[M4Ddeal active] : Lumintop GT Mini - 2 authorized deals
PM me the emailadress you used to order (paypal) and i look in the list i got from neal
My mini GT finally arrived. I thought it was without a rubber button, but it remained in the box … How do I put it in there? The steel ring are very tight. I did not buy a DIY flashlight. Anyone had a similar situation?
Hmmm, very strange. I believe the metal ring just pushes into place. You would need to get a metal tool and pry the ring out. Then put the rubber switch in the hole and push the metal ring back in.
You would need to make sure the button is rotated so the led can shine through. See this picture.
I’m sure it’s possible to just push the rubber button in its place without removing the steel ring
The metal ring needs to press down on the lip of the rubber button in order to make a watertight seal. This is also what holds it into place.
I would like to do it even with a screwdriver, but I’m afraid that I will scratch anodisation. I do not have a flashlight in the collection without even one scratch.
I am also wondering if I already pulled out a ring it would be possible to push it again. I mean, it can be loose. This ring is probably a one-off.
I think so too, Jason.
I tried to push the edge of rubber button under the ring, but it’s too tight.
Just take a small screwdriver or similar tool and use it like this.
Lift one side just a little, then lift the opposite side a little. Go back and forth until it lifts up or pops off.
Don’t worry about scratches under the button cover where it can’t be seen.
Just make sure the button cover is rotated correctly before you tap the metal ring back down.
I think it’s the same basic idea as the metal ring on the ROT66 light.
Try lubing the inside of the ring in the light with some silicone grease.
great advice (as always) JasonWW!
:beer:
Ordered 2 lights thanks for the codes M4D M4X
:beer:
You are getting great advice how to fix it but I agree that you did not buy a DIY flashlight. This is not like simply tightening a retaining ring, there is serious risk of severe scratches when trying to fix it. So if you do not feel like doing the fix IMO you are right to contact the seller (Neal).
So, who do we contact if you are missing something?
My 18350 tube is missing.
just contact the person who you sent the money? ;)
have you ordered from Neal or banggood?
I did it through the GB, so Neal then?
So do I email or PM?
Maybe a PM at first?
Neal PM
GOT MINE!
Just great first impressions. Smaller than I thought, but I like that.
Thanks to BLF & all who organized this, you know who you are.
:slight_smile:
use neal@m4dm4x.com
Received mine 3 days ago. Everything works fine, but it seems i got ww instead of NW. I compared it to BLF A6 and Q8. :frowning:
