(prototype) the GT Mini
Mine says that also since the 3rd…GRR
My Mini GT arrived in Canada yesterday and is in customs in Mississauga. It will hopefully be released and arrive in the next few days.
Received my order in the mail today. It’s great!
Quick question: I’m trying to set the moonlight mode to “1”. When I click to set “1” as the desired moonlight level, the light starts up brighter than the “default 3” level. When I click to set moonlight to “2,” it is noticeably dimmer than “3”. Am I doing something wrong?
Thanks for the help and putting this buy together!
Neal mailed me the latest tracking numbers for the GT mini today
please mail me the email adress you used to buy to Martin@m4dm4x.com - i check if there is a tracking#
for other shipping information ask Neal@m4dm4x.com direct;)
Are you in ramping mode? Are you pressing and holding from off to get to moonlight? You have to release the button as soon as the light turns on otherwise it starts ramping up. It just stays at moonlight for maybe 0.5 second.
The bottom of the ramp seems to be about moonlight 4 brightness level.
I checked moonlight levels 1-4 and all seemed to work as they should. Moonlight 1 just barely had the led glowing. I had to turn off the room light just to see if it was on or not.
Hi,
I’m wondering whether I can use a Convoy C8 lens as a replacement for the lens in my GT mini. I don’t have a Convoy C8 lens at the moment but I am planning to buy one since I couldn’t find a replacement lens for the GT mini in Banggood.
I received my GT Mini today. I didn’t receive my GT Mini holster and my GT Mini didn’t work. I tried with all the 18650 still nothing. One very dim light came on for 1 second when I pushed the button then nothing after that. The rubber button has a green light when I click on it, it flashes then stop then flash couple time but still no light. I tried following the user manual still nothing. I emailed Martin. What do I do now?
You’ll need to talk to Martin or Neal.
Do you get the 2 blinks when the battery is connected?
I emailed Martin already. I only see some green light flash in the rubber button when the battery is connected.
The C8 lens is much too small.
You would probably need to get a lens at Lumintop or else an aftermarket lens. If you are in the USA, you might try: https://www.flashlightlens.com
Thanks Jason, I hope BG will start selling parts for the GT Mini soon.
Yes I’m in ramping mode. I just tried again and clicking once for the setting “moonlight 1” is a lot brighter than clicking twice for setting “2”.
It’s not that big a deal because setting 2 is plenty low enough for me. I just thought the situation is bizarre.
Thanks for the help Jason.
My Mini has shown up in Queens and is on its way to me ( I hope) maybe others will see similar tracking with theirs
Some pictures of my defective gt mini
Smoke inside the ref:
Smoke in the right
Beamshots both on turbo and both neutral white
Have contacted Neal yesterday, still waiting for answer
sad u got a kaputt light, its clearly looks defective and they hopefully will send u a new one.
I hope so too
Thanks JasonWW, I have edited my post
Mine came today, a couple days early from what tracking said earlier in the week. All my add-ons were also in the box. Everything works well, and unfortunately mine came with a ton of glue in the bezel.
Light came and it’s my first thrower! Neat light but the backlit button isn’t aligned for me…nbd just looks like the light is smirking at me.
I am missing the diffuser and 18350 I ordered tho ): email sent to Neal
I think all the bezels are glued. Nothing else, though.
