They probably don’t have a very optimized fan setup. Looking at the pictures I don’t see a clear inlet and outlet for the air. Most designs will draw cool air into the head from around your hand and then blow it out the sides. I don’t see that here. Hopefully it does not suck the hot air back in and circulate it. That could definitely limit the highest sustainable output. Maybe it moves air from the left side to the right side? We will need to see more pictures to find out.
I see it uses the older xhp70 instead of the 70.2. Interesting choice especially since their DX80 32k lumen light uses the 70.2.
Martin, does the R70C have a 70.2 or 70? I assume they are trying to get into the trend of high powered throwers like the GT70 and MF04S. Surely they would choose the 70.2 so that they can use a SMO reflector to get more distance.
Looking at the R70C specs,I see this. Utilizes one American CREE XHP70 + 2nd generation+ LED, with a lifespan of up to 50000 hours and a maximum output of 6500 lumens.
So,it is 70.2 for sure.
It is possible that the same leds have been put in the MS12.
wow that MS12 is gonna retail for 600$ thats crazy and also doesnt make sense to use older xhp70 emitters for that price i think its fail imo… if they gonna charge olight/acebeam prices suddenly then their quality better be up there since the dx80 wasnt exactly flawless… will acebeam now bump the x70 to 50k lumens? lol
Lets say the 50k lumens cant be run at very high if they write stable 15k then it means it can run that nonstop probably… so if paying 600$ for a light that can only run short bursts highest its a waste of money then and lumens…
RRP on the DX80 is around $400 but Gearbest nearly always do it for around $220, I expect the MS12 will be competively sold by Gearbest, Banggood and other stockists at a price per lumens point that puts all but Hank Wang to shame!
Imalent notoriously underestimate their lower mode level ratings so chances are that 15k could be 20k.
I heard Imalent were selling the DX80 at cost ($180) just to get rid of them. They needed the money to build new models which hopefully could be sold for a profit. So I would not expect half off on the MS12. We will have to wait and see.
Oh no, that is alot of wasted potential. So with XHP70.2, they can probably get 70k lumens? I hope Imalent don’t glue the bezels and make this thing modder friendly so we can get it modded with 70.2 emitters.
It’s probably already pushing 500+ watts. I don’t think there’s much more left in the batteries. If you leave the driver alone and just swap emitters to 70.2, you might get 500 more lumens each (at maybe 7A@6v) so another 6,000 lumen. Maybe not even that much.
They probably glued everything to keep modders from tinkering with it and then asking for a replacement when we screw it up. Lol
emitters driven optimally means 1500-1800 OTF per emitter, this is a flashlight company not a BLF modder going to the absolute limits
there is a point where you gain little lumens with a lot more heat and possible issues over long time, like burned phosphor ect.
Emitters pushed to maximum limit would mean 2200 OTF per emitter, but heat gets an issue
