I’m wondering whether I can use a Convoy C8 lens as a replacement for the lens in my GT mini. I don’t have a Convoy C8 lens at the moment but I am planning to buy one since I couldn’t find a replacement lens for the GT mini in Banggood.
I received my GT Mini today. I didn’t receive my GT Mini holster and my GT Mini didn’t work. I tried with all the 18650 still nothing. One very dim light came on for 1 second when I pushed the button then nothing after that. The rubber button has a green light when I click on it, it flashes then stop then flash couple time but still no light. I tried following the user manual still nothing. I emailed Martin. What do I do now?
Mine came today, a couple days early from what tracking said earlier in the week. All my add-ons were also in the box. Everything works well, and unfortunately mine came with a ton of glue in the bezel.
-Identical head size vs. D1S
-Lower moon than D1S
-Pretty much identical beam profile, D1S has a marginally smaller spot but wider corona
-My D1S has a bit more rosiness to the beam, GT Mini is more neutral, no green
-Switching between the two on momentary turbo, there’s practically no telling them apart
-Mushy switch cover, but good distinctive click, no trouble doing 5x clicks in a row
–18350 tube is ridiculous
So, if you have the D1S and don’t need more configurable NarsilM and its mode config, the silly but adorable 18350 tube, there’s no need to get the more expensive GT Mini.
