single rechargeable Li-Ion 18650, the choice is yours. Being that the Sunwayman G20C is o-ring sealed, it is rated IPX-8 waterproof, so you can dunk it under two meters of water without damaging the light or the batteries. You can also drop the light from up to 1.5 meters without damaging the light.
Main Parameters:
Light Source: CREE XM-L2 U2 LED
Battery Configurations: Uses one single 18650 or two CR123A batteries
Max Output: 1000 lumens
Effective Range: 208 meters
Working Voltage: 2.8 ~ 6V
Waterproof: IPX-8
High: 1000 lumens ( 1hr )
Mid: 150 lumens ( 6 hrs )
Low: 16 lumens ( 80 hrs )
Strobe
Product Features:
● CREE XM-L2 U2 LED, with a lifetime of up to 50,000 hours.
● Tail cap dual-push-button switches, one to control on/off, the other for selecting desired output mode, three types mode-switching.
● Constant current circuit, constant output to protect eyes.
● As low as 20μA standby current ensures a safe standby mode.
● Considerate memory function, convenient in use, intelligent low-voltage, indicator lamp protects, battery from over-discharge.
● Exquisite stainless steel clip, easy carry on backpack or pocket.
● Waterproof, in accordance with IPX-8 standard, 2 meters under water.
● Tail-stand capable, can be used as a candle.
Product link: https://gearvita.com/sunwayman-g20c-tactical-led-flashlight-1000-lumens.html
Choosing a powerful handy flashlight is not easy for us. The Sunwayman G20C is bursting on GearVita with a powerful 1000 Lumen output and a stylish and compact dual switch design. Utilizes two tail switch buttons that allow users easily access to on and off functions as well as several lighting modes. The G20C makes a great EDC due to its compact size, yet the massive output and sleek design make it perfect for tactical operations or hunting as well. Before the deadline of 27th, its transaction price is $52.90 with the coupon code "SWMG20C".
Related product:
The Nitecore SC4 charger is a reliable smart charger with manually selectable charging currents, LCD screen and an optomized charging process for IMR batteries. Capable of switching between 3A and 6A output, this charger can be customized to match the ideal charging rate for your unique battery and needs. Equipped with 4 Individual Charging Bays, the SC4 is ready for heavy duty charging action. Compatible with just about any standard sized Li-ion, IMR or LiFeP04 battery as well as NiMH batteries, the SC4 is the the only charger you'll ever need.
With intelligent charging features, using the Nitecore SC4 is as easy as inserting your batteries into the charger - the SC4 does the rest. Both the charging current and voltage can also be adjusted for specialized batteries. A brightly lit LCD screen displays charging status and battery health while built-in overcharging, overheating and short circuit protections keep you and your batteries safe. In the event of a problem, the screen will read "EE EE" to alert users and cease charging.
Main Parameters:
Input:
AC 100-240V 50/60Hz
1A (MAX) 40W
DC 12V 3A
Output Voltage:
Battery: 4.35V ± 1% / 4.2V ± 1% / 3.7V ± 1% / 1.48V ± 1%:
USB: 5V ± 5% 2.1A MAX
Output Current: 3A*2 MAX 1.5A*4
Compatible with:
Li-ion/IMR/LiFePO4:
10440, 10500, 12340, 12500, 12650, 13450, 13500, 13650, 14350, 14430, 14500,
14650, 16500, 16340(RCR123), 16650, 17350, 17500, 17650, 17670, 18350, 18490,
18500, 18650, 22500, 22650, 25500, 26500, 26650
Ni-MH(NiCd):
AA, AAA, AAAA, C, D
Product Features:
● Four slots can charge one to four batteries simultaneously.
● The charging current is up to 6A in total and maximum charging current up to 3A in a single slot.
● Using LCD screen with MVA technology to display real-time information on charging status.
● Display the current charge status with a perfect 160-degree visual angle.
● Can charge the external devices via the integrated USB port.
● Multifunctional charger, can diagnose and identify bad batteries, protect against overcharging, improper installation, short-circuit.
● Intelligent charging mode detects battery type and capacity, then select the appropriate charging current based on the battery type.
● The SC4 is capable of activating depleted Li-ion batteries with a protective circuit.
● Coordinate with PID system to automatically control the temperature within a safety limit.
● Energy saving when there is no operation in 3 minutes, the screen will dim to save energy automatically.
● Constructed from high-quality flame retardant and fire resistant PC materials and featuring intelligent temperature monitoring.
Equipped with a USB output as well, the SC4 can be used to charge external devices such as laptops and cell phones. With the price of the $34.88 after applying the coupon code "NTSC4", it is definitely worthy to buy from GearVita. Get it and say goodbye to long charging times: https://gearvita.com/nitecore-sc4-superb-charger.html
Related product:
https://gearvita.com/nitecore-i8-8-charging-slots-smart-universal-quick-charger.html
The Olight M2R Warrior flashlight is the new rechargeable dual switch LED tactical flashlight from Olight. This flashlight is equipped with the latest XHP35 HD LED powered by a single high discharge rate 18650 with an output range of 1 to 1,500 lumens. The M2R features a quiet tail switch with minimal noise when being clicked on for tactical purposes. The tail cap of this light can magnetically charge directly through the tail tactical switch. The side switch has a similar operation as the Olight's series flashlights, while the tail switch can be switched between conventional and enhanced tactical operation modes allowing the user to access turbo or strobe with a single click. With its slim head, lanyard hole, and dual direction pocket clip, the M2R Warrior is the perfect tactical light to carry with you on any adventure.
Main Parameters:
LED: CREE XHP-35 HD
Compatible Batteries: 1 x 18650, 2 x CR123A
Light Output: 1,500 to 1 lumen
Throw Distance (Max): 208m
Peak Beam Intensity: 10,880 cd
Waterproof: IPX-8
Impact Resistance: 1.5 meters
Mode 1: 1,500~700 lumens - 3 minutes~110 minutes (Turbo mode will lower from 1,500 to 700 lumens after 3 minutes to prevent overheating)
Mode 2: 700 lumens - 2 hours
Mode 3: 250 lumens - 6.25 hours
Mode 4: 60 lumens - 20 hours
Mode 5: 15 lumens - 70 hours
Mode 6: 1 lumen - 25 days
Product Features:
● The body of Olight M2R Warrior features smooth but aggressive matching for just the right amount of grip while maintaining comfort over prolonged use.
● Durable metal tail switch design making the M2R rechargeable directly from the switch with the Olight signature USB magnetic charging cable.
● The tail cap uses a quiet tact switch and the side button is pronounced with a braille marking for ease of use in a dark and tactical situation.
● It only takes a single press of the tail cap switch to access the 1,500-lumen turbo or strobe mode for high stress situations.
● Comes with a high capacity and high discharge rate 3500mAh 18650 lithium-ion battery that supports up to 1500 lumens with long runtimes.
● Compatible with all 18650 batteries (with a discharge current over 6A and protection board) and the Olight micro-dok.
● Slim head design, detachable pocket clip for both carry directions, and lanyard hole for an enhanced and comfortable user experience.
● This flashlight can be turned on/off from either the side or the tail switch, making it adaptable to different operational habits.
● IPX8 waterproof rated for up to 2 meters under water without damage.
The M2R is the perfect carry to bring with you for any situation, no matter be used for tactical, self-defensive or outdoor, it will meet your different demands. It sells for $99.95 on most websites, but applying the coupon code "OLTM2RW" on GearVita, you can get it for only $89.98 and of free shipping: https://gearvita.com/olight-m2r-warrior-led-flashlight-1500-lumens.html
Related product:
The Fenix BC35R is an all-round USB rechargeable bicycle light. The max output is 1800 lumens, making it a tough performer not only for city commuting, but also for country cycling. The innovative cut-off facula line guarantees safer cycling by not dazzling oncoming traffic, whether on foot or in vehicles. The OLED screen displays the current output and corresponding runtime, thus riders are constantly aware of the bicycle light status. The remote pressure switch makes instant operation possible during cycling, and changing road conditions can be abruptly dealt with. The Fenix BC35R bike light has built-in anti-theft protection which smartly monitors users' bicycles. Moving the bicycle will set off an alarm, also helpful when a potential danger or emergency is encountered.
Main Parameters:
LED: Cree XHP50 neutral white LED
Max Output: 1800 lumens
Max Distance: 146m
Output Modes: 6
Impact Resistance:1m
Waterproof: IP66
Batteries: Built-in 5200mAh/3.7V rechargeable battery
Burst: 1800 lumens
Turbo: 1100 lumens ( 2.2h** )
High: 400 lumens ( 6.5h )
Med: 150 lumens ( 12h )
Low: 45 lumens ( 28h )
Flash: 150 lumens
Product Features:
● Cree XHP50 LED offers even and soft neutral white beam - better for color rendering and vision protection.
● Orange-peel reflector makes every corner is clearer to sight and darkness is nowhere to hide.
● Max 1800 lumens output and 146m beam distance, guarantee safe cycling with better vision.
● The rechargeable built-in 5200mAh Li-ion battery offers max runtime of 28 hours. Standard micro USB charging port, charge as you like anywhere.
● Anti-glare cut-off facula line for safer cycling.
● Equipped with extra remote pressure switch - conveniently select desired output and activate.
● The user-friendly OLED screen displays current output and corresponding runtime, thus user is constantly aware of the bicycle light status, making the rider well-prepared for on-going riding trip.
● Intelligent anti-theft protection funtion smartly monitors bicycles, once the security key is removed, moving the bicycle will set off a piercing alarm.
● The functional switch will flash red when the runtime of low output level is less than 10 minutes.
● Overheat protection - The light will accumulate a lot of heat when working on Turbo mode. The light will automatically step down to a lower brightness level to reduce the temperature, but turbo mode can be reselected.
● Low-voltage warning - When the voltage level drops below a present level, the bicycle light is programmed to step down to the next lower brightness level until low output is reached.
● Quick-release light mount.
● High-strength aluminum body.
● IP66 rated dustproof totally protected against dust and foreign objects, waterproof can withstand heavy rain and splashing.
Applying the coupon code "FNBC35R", you can buy this bicycle light of $99.88 on GearVita. Grab your BC35R and don't miss the opportunity to have fun riding: https://gearvita.com/fenix-bc35r-led-bike-light-1800lm.html
Related products:
https://gearvita.com/fenix-bc30r-led-bike-light-1800lm.html
https://gearvita.com/fenix-bc30-led-bike-light-1800lm.html
Acebeam EC50 Gen III flashlight is updated version base on early one, now equipped with a powerful CREE XHP70.2 LED and powered by 1 * 26650 rechargeable Li-ion battery, max output 3850 lumens beam throw 326 meters, compact size and lightweight is for convenient operation. Also redesigned massy bezel must be your super personal body guard in daily use to outdoor and professional use while a simple press on the side switch is all you need to select output.
The body of EC50 Gen III has been knurled with a diamond pattern to make longterm use less harmful to the skin on your hands. The vents on the sides of the head to make sure the LED and circuits don't overheat are fewer but wider. The strike bezel has also been given a larger form this time, giving it a bit more heft than previous versions. It is the brightest EDC flashlight integrates high performance and long standby time, adventurers and flashlight enthusiasts are very excited for the release of the Acebeam EC50 Gen III.
Main Parameters:
LED Type: CREE XHP70.2 LED with a lifetime of 50,000 hours
Power Source: 1 * 26650 battery
Maximum Output: 3850 lumens
Max Beam Throw: 326 meters
Max Runtime: 50 days
Peak Beam Intensity: 26500cd
Waterproof: Standard IPX-8 (2 meters)
Impact Resistant: 1.2 meters
Output Levels and Runtime:
Firefly: 1 lumen ( 50 days )
Low: 200lumens ( 14 hours )
Mid: 1000lumens ( 2.8 hours )
High: 1800lumens ( 1.2 hours )
Turbo: 3850lumens ( 2 mins + 1.1 hours )
Strobe: 1800lumens ( 2.2 hours )
Product Features:
● Latest CREE XHP70.2 LED with amazing 5000K tint.
● Max output is a staggering 3850 lumens with a beam distance of 326 meters.
● Aircraft-grade aluminum body structure.
● Ultra-clear tempered glass lens with anti-reflective coating.
● Premium type III hard-anodized anti-abrasive finish.
● Smooth reflector gives perfect beam and throw.
● Tactical diamond knurling makes longterm firm grip easy on the hands.
● Streamlined body design.
● Easy to use side switch interface.
● Intelligent circuit board design for maximum performance and long run time.
● Digitally regulated output maintains constant brightness.
● Over-heat protection to avoid high-temperature of the surface.
● Reverse polarity protection prevents damage from improperly inserted batteries.
● Low battery indicator will flash when voltage down to 3V.
● Micro USB chargeable, plug USB cable directly into light to charger.
● Waterproof to IPX8 standards.
With unstoppable power like that, this flashlight is perfect for just about anything that will come up in everyday use. Great for typical chores where you need a light or even late night navigation, the EC50 Gen III is the ultimate light utility for most users.
It is on sale at the GearVita at a cost of $114.99, but if you enter the coupon code "ABEC50", the price will drop to only $102.99. Otherwise, the coupon code is valid until Oct 20th: https://gearvita.com/acebeam-ec50-gen-iii-led-flashlight-3850-lumen.html
Related products:
https://gearvita.com/acebeam-ec65-4000lm-rechargeable-flashlight.html
https://gearvita.com/acebeam-k30-led-flashlight-5200lumens.html
The Sunwayman C41CT flashlight is a compact and powerful EDC light featuring a stylish design. Weighing less than 4 ounces and measuring just 4.33 inches long, this flashlight is easy to store in your kitchen drawer or carry with you wherever you go! The torch's unique body is constructed from aerospace aluminum alloy and comes with a unique wavey knurling for a secure grip, also it is completely waterproof, so it's safe to use in any weather conditions. The Sunwayman C41CT can be powered by either a pair of CR123As or a single 18650 and can even be recharged internally when equipped with a 18650. When charging, the side switch doubles as an LED power indicator, letting you know when it's fully charged. The flashlight can emit up to 1000 lumens of light, provide up to 60 hours of runtimeand can produce a total of 6 outputs to cover any lighting needs.
Main Parameters:
LED: CREE XM-L2 U3
Color BIN: Cool white
Power Source: 1 x 18650 or 2 x CR123A
Max Output: 1000lm
Peak Beam Distance: 307 meters
IPX Rating: IPX-8 (waterproof and submersible up to 2 meters)
Impact Resistant: 1 meter
Outputs Mode:
Turbo - 1000 lumens
High - 580 lumens ( 150 mins )
Med - 130 lumens ( 800 mins )
Low - 16 lumens ( 3600 hours )
Two Hidden Modes: Strobe and SOS
Product Features:
● High quality LED of CREE XM-L2 U3, with lifespan up to 50,000 hours.
● Rugged anodized aluminum body is waterproof.
● Unique wave knurling provides secure grip.
● High-powered LED and smooth reflector provide maximum throw.
● Pair of tactical outputs for emergency situations.
● Easy-to-use pushbutton side switch lets you effortlessly cycle through outputs.
● While equipped with 18650, light is internally rechargeable through micro-USB charging port.
● Side switch doubles as LED power indicator, flashing green while light charges, glowing solid green when fully charged.
● Constant current circuit, uses one single 18650 battery or two CR123A batteries.
● The circuit CPU will detect automatically when the battery voltage lowers to 2.8V and the white light will flash slowly five times and turn off to protect battery.
● Reverse polarity protection prevents damage caused by improperly inserted batteries.
● Tail-stand capable, can be used as a lamp.
● Waterproof accords with IPX-8 standard.
● Memory funtion, the last mode used will be memorized for next time use.
Compact and versatile, the Sunwayman C41CT rechargeable LED flashlight is a powerful light that features all the qualities in a top EDC. Take the coupon code "SWMC41CT" before Oct 20th, get this top EDC flashlight from GearVita with the coupon price of $45.99: https://gearvita.com/sunwayman-c41ct-led-flashlight-1000lm.html
Related products:
Mi IR night light is equipped with an infrared motion sensor with up to 120-degree and 7-meter motion detection range. Using advanced photosensitive sensor and human infrared sensor technology with anti-infrared interference function, the sensor instantly reacts to the movement and turns on the light. It will last 15 seconds after you walk out of the sensing area. The Mi IR light is powered by batteries and making it a low power consumption, energy-saving and environment-friendly device.
Product Features:
● Extraordinary Sensing Function
120-degree sensing angle and sensing distance is 5 to 7 meters. Adopting light-sensitive and body infrared induction technology, the light can turn on automatically in the dark environment, 15 seconds duration, with anti-infrared jamming function.
● Two Brightness Modes
There are two brightness modes to switch: with 0.7 lumens mode and 3.8 lumens mode, you can adjust the brightness according to your needs.
● Extremely Low Power Consumption
Powered by 3 x AA battery, free you from socket trouble. The choice of ultra-low power consumption of the sensing program ensures only 0.25mW power consumption when in standby mode. 0.7 lumens mode can be used for about 12 months, 3.8 lumens mode can be used for about 6 months time.
● Safe Environmental Material
Selecting environmental-friendly ABS material and high-density polyethylene material, the light has a small body with flexibility, which is more durable, practical and safer.
● No Socket Constraint
With 3m glue on its back, you can stick it on wardrobe, stairs, bedside, etc. And it has an adjustable hook, provides brightness for you anytime.
● Soft Warm Light
2700K color temperature without visible strobe lights, protect the vision of your eyes especially your baby's eyes.
● Cool Lampshade
Total reflection structure of fish scales, can make the light equably reflect to the diffusion shell, provide a good visual experience for families.
● Freshnel Ultra-thin Lens
Equipped with a Freshnel ultra-thin lens which enhances the performance of the sensor.
● Minimalist Design Adds Unique Flavor to Life
The light adhering to minimalist design style, external soft round design encounters silkily-touching edge, easily matches with a variety of furniture style.
When talking about an ordinary night lamp that turns on when motion is detected, it wouldn't gain much attention from most human beings. Fortunately this is not just a night lamp running on AA batteries, it is an original Xiaomi Mijia night light! Never bump your foot in the middle of the night again for it can be put anywhere in your home. Apply coupon code "MIYSENSOR" on GearVita to get this night light with the price of $7.99: https://gearvita.com/xiaomi-mijia-yeelight-sensor-night-light.html
Related products:
https://gearvita.com/seenda-dual-usb-port-wall-charger-with-led-light.html
https://gearvita.com/official-international-version-yeelight-ylfw01yl-smart-atmosphere-candela-light-support-bluetooth-control.html
Sunwayman C22CC is an inventive flashlight, which uses the 18650 battery, the two lights equipped can work as well as simultaneously. C22C comes with charging instructions and low voltage protection, full care of flashlight "heart" to make it healthy. The main light can be controlled by a button, it's easy to operate and hand feel smooth. Unique side light can be used as a corner lamp which is full of yellow ray, so it is suitable to read at night or at camping. The head of Sunwayman C22CC flashlight is designed with multi-slot to make it cool, so that effectively increase the cooling effect. The charging's design of flashlight's tail is hidden in extreme to make the whole flashlight more beautiful and easy to use. The stainless steel attack head is located in the tail, and install a quick hole, so it can be connected to universal tripods quickly to meet various function's request.
Main Parameters:
Emitter: Cree XM-L2 U2 LED(primary), Cree XP-G2 R5 LED(side)
LED Lifespan: 50,000 hours
Estimated Usage Time: 42 hours
Luminous Flux: 820 lemens
Beam Distance: 310 meters
Battery: 1 x 18650 or 2 x CR123A or 2 x 16340
Waterproof: IPX-8 (waterproof and submersible up to 2 meters)
Output Modes and Runtime:
● Primary Light
Turbo (820 lumens) - 3 minutes
High (510 lumens) - 2 hour and 10 minutes
Mid (130 lumens) - 10 hours
Low (35 lumens) - 42 hours
Strobe
SOS
● Side Light
High (160 lumens) - 5 hours
Mid (46 lumens) - 13 hours
Low (16 lumens) - 68 hours
Product Features:
● Main light Cree XM-L2 U2 LED, side light Cree XP-G2 R5 LED, with a lifetime of up to 50,000 hours.
● High quality metal smooth reflector for main light maintains great throw diatance and spread with an ideal beam pattern, able to generate an 820 Lumen beam that can reach over 1000 feet away.
● Special secondary side LED produces up to 160 lumens of soft white light for close-range lighting.
● Aerospace-grade aluminum body with military-grade Type-III hard anodized finish, stainless steel retaining ring on the top to prevent any ingression of water and dust.
● Ultra-clear tempered glass lens is both impact and scratch resistant.
● Single pushbutton side switch uses optical lens to access all outputs.
● Stainless steel crenulated tailcap used as glass breaker, self-defense tool.
● Tail with three feet design, also used as tripod mount for hands-free illumination.
● Use one single 18650 lithium battery or two CR123A/16340 lithium battery for constant current circuit and constant brightness.
● Micro-USB charging port underneath tailcap for recharging battery internally (18650 and 16340 only).
● LED power indicator above side switch glows when charging, flashes when fully charged.
● Inverted on the plane to be used as candle lighting.
● Precision IPX-8 waterproof design, can continue to light under 2 meters.
● Stainless steel clip, can be linked to clothing at any time, flexible and more use.
● Flashlight tail UNC 1/4'' screw hole, can be installed directly on most of the equipment used.
Applying the coupon code "SMWC22CC" when checkout on GearVita before Otc 24th, you can get this flashlight at the final price of $39.99: https://gearvita.com/sunwayman-c22cc-rechargeable-led-flashlight.html
Related products:
Convoy S2+ flashlight is a powerful and cost-effective LED torch and used for many outdoor applications. It supports up to 1000 lumens output with the use of a 18650 Li-ion battery. Constant current circuit ensures constant output, with its ultra-long shooting function, its lighting range is about 50-100 meters. Moreover, it also has mode memory function, low voltage protection and battery reverse protection function.
Main Parameters:
Emitters: Cree XM-L2 U2
Lumens Range: 500-1000 lumens
Luminous Flux: 940 lumens
Circuitry: 2.1A
Color Temperature: 6500-7000K
Mode: Two kinds of mode - .three modes: low 5%-mid 50%-high100% and five modes: low 5%-mid 50%-high100%-Strobe-SOS
Power Source: 18650 battery
Beam Distance: 50-100m
Product Features:
● High Performance
Adopting XM-L2 LED light, with up to 1000lm high brightness and long service time, to light up your way in the dark.
● Two Group Modes Choice
Two kinds of mode group, group 1 (Low - Mid - High - Strobe - SOS) and group 2 (Low - Mid - High) to meet your different demands.
● Mode Memory Function
Convoy S2+ can memory the mode next time when turn on for more than three seconds. If less than 3 seconds, it will goes into next mode.
● Low Voltage Protection
When the voltage of battery is 2.9 - 3.1V, the flashlight flashes 2 times/sec with low brightness for alarm.
● Battery Reserve Protection
If your battery is reversed, it will not bright only, do worry about battery or circuit.
● Premium Material
Adopting high quality aluminum alloy material, durable and stable.
● Widely Applicable
Idea for cycling, hiking, camping, fishing, working, repairing and other outdoor activities.
Get this LED flashlight from GearVita for multiple use, it is perfect for working, outdoor camping, emergency, repairing, and daily use: https://gearvita.com/convoy-s2-led-flashlight-cree-xm-l2-u2.html
Related products:
https://gearvita.com/convoy-s3-xm-l2-led-flashlight.html
https://gearvita.com/convoy-t2-led-flashlight-320lumens.html
Hey Cathy does Gearbita offer free shipping ?
I was looking at the mijia motion detection lights on sale for 7.99$ but saw shipping was another 6$ Which makes it no longer a great deal
The Sunwayman C45CT flashlight is the powerful thrower searching flashlight. Wavy knurling design body ensures the light is easy-gripped. Charging Indicator Lamp cleverly built in the user-friendly side switch covered by sub-transparent rubber cap. The tail of the flashlight is ingeniously designed to be used as an emergency spike.
Main Parameters:
Emitter: Cree XM-L2 U3 LED
Runtime: 60 hours
Beam Range: 450 meters
Power Supply: 1*18650 battery or 2*CR123A(16340) batteries
Light Color: Cold white
Working Voltage: 3.7V
Waterproof: IPX-8
Turbo: 1000 lumens
High: 580 lumens ( 150 mins )
Mid: 130 lumens ( 800 mins )
Low: 16 lumens ( 3600 mins )
Product Features:
● High quality LED of Cree XM-L2 U3, with lifetime up to 50,000 hours.
● Powered by single 18650 battery or two CR123A(16340) batterries to provide constant current circuit.
● Max runtime up to 1600 mins, with the reflector of big diameter, Sunwayman C45CT is capable of reaching up to 450 meters effective range.
● One single switch provides access to all functions.
● Four brightness levels and two special functions available.
● Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish.
● Wavy knurling design body ensures the light is easy-gripped.
● Memory function, the last mode used will be memorized for next time use.
● USB charging system, charging indicator lamp cleverly built in the user-friendly side switch covered by sub-transparent rubber cap.
● Low-voltage indication, the circuit CPU will detect automatically when the battery voltage lowers to 2.8V and the white light will flash slowly five times and turn off to protect battery.
● Electronic reverse battery protection effectively protects the flashlight circuit.
● Indicator lamp for charging is built inside the side switch, it turns on in green and flash when it's under charging, constant green when charging finishes.
● Twisting the rear part of the tail cap leftwards to use it as an emergency spike to break glass when needed.
● Waterproof in accordance with IPX-8.
Purchase this flashlight of $49.99 on GearVita with the coupon code "SMWC45CT" when checkout, the deadline is Oct 26th: https://gearvita.com/sunwayman-c45ct-led-flashlight-1000lm.html
Related products:
https://gearvita.com/sunwayman-c22cc-led-flashlight-820lumens.html
Convoy S10 flashlight comes with stainless steel and aluminum alloy material which is durable and practical. Loaded with18650 battery, it also features with adjustable brightness and low voltage protection function. When the voltage is 2.9-3.1, the flashlight will flash twice a second at a low brightness.
Main Parameters:
Light Source Brand: Cree
Light Source Model: XM-L2
Light Source Bin: T4-7A / T6-4C / T6-3B / U2-1A
Color Temperature: 3000K / 4200K / 5000K / 6500K
Light Color: Warm White / Neutral Light / Natural Light / White
Driver: 7135*8
Power: 11W
Voltage: 4.2V
Max Brightness: 1000 lumens
Modes: 1%-10%-100%
Waterproof Rating: IPX6
Product Features:
● High-quality tainless steel and aluminum alloy material, durable and practical.
● Waterproof to IPX-6 standard, available in all weather conditions, don't worry about the rainy days anymore.
● As long as a cigarette, Convoy S10 only takes up a little space in your bag, compact and small size for easy carrying.
● 10W strong power light with 6500-7000K color temperature, suitable for gambling stone jade identification.
● Powered by 1 x 18650 battery.
● Memory function, when the flashlight is on over 3s, the current mode is in memory.
● Low voltage protection, when the voltage is 2.9-3.1, the flashlight will flash twice a second at a low brightness.
● Stainless steel head, durable and shock resistant.
● Level-3 oxidation treatment shell.
● Battery reverse protection, battery will reverse, do not worry, no problem will occur.
There are four options for you to choose from on GearVita, T4-7A, T6-4C, T6-3B, U2-1A, all of which can enjoy a discount of $3 with the coupon code "CVS10" when you checkout. The following is the price after the discount:
T4-7A - $14.99
T6-4C - $14.99
T6-3B - $13.99
U2-1A - $12.99
Product link: https://gearvita.com/convoy-s10-led-flashlight-1000lm.html
Related products:
https://gearvita.com/convoy-s9-xml2-flashlight-580lm-natural-light.html
https://gearvita.com/convoy-s2-led-flashlight-cree-xm-l2-u2-7135-6-2-mode-groups.html
The Klarus XT32 flashlight is specially designed for tactical and hunting. Using a US CREE XP - L HI V3 LED lamp beads with a max output of 1200 lumens and a long lifespan of 50000h, it has two settings - classic tactical setting and hunting setting, and 6 brightness modes to meet your luminous needs. This flashlight uses 2 × 18650 lithium-ion battery or 4 × CR123A battery which is easy to buy to eliminate travel troubles in charging. Equipped with a lanyard and a holster, it's easy to carry.
Main Parameters:
Emitters: Cree XP-L HI V3
LED Lifespan: 50000h
Luminous Flux: Max 1200lm
Luminous Intensity: Max 250000cd
Power Source: 2 × 18650 or 4 × CR123A
Working Voltage: 5.0 V-12.8V
Six Outputs:
Turbo (1200 lumens) - 3 hour runtime
High (400 lumens) - 7 hour runtime
Medium (100 lumens) - 34 hour runtime
Low (20 lumens) - 120 hour runtime
Strobe (1200 lumens) - 6 hour runtime
SOS (100 lumens) - 102 hour runtime
Two Programmable Settings:
Tactical Setting: One-touch turbo, one-touch strobe
Hunting Setting: One-touch turbo, one-touch low
Product Features:
● Cree XP-L HI V3 LED, max brightness up to 1200 lumens.
● Precision manufactured reflector with optimized design for extended range illumination, improved spotlight performance, max beam distance up to 1000 meters, exceeds current industry level.
● Patented dual tactical tail switch and side switch design to meet different user need, easy and intuitive operation.
● Two programmable settings and six brightness modes.
● Perfect for hunting, hiking, camping, search and rescue operations and more.
● Newest ITS intelligent temperature protection system, monitors internal temperature and adjust output for maximum brightness, protects LED and internal components to ensure safety, stability, optimum performance, and user comfort.
● Lock-out function of the side switch prevents accidental or unnecessary activation.
● Intelligent capacity indicator monitor remaining battery capacity anytime.
● Front and rear mounted springs protect against shocks and drops.
● Aerospace aluminum alloy construction, CNC precision machining, mil-spec HAIII anodizing, rugged and anti-abrasion.
● Hardened and AR-coated lens, anti-abrasion and high light transmittance.
● Waterproof IPX-8 ( underwater 2m ), suitable for rainy weather.
This particular flashlight has a 1000 meter range, is programmable, and has a host of other features that make it really stand out from your average searchlight. This flashlight is really excellent for outdoor activities such as hunting or search and rescue or even professional work. It's really quite versatile and can be used in a myriad of situations. Get Klarus XT32 of $89.99 by appling the coupon code "KRXT32" from GearVita, it's definitely powerful enough to get the job done: https://gearvita.com/klarus-xt32-led-flashlight-1200-lumens.html
Related products:
klarus xt12gt
klarus xt11x
