WowTac A4 "Thrower" // Full Review
39 posts / 0 new
robo819
robo819's picture
Last seen: 1 month 3 days ago
This is the new WowTac A4 , sent to me for review and no other compensation other than keeping the light.
You can find the A4 at the main WowTac site……….
http://wowtac.com/wowtac-a4-2000-lumen-searchlight-battery-excluded/
or at Amazon………. https://www.amazon.com/dp/B07FMQMLLG (Links are NON affiliated)
As many know , we havent heard from WowTac with any new products for awhile , but they are back and I personally think they have a winner with the new A4.
The A4 came in a bubble wrap package , with the Wowtac box inside that. Everything was in good condition and well packed and padded inside the box when the light arrived.
The light comes with 2 spare O-rings , an extra switch boot for the side switch and the instruction manual.
I have to admit I was pleasantly surprised when I took this one from the packaging. I was not expecting the light to be as compact as it is using 2 × 18650 cells and claiming 800 plus yards of throw.
Pictured below with the Convoy L6 (Left) A4 center and Thorfire C8 (Right)
The knurling is well done on this light as are all the threads.
The XHP 35 HI emitter sits perfectly centered in an almost flawless reflector behind an AR coated lens that was almost invisible when I took this light from the box.
The heat seems to be handled pretty well with the few fins the A4 has. The shelf for the emitter is solid and the MCPCB is screwed down.
The head is actually made very much like the ThruNite Catapult V6 head , for those who have or are familiar with that light.
Here are the A4 and Catapult V6 side by side…….
The side switch is a metallic one and is lighted Blue in the center when the power is on, This same indicator doubles as a low voltage warning , turning Red when the cells are at 20% power remaining and the Red light starts blinking constantly when the cells get down to 10% power remaining. The Branding (etching) on the light is also well done.
The A4 has a pretty simple UI. A long press turns the light on in Firefly mode , a press and hold (about 1/2 to 3/4 of a second) advances to the next higher mode of Low. From there you can cycle through Low , Medium and high modes holding the switch button down and just release it when desired mode is reached. The Turbo is a double click from any mode , including off and the strobe is a double click from there. To turn the light on or off a simple quick click of the switch is all that is needed. There is mode memory for Low , Medium and High modes , so when the light is turned off in one of those modes it will come back on in that mode next time the power is turned on.
The beam from the A4 is a very well defined hotspot with very little to no corona around it and enough spill to be a useable spill for walking and such.
Shown below at 22 Feet from White garage door on Firefly / Low / Medium / High and Turbo………
At longer distances the beam is still pretty well defined with most of the light going on target.
Here at 50 , 75 and 100 yards from the Gate on high and Turbo……
And at 155 yards from the barn on High and Turbo…..
I have been limited on time lately with multiple reviews and my 85 year old aunt breaking her hip and a very good friend having heart pump replaced and major hernia surgery at the same time. I have not done any run time testing on the A4 , but with good quality 2 x 3400mAH 18650 , I am guessing the run time should be pretty decent.
I have done Lumens and tail amperage testing however , as listed in the charts below……….
Wowtac does specify to use PROTECTED cells only and this is due to the length of the tube , as even the button top unprotected will work to power the light , but they will not maintain good contact with any jarring or bumping of the light.
The only negative I can come up with on the A4 is that I would like to see them possibly use springs at both ends to allow use of cells other than the protected only , even if the driver is regulated and the output would remain pretty much the same , because I know some people may not have the protected cells on hand.
Overall I think this is an excellent little thrower , with exceptional build quality , great output and throw , especially for the price being in the $50 range.
EDIT: *It looks like Wowtac has actually lowered the price for the A4 on their Amazon store site already , making this light a pretty good deal IMO………… *https://www.amazon.com/Ultra-Thrower-Flashlight-Hunting-Fishing-Included...
If there is any particular photo you would like a better look at , here is the link to all the still photos of the light and the GIF images.
https://postimg.cc/gallery/23mec4xa2/
For those who may not want to watch the whole video , the live outdoor footage comparing the Thrunite Catapult V6 and the Emisar D1S with the A4 starts at 12:58 of the video timeline.
Video followed by the listed specs……….
FEATURES
•WOWTAC A4 adopts one Cree XHP 35 HI LED to make max output up to 2000 lumens and max beam distance of 750 meters.
•Ultra-long beam distance of 820 yards with such compact size, which makes the light be a good choice for searching, hunting, fishing, camping, military, security and outdoors usages.
•Reverse polarity protection design to protect from improper battery installation.
•Aircraft-grade aluminum body.
•Toughened ultra-clear glass lens with anti-reflective coating.
•Operation: Single click the switch to turn the light on and off. With the light turns on, keep pressing the switch to cycle through Low, Middle and High. Double click to turn to Turbo from any mode. Another double click to get Strobe.
•Low power indication: When the battery power is less than 20%, the indicating light on the switch turns from blue to red. When the battery power is less than 10%, the red light on the switch will flash constantly, which means you need to replace or charge the batteries immediately.
•Dimension: 201mm*58mm*26.5mm.
•Weight: 240g (excluding battery).
•IPX-8 waterproof and 1.5m impact resistance.
•30 days worry-free money back; 2 years limited warranty for flashlight.
ACCESSORIES
•Spare O-ring x 2
•Side-switch cap x 1
•Instruction Manual x 1
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Edited by: robo819 on 08/19/2018 - 07:39
Ragsy
Ragsy's picture
Last seen: 1 hour 53 min ago
nice review, thanks
the style seems to be bucking the trend by going long and skinny and using 2× 18650’s – it’s like a throw back (sorry for the bad pun).
I reckon it will get a lot of interest
G'day mate, ow ya garn?
Yeah, nah good mate
robo819
robo819's picture
Ragsy wrote:
nice review, thanks
Thank you , and as always I am glad to do the reviews.
Yea I guess it is kind of going against the grain with all the smaller lights now days.
Personally I really like it though.
It is built a little leaner than most of my 2 cell throwers , maybe not a lot more than a few , but it IS a little more compact than 95% of the other 2 × 18650 lights I have , at least length and weight wise.
I also like the fact that the A4 has very similar output and throw to the Catapult V6 , but with 2 × 3400 mAh 18650 , I can get a little better run time with the A4 with 6800 mAh total using the 2 cells vs the single 26650 of the V6 and there is no real noticeable difference in the weight of the 2 lights holding them in hand.
I really like both the V6 and the A4 to be honest and as with me , I am sure others will make their mind to either get both if they like these lights , or they will choose the one that appeals to their personal taste more if they just want one or the other.
To give a little better idea what I am saying about the A4 being slightly leaner built , Here is the A4 side by side with my Convoy L4 in the single cell configuration…………
And with the L4 (left) in double cell configuration and the Maxtoch 2X on the right of the A4…………..
ChibiM
ChibiM's picture
Last seen: 4 min 7 sec ago
Didnt know their connection with Thrunite!
robo819
robo819's picture
Yea the “Technical support” Wowtac gets from ThruNite shows in a lot of the styling and very much so in the build quality of the lights that have came out so far from WowTac IMHO.
ChibiM
ChibiM's picture
It kinda surprised me. Many flashlights look a like (copied) so this information is new to me. Thanks for the review!
desmondkun
desmondkun's picture
Last seen: 14 min 7 sec ago
Wow!
Another interesting light. Good price too. Thumbs Up
Take care of your flashlight and your flashlight will take care of you.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 35 min ago
Very nice review, as always! Looks to be a great budget friendly Thrunite/WOWTac! Love the full round knurled battery tube and cap! Got to have a look at the driver, bet it’s the same as the CatV6 easy to boost, I’ll find out soon…. ordering one! Thumbs Up
Thanks Robo!
KB1428 “Live Life WOT
robo819
robo819's picture
KawiBoy1428 wrote:
Very nice review, as always! Looks to be a great budget friendly Thrunite/WOWTac! Love the full round knurled battery tube and cap! Got to have a look at the driver, bet it’s the same as the CatV6 easy to boost, I’ll find out soon…. ordering one! Thumbs Up Thanks Robo!
Thanks and your welcome Kawi.
I didn’t go for the driver just yet because the one on my sample is either well pressed in or glued. I wanted to use the A4 awhile before I take a chance on trying to remove and possibly ruining the stock driver and have to replace it……….lol
There is probably room for a slight increase on the driver. I am guessing from the tail amps , that the emitter is at around 1.8 amps or so as it came on mine.
Muto
Last seen: 6 hours 21 min ago
Now shows up at $39.95
Tempting
Notice the box shows an A5 listed, what is that going to be?
26650 single version maybe?
Thanks for the great review!
Later,
Keith
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Big Sky Country
robo819
robo819's picture
Tempting
Later,
Keith
Glad to do the review and thanks.
Yea I noticed today also the Amazon link has the A4 listed for the $39.95 , but I didn’t know if it was a typ-o or what.
Haven’t gotten any word on the A5 just yet , been hoping they will contact me soon about that one.
anycolourfloyd
Interesting looking light. What do you think the LED colour temp is?
robo819
robo819's picture
Mine is listed as CW but it is not as cool as many of the CW lights I have.
Just as a guess I would say around 5700K to maybe 6000K on the one I have.
firedome
Last seen: 4 months 1 week ago
Nice review, Thanks!
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
robo819
robo819's picture
Thank you …. and always glad to do the reviews.
EasyB
Last seen: 8 hours 34 min ago
Cool light. I love the simple styling and how compact it is with its minimal tail cap and shallow reflector.
It looks like a very nice affordable light as is, but I’m tempted to put a sliced XHP70.2 and FET driver in it. Evil
wolfdog1226
wolfdog1226's picture
Last seen: 10 months 1 week ago
Thanks for the great review again. Thumbs Up
It looks like a nice light,,,however[!],,it would not be my preference over my Cat[vn] V6.
-I am not a fan of BTB 18650 set up. I have big hands and do not like the skinny tube.
- It does not come w/ a holster. To some that is not a big deal. My Husky CAPO is with me every night. I bring 2 or 3 lights each night.I do not have a free hand as it is! I do not consider this a pocketable torch! Holsters are a must.
It seems identical to the CAT V6 in output. Nothing wrong with the light in that aspect. I am sure people who buy it will enjoy it.
As usual it all comes down to preference and freedom of choice.
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
RotorHead64
RotorHead64's picture
Last seen: 8 months 1 day ago
Great review thanks. Ordered one to gift.
robo819
robo819's picture
Yea I have been thinking what I might do later on with this one. As Wolfdog mentioned the output and beam is almost identical to the Cat V6 (which I have also) so no telling what possibilities might lay ahead if or when I decide to mod the A4.
robo819
robo819's picture
You are welcome Wolfdog and thanks also.
Yea I agree it will be a preference thing between the A4 and the V6. I am sure the V6 may have a little better following due to the shorter design and onboard charging though. If someone is looking mainly for run time then the A4 may win out on that point and the price , with it now listed for $39.95 on Amazon.
robo819
robo819's picture
Glad to do the reviews and thank you.
wolfdog1226
On a side note. I hope your friend and your Aunt heal quickly. Big Smile
My Dad wad 82 when he got quintuple bypass surgery and he was 85 when he broke his hip! His heart actually healed better than his hip!
The hip got infected and it took almost 6 months to fully heal.
EDIT:
I forgot to ask.
Does the A4 have a step down? If so when?
…..Thanks.
        WOLFDOG
robo819
robo819's picture
Thanks again.
Yea it gets harder and harder as we get older to get over things that took only a short time when we were younger.
wolfdog1226
Sorry!
Your efficiency was faster than my edit!
I forgot to ask.
        WOLFDOG
robo819
robo819's picture
wolfdog1226 wrote:
Sorry!
I forgot to ask.
I didn’t even think to check that when I was Testing , so I just went and checked…….it stepped down at 4 1/2 minutes to High mode and the hottest point I found with the laser thermometer was at 124 F.
wolfdog1226
robo819 wrote:
wolfdog1226 wrote:
Sorry!
I forgot to ask.
Thanks,,,,,,
Not bad,~ twice as long as V6 initial step down.
I wonder if it has a timed or thermal step down?
Also, what the successive step down times would be if I kept bumping it up like a good turbo freak that I am!
EDIT:
I have used the V6 for 35 minutes straight and constantly stepping back up every 60 to 90 seconds to turbo. Temps ~ 74 to 80F outside. Only turned it off once to change the battery!!
        WOLFDOG
robo819
robo819's picture
wolfdog1226 wrote:
robo819 wrote:
wolfdog1226 wrote:
Sorry!
I forgot to ask.
Thanks,,,,,,
I will try to check it later on and see what it does.
Got Ribs and Brisket on the pit right now and I have Chicken I have to start not long from now.
wolfdog1226
Sounds good,,,,,,,,,,both the food and your work! I am hungry now! LOL
        WOLFDOG
goryo
That’s informative review man thanks for it.
robo819
robo819's picture
Thanks and glad to do it.
robo819
robo819's picture
OK Wolfdog……….
I have done a few test between trips out to the pit…..lol
I am not sure if this Turbo step down has 2 different timers or if it has the first “timed” step down and then goes on a thermal step down.
The initial step down after letting the light cool stays at the 4 1/2 minute mark but , when you go right back to Turbo mode without letting the light cool down , it stepped down the next three times bumping right back into Turbo at 90 seconds , with the temperature on the outside of the head at hottest point being at the 134 F mark.
