Being spoiled to TK’s immaculate set-up, I have found the Sofirn ramping painful to use. Slow, enough different that it bothers my “purist sensibilities”
Sorry for not replying. I got my Imalent DT35 after 2 months waiting and it is DOA so I was upset and made videos and pictures.
I only copied the whole writing and modes what Sofirn sent to me so sorry if some errors they have. The last info about turbo is 3500 lumens. We will see what is the final when they list it on Aliexpress.
The battery is rated at 4000mah. Maybe it’s a Liitokala or Lishen under the wrapper? Those two are basically the same battery and a good choice. Has anyone heard details?
It’s a bit more expensive than I imagined at $41 $35 with no battery and $48 $41 with battery and charger.
Not really. D4S is $48 base model with the 219C or XP-G2 emitters and $66 with the XP-L Hi emitters. The C8F should be able to maintain output better than the D4S although the maximum brightness is lower. I see a $10 coupon at the aliexpress store so you can probably get it cheaper.
