Mine came today, a couple days early from what tracking said earlier in the week. All my add-ons were also in the box. Everything works well, and unfortunately mine came with a ton of glue in the bezel.
-Identical head size vs. D1S
-Lower moon than D1S
-Pretty much identical beam profile, D1S has a marginally smaller spot but wider corona
-My D1S has a bit more rosiness to the beam, GT Mini is more neutral, no green
-Switching between the two on momentary turbo, there’s practically no telling them apart
-Mushy switch cover, but good distinctive click, no trouble doing 5x clicks in a row
–18350 tube is ridiculous
So, if you have the D1S and don’t need more configurable NarsilM and its mode config, the silly but adorable 18350 tube, there’s no need to get the more expensive GT Mini.
Got my order of GT Mini too (CW & NW). In both cases, the buttons do look like smiley faces (2 “eyes” and a smile).
Also, in both cases, when the tube is properly screwed up, the tube label “GT Mini” doesn’t align to the side button… (more like at a 90-degree angle).
I would like it better when the “GT Mini” words line up with the button, when the tube is properly screwed up…
