Now I realize why it comes in a plastic inlay inside additionally to the carton box
Piece of Tape doesnĀ“t work, maybe IĀ“ll find a plastic suitable lidā¦
Maybe itĀ“s the best not to think too much about and remove the battery instead
Btw, mine has been running non stop on the lowest warm white mode for 3 weeks straight. I havenāt spoiled myself by measuring the current draw beforehand.
edit: red low battery indicator and the light started flashing just now after 3 weeks.
I just got the one I ordered in today and I have to say I REALLY like it. We had a power outage just the other day and it would of been perfect for that.
I want to get another one when they come back in stock.
It canāt lock out.
In case I want to pack it in a bag and the sensor will switch it on:
Cut an isolation disc out of plastic.
(Any yoghurt cup will serve you)
Lollipop shape (make it 1cm longer than I did and round the tip), fold it so it stays in place while you screw the cap on. For normal use the disc is storred in the battery tube
I canāt find the off button when the thing is lit:
A marker out of blake tape aligns with the position on the bottom.
Nice ideasā¦ā¦ I too had trouble locating the off buttton. I took some gitd paint and made a dot on the black frameā¦ā¦. although even it can be hard to see when the light is on(which it always is when it needs to be turned off) :student: . I might try the black tape or maybe paint a āblack dotā on the globeā¦ā¦ the lockout is cool too! :+1:
I decided to try a white GITD paint dot on the white globe just above the switch.
I like itā¦. It shows up good when the light is on but is subtle when the light is off.
And it glows for a while after turning the light off. I plan on putting a coat of clear
fingernail polish on it to keep it in place.
