What did you mod today?
9047 posts / 0 new
Swib
Last seen: 1 week 1 day ago
Ok that’s great news, thank you Dale. I just checked and have used Arctic Alumina two part adhesive. I’ll try your method and see what I can do. Do you think the noctigons will still be useful after?
If you don’t like what it looks like on the wall, take it outside.
Cereal_killer
Cereal_killer's picture
Last seen: 5 months 4 days ago
Finally got a day off and put it to good use!
Convoy s2+ w/ 2 channel red / white triple.
LEDs: 2x Nichia 219C 5000k, 1x Osram Olsen SSL80 deep red (657nm). Do note this is a 3030 LED and is VERY DIFFICULT to get it to float centered on XP pads during reflow)
Driver: hacked 105c
FW: BLF-A6, surprisingly [to me] not that modified at all.
Cut one trace on thr MTN MCPCB is all it takes to make the one individually addressable
Isolate a 7135
That soldering was easy, you can’t see the tiny wire from pin 5 to the single 7135 leg.
It needs some work still, I forgot to make the red channel come on during hidden turbo and I want to mod the levels some, maybe add a red/white strobe back in. Definitely gotta make the 6 mode group have a little higher R1 than it does now then crank R2 to max for a low/high red mode.
MRsDNF
MRsDNF's picture
Last seen: 2 hours 59 min ago
Yep. Thumbs Up
pinkpanda3310
pinkpanda3310's picture
Last seen: 10 hours 41 min ago
Very nice CK Thumbs Up
Cereal_killer
Thanks guys.
Wasn’t gonna post this one but gotta live and learn. Plus if at first you don’t succeed; spend more, spend more money. Or something like that I think.
Thankfully the 2 nichia bit it and the SSL80 was fine, it was the only one, the other Olsen I had was standard red and the deep red was one of my main wants in this light, otherwise I’d have just used a XP-E2 and not dealt with the crazy soldering.
MascaratumB
MascaratumB's picture
Last seen: 24 min 16 sec ago
Just for fun Big Smile Cool
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
NeutralFan
NeutralFan's picture
Last seen: 1 day 12 hours ago
Modded my cheapo Rayovac 3 AAA headlamp. I don’t use a headlamp that often, but when I do, it’s to work on something around the house in order to keep both hands free. Although I would love to get a nice ZebraLight floody headlamp, I can’t justify it since I wouldn’t use it much. The tint of the Rayovac headlamp isn’t bad for a cool white LED, and I like that it just has high and medium modes (no strobes).
The headlamp is also plenty bright, but I don’t like the narrowness of the beam. I’m constantly moving the headlamp up and down in order to get it in the position that I need. So I decided to replace the lens.
Taking it apart was very easy, just 3 screws holding it together. There are 2 O-rings, 1 for the battery cover and the other for the plastic lens. There was some type of thermal compound/adhesive on the back of the aluminum MCPCB, but my guess it was to hold the LED in place for assembly rather than for thermodynamics.
I thought about trying to make the Rayovac lens frosted, but it had a raised rim on both sides. So instead, I created a lens from some semi-transparent plastic I had. I used sandpaper to make 1 side frosted.
The final result turned out great. The headlamp now produces a much more useful flooded light.
I’d rather use my flashlight around the house than turn on the lights.
Agro
Agro's picture
Last seen: 2 min 28 sec ago
I solved the last of the problems with my first flashlight rebuild.
S2+ with TIR, shaved SST-40 and BLF-A6 driver.
The problem was soldering the driver to that damn pill.
I used a blowtorch this time and it worked.
Though I overheated the spring so it stopped being springy. And fell off.
Oh well, doesn’t matter for now, I soldered it back on.
I turn it on….nothing happens.
If I bypass the driver and connect a battery directly to the leads – ouch, my eyes hurt. So it must be the driver.
I tried to remove the pill and connect battery to it directly. I touched the pill and the driver with wires, saw a blink. Weird…
Back to the host, it’s still dead.
Again, checking the pill. When I connected it I saw some smoke from the point on the spring where I touched it with the wire.
Did I reverse polarity?
No.
OK, how should I troubleshoot it further?
DB Custom
DB Custom's picture
Last seen: 3 days 10 hours ago
You might have heated the driver so hot with the torch that other things flowed and shorted it out, or you may have just damaged components with the sheer amount of heat applied. Blowtorch and the fine components of a flashlight driver are a risky and tricky combination.
djozz
djozz's picture
Last seen: 1 hour 31 min ago
I have demolished several drivers trying to solder them to a pill with a blowtorch. After I bought a 80W (Antex) solder iron (also good for soldering wires to DTP boards inside cavities) my problems were over.
Agro
Agro's picture
OK, so the best thing to do now is cut the driver off the pill, unsolder the leads and do a visual inspection. Right?
DB Custom
DB Custom's picture
Perhaps a photo of this driver/pill assembly would help, maybe a few photo’s from different angles?
eas
eas's picture
Last seen: 4 months 1 week ago
Next time, before you put in the driver, tin the rim of the pill with solder. It’ll be a lot easier to solder the driver to it.
KawiBoy1428
KawiBoy1428's picture
Last seen: 7 hours 31 min ago
Been working on the TN42 XHP70.2 P2-1A. (crash test dummy) I think I got most of the resistance out of it. Big Smile Tested on a T/A’s Lumen Tube and calibrated with maukka’s lights.
4xVTC5D’s at 4.07volts. 8,840lms @ turn on.
4xVTC5D’s right off the charger, 4.21volts
9,230 lumen at turn on. I need more/better/ bigger heat sinking!!! Facepalm
I SWEAR I seen just over 11,000lm Blip off the meter for a Nano Second! Shocked
KB1428 “Live Life WOT
ImA4Wheelr
Last seen: 1 day 10 hours ago
Nice KawiBoy.  Looks like you are losing some lumens in your measurement around the bezel.  If you can lower the light a bit deeper into the tube, you will probably get a better measurement.  I think I read TA once saying that he lowers the light until he gets the highest reading.  I do the same thing now.
Cereal_killer
Fun soldering tonight!
That’s how much slack I was working with. All 22AWG silicone
Fady
Last seen: 1 year 8 months ago
Pretty cool! What driver is this?
MRsDNF
MRsDNF's picture
That looks downright scary Sk. Nice work. Beer
Cereal_killer
That’d be mine. If you happened to know that and you’re asking for specifics it’s my v3.0 constant current 4Ch driver in 17mm.
Cereal_killer
Omg, with the current FW offerings this old board is my new favorite 7135 driver!
Can be populated from a 105c and a otc.
Dual channel 1x / 7× 7135.
Runs popular FW including star moonlight special and (wait for it) BLF-A6 without mods.
Fits in Convoy S2+ pills, with non filed retaining ring!
Fady
Awesome!
KawiBoy1428
Yes, sitting on top of the ring is not ideal, and even with a tinfoil hat around it, and set inside I gained 400lm. It was mostly and experiment. I used some heavy solid core copper wire we use on our machines that I found laying around in the shop, and hand pounded and bent many pieces to connect the mcpcb to the Lexel T/A Infineon FETDD TN42 driver, to see if/what I would get. Well the pipe fitters have a term/word for it “Bones” many bones were made till I got the right length and bends in the leads to be able to solder the leads to the board or driver with out breaking the solder joints or ripping the contacts off either, and bolt the TN42 style driver up to the light. This heavy solid core wire is not manageable to say the least. I wasted a good brand new massive SD75 XHP70 board in the process. I just wished I would of done this in a light that had better sinking and fins on it. The TN42 is not the best choice, as in seconds this thing gets amazingly hot, the GT or SD75 would have been a better host, really stupid in the end on my choice with all the effort but it was a rainy weekend?. Big Smile
The carrier springs had 18awg Normal wire (silicone) bypass’s and the center positive contact was soldered directly to the carrier mcpcb, brass screws connecting the stanchions to the boards, with 4xVTC5D’s 2S2P it’s a potent power plant.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 5 hours 54 min ago
I am building an integrated sphere and have a problem.
My Luxmeter has a maximum value of 200 kLux, but my Imalent DX80 emitts more light.
Does anyone know how to mod a luxmeter, that it shows lower values. Can I add a resistor? How does it work? Has the sensor AC or DC Current?
Its a UNI-T UT383 BT.
DB Custom
DB Custom's picture
Diffuse the light. That will take some balancing to get it right but it will be easier and more reliable than tinkering with your meter.
Wieselflinkpro
Thank you, that was my second idea, but my favorite was to change something in my meter.
Now I added a DN25 electric installation tube with 6cm length, to put the sensor to the outside of the sphere. It lowers the readings by factor 10.
No 30.000 Lumen eqals around 50.000 Lux. This means my sphere can read around 100-120 kLumen. That may rest around 2 years to get such a flashlight, I think.
maukka
maukka's picture
Last seen: 49 min 14 sec ago
Measure a lower mode in the sphere and calculate the relative difference between that and higher modes in some other way (ceiling bounce for example). Or put a diffuser/neutral density filter in front of the lux meter. Or what you just did Smile
Wieselflinkpro
I have alread a Lumen-Box, but I noticed that the readings for over 10-15 k Lumen are too low. So Now I make further readings in the Toilette. But I wanted to get better readings for all output levels of a flashlight. For my Imalent DX80 and others like Olight X9R, Acebeam X80 and upcoming flashlights. Thats why I build the new integrated sphere.
And with diffusing the light before it hits the luxmeter, I will get good readings, I hope.
djozz
djozz's picture
If you want a very neat way to diffuse the light you can use a satellite sphere (which is indeed called a diffuser in the literature) where the luxmeter sensor used to be, and put the sensor in there (you even gain some integration). The sensitivity decrease can be set by the size of the connection hole: the inner surface area of the satellite sphere divided by the surface area of the connection hole gives you the decrease of the sensitivity.
(I made one sphere with diffusing satellite sphere: http://budgetlightforum.com/node/41217)
Cereal_killer
Last night I built up this old SK68 driver board from warhawk-AVG and then stacked it on the stripped driver board from a SolarStorm SC02 then flashed it with single mode (100% + hidden strobe) eswitch-13 FW from Tom_E then installed a Chinese no-name-brand XP size 365nm UV emitter that, other than a high vF performs very well and actually outputs a good amount of 365mn light (25mm ZWB2 filters on order from AE, does have a bit of visible light too).
This is one of the lights for my next GAW.
Power and GND connections between boards so only LED wires and the one switch wire are on top.
contactcr
Last seen: 40 min 18 sec ago
Looks good. How is the output relative to a FET triple?
