Sofirn SP10A V2.0
49 posts / 0 new
rost333
rost333's picture
Last seen: 1 min 22 sec ago
Sofirn SP10A V2.0
I have no affiliation with Sofirn (other than being a customer).
SP10A V2.0 on Amazon and on Aliexpress
Here is the previous version of this flashlight on Aliexpress
Edited by: rost333 on 09/21/2018 - 05:34
samyy
Last seen: 6 days 22 hours ago
Finally!
teacher
teacher's picture
Last seen: 6 months 1 week ago
Thanks for the info. Good information. Will this light go into TURBO when using a AA NiMh battery??
Nooner
Last seen: 2 hours 59 min ago
I’m not seeing any difference between this V2 and the original/existing SP10A. Looks like the same specs and functionality. What exactly has been changed?
moderator007
moderator007's picture
Last seen: 1 hour 11 min ago
I was looking and wondering the same thing.
samyy
One thing is specs “on the paper”, another thing are real lumens.
I dont know about SP10A, but on SP10B the lowest level was way too low, much lower than claimed 1 lm (in fact it was lower than the lowest level on my Zebralight SC62W, which is 0,01 lm!). Then, second highest level should be (according Sofirn) 20 lm, but i measured 35 lm. So there is big jump from lowest to second lowest level and some people complained about it.
So as I understand the SP10A v2 specs, Sofirn adds another level on the lower side of the output.
Second change, Sofirn lowers the Turbo, but looks like it should work now without 3min step down.
rost333
rost333's picture
SP10A
5 Modes powered AA battery: Moonlight (1lm) 180h – Low (20lm) 11h40min – Mid (70) 3h19min – High (270lm) 51min – Strobe (270lm) 1h42min
5 Modes powered 14500 battery: Moonlight (2lm) 330h – Low (60lm) 12h2min – Mid (224lm) 3h13min – High (573lm) 1h15min – Strobe (573lm) 2h31min
Upgraded SP10A v2.0
6 Modes powered by AA battery (Nimh) : Eco (0.5 lm) 284h – Low (5lm) 68h50min – Mid (30lm) 11h26min – High (80lm) 3h3min – Turbo (200lm) 51min – Strobe (200lm) 51min
6 Modes powered by14500 battery: Eco (0.5lm) 227h – Low (15lm) 61h33min – Mid (50lm) 11h42min – High (200lm) 3h21min – Turbo (550lm) 1h3min – Strobe (550lm) 1h3min
As per information from Sofirn Store on Aliexpress “…we will add this new model in Aliexpress shop on next Monday”
Nooner
Thanks.
I guess I was too lazy to look up the actual specs of the original. I also could have just reached across the table and grabbed my SP10A V1 and counted the mode groups Facepalm
moderator007
rost333 wrote:
SP10A
Upgraded SP10A v2.0
Okay I see now, thanks. Any idea why output in turbo went from 573 lumen’s down to 550. Most of the time output goes up on a newer model not down.
MascaratumB
MascaratumB's picture
Last seen: 6 hours 38 min ago
Is it normal to have higher runtimes on Li-Ion batteries than Ni-MH?
Honest question!!
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
korkfoto
Last seen: 9 hours 34 min ago
Does it have the stepdown after 3 minutes in Turbo mode?
Thank you.
FIAT LUX!
rost333
rost333's picture
korkfoto wrote:
Does it have the stepdown after 3 minutes in Turbo mode? Thank you.
Yes, it has a stepdown after 3 minutes in Turbo mode.
Considering the stable in circuit and lifetime of LED emitter, the lumen max was adjusted to 550lm.
korkfoto
Thanks, rost333!
FIAT LUX!
rost333
rost333's picture
Sofirn SP10A V2.0 for $14.59 on Aliexpress (for 3 days)
mmalive
Last seen: 10 months 3 weeks ago
I picked this light up when it first released. Still waiting for arrival. Normally do not pick up small lights but like Sofirn to take a chance.
rost333
rost333's picture
Exactly, I have V1.0 and I can’t wait to compare those two Wink
samyy
I really hope they fixed impact resistance issues http://budgetlightforum.com/node/58866
rost333
rost333's picture
pennzy
pennzy's picture
Last seen: 29 min 1 sec ago
You will like it . I have one from 6mo. ago and it is my work light. Small enough to carry unnoticed and bright enough for close to medium distances. I put a protective ring around the switch so it never activates in the pocket and helps index the button .
rost333
rost333's picture
Hi Pennzy, can you post a picture of this protective ring around the switch please? Thx!
pennzy
pennzy's picture
Sorry but I don’t have what it takes to post pictures . I can tell you what I did though. Simply glued a stainless steel washer over the button. Harbor Freight has assortment packs of stainless and brass washer that seem to match up in size well.I could email a picture if you want.
rost333
rost333's picture
I’m afraid that you don’t want to post the result as it’s not aesthetically pleasing. I’m I correct?
To upload a picture you can use igmur.com and post a link here Wink
pennzy
pennzy's picture
No, I just don’t want to upload pictures to the cloud.
samyy
Sofirn SP10 V2.0 in blue color.
https://www.aliexpress.com/store/product/Sofirn-Blue-SP10-V2-0-Mini-LED-Flashlight-AA-High-Power-14500-Flashlight-EDC-Pocket-Light/2933049_32841154512.html?spm=2114.12010615.8148356.12.1d0a4fe8QCffUo
hodor
hodor's picture
Last seen: 1 hour 7 min ago
I just bought a blue SP10B (V1) Facepalm
korkfoto
I see that the V 2.0 has a SMO reflector… That’s a drawback for me.
FIAT LUX!
eas
eas's picture
Last seen: 3 weeks 15 hours ago
My v2 does not have an SMO reflector, it’s the same OP as the earlier versions.
I’m not very happy with the v2. I bought one because another one of my UT01’s stopped working with 14500s. I was looking forward to the improved mode spacing.
I didn’t realize that they’d gotten rid of the option to turn on to moon that the last generation had. Now it just comes up in whatever the last normal mode it was in before it was turned off. Oh, but only when using 14500s. If I’m reading the instructions right, it doesn’t have mode memory when used with AA cells.
Be forewarned. They gave a mode and took away a useful UI affordance.
korkfoto
That’s good to know. However, on their store on AE it’s figured with SMO reflector…
That’s… nasty. Sad
Thank you for the warning.
FIAT LUX!
maba
Last seen: 18 hours 34 min ago
I had all versions, V2 is hopeless, I do not recommend it..
- Starts with Low, WTF?
- The mode memory sometimes does not work at 14500
- One 14500 was discharged to 2.2V
eas
eas's picture
Interesting. The blue v2 is pictured with a SMO reflector, but the description says it has an OP reflector. The black is pictured with an OP reflector.
Blackbeard
Blackbeard's picture
Last seen: 7 hours 14 min ago
theres a lightning deal right now its $12.99, ends in 4 hours
Amazon
