Yes, it is pretty. A few weeks ago I beam optimized a friend's SingFire-L05 headlamp which I once modified with such T3 7A4 emitter, to change its optics from reflector to TIR. Did it with this 35.8mm marble grain lens @ Yajiamei Optics plus two ∅35×2mm flat lenses on top to supplement the total lens setup height. Worked like a charm, and when I turned the headlamp on again I was struck with the reddiness of the thing versus an S2+ class torch modified with a first batch (T6 chromaticity coordinate) 4000K CRI90+ LH351D plus wide beam TIR, which looked green in :-D comparison LoL! Lovely smooth and wide beam for close up work.
Has anyone used their 351B 3000K 90cri leds on a light yet? I haven’t found a light to use these leds on yet but I wanted to see if anyone could report back and let us know how they look.
I was just about to order and realize that it is a 7A3 and not 7A4 in your link. I would love to try the 7A4 as that is more rosy. Do you have any idea where the 7A4 can still be purchased? Thanks.
Ordered some from Kaidomain but I just got confirmation from them that it is indeed the 7A3 and not the 7A4, which they sold out. They changed the link and deleted that image showing 7A4. Darn, I was really hoping to try a WW 90CRI emitter with far below the BBL tint to get rid of the yellowness.
If you not stick to 5050 format (XM-L), probably the new Luminus SST-20 3000K emitters could be good (being slightly under BBL). Maybe you can also hope for newer stock of E21A in 3000K, but Clemence said, that there were issues with mass production of some CCTs of E21A emitters.
I have only 2000K and 4000K Nichia E21, which are both under BBL, or at least no signs of yellow color domination.
I finally found the way to order new batch of 351D/B
Is it still interesting for someone?)
1)SPHWHTL3DA0GF4T0Q6. - 351D 4000k 90cri
2)SPHWH2L3D30GD4V0F3 (H1) –351B 3000K 90cri
3)SPHWH2L3D30GD4V0H3 (J1)- 351B 3000K 90cri (new a 10% more efficient than 2)
4)Not hicri but still may be interesting.
SPHWH2L3D30ED4Y0G3 (H1) 351B 2200K 80cri.
