-Identical head size vs. D1S
-Lower moon than D1S
-Pretty much identical beam profile, D1S has a marginally smaller spot but wider corona
-My D1S has a bit more rosiness to the beam, GT Mini is more neutral, no green
-Switching between the two on momentary turbo, thereās practically no telling them apart
-Mushy switch cover, but good distinctive click, no trouble doing 5x clicks in a row
ā18350 tube is ridiculous
So, if you have the D1S and donāt need more configurable NarsilM and its mode config, the silly but adorable 18350 tube, thereās no need to get the more expensive GT Mini.
Got my order of GT Mini too (CW & NW). In both cases, the buttons do look like smiley faces (2 āeyesā and a smile).
Also, in both cases, when the tube is properly screwed up, the tube label āGT Miniā doesnāt align to the side buttonā¦ (more like at a 90-degree angle).
I would like it better when the āGT Miniā words line up with the button, when the tube is properly screwed upā¦
I did. But I got a replied says he is not Neal. I guess I got the name wrong. I believe i placed my order through m4d m4x web site. This is not my first time never had any problem before. There is first time for everything. I will wait few more days. Hopefully I get contact soon. It really sucks that you wait for few weeks and the light donāt work.
Itās on M4D M4Xās website, but Neal runs his own āNealās Dealsā page within that website. Neal is the one who actually handles the transactions for things like the Mini GT.
Yeah I know, I recall a couple others saying their bezels werenāt glued. Mine had so much glue that some mustāve dripped down the head of the light due to how hot the box got in transit cause it was all over. A bit excessive lol
Mine was not glued, or so little that I failed noticing it. It did have faulty switching though (light fails to respond to switching action most of the times). Iām in the process of finding out if it is the switch itself or some connection (Neal asked about that). Also in the process of finding out how Neal is going to make it right (as CvonP in the other thread already mentioned about his GTmini without switch cover: āI did not buy a DIY flashlightā).
