My mini GT finally arrived. I thought it was without a rubber button, but it remained in the box … How do I put it in there? The steel ring are very tight. I did not buy a DIY flashlight. Anyone had a similar situation?
Hmmm, very strange. I believe the metal ring just pushes into place. You would need to get a metal tool and pry the ring out. Then put the rubber switch in the hole and push the metal ring back in.
You would need to make sure the button is rotated so the led can shine through. See this picture.
I would like to do it even with a screwdriver, but I’m afraid that I will scratch anodisation. I do not have a flashlight in the collection without even one scratch.
I am also wondering if I already pulled out a ring it would be possible to push it again. I mean, it can be loose. This ring is probably a one-off.
I think so too, Jason.
I tried to push the edge of rubber button under the ring, but it’s too tight.
You are getting great advice how to fix it but I agree that you did not buy a DIY flashlight. This is not like simply tightening a retaining ring, there is serious risk of severe scratches when trying to fix it. So if you do not feel like doing the fix IMO you are right to contact the seller (Neal).
