It canāt lock out.
In case I want to pack it in a bag and the sensor will switch it on:
Cut an isolation disc out of plastic.
(Any yoghurt cup will serve you)
Lollipop shape (make it 1cm longer than I did and round the tip), fold it so it stays in place while you screw the cap on. For normal use the disc is storred in the battery tube
I canāt find the off button when the thing is lit:
A marker out of blake tape aligns with the position on the bottom.
Nice ideasā¦ā¦ I too had trouble locating the off buttton. I took some gitd paint and made a dot on the black frameā¦ā¦. although even it can be hard to see when the light is on(which it always is when it needs to be turned off) :student: . I might try the black tape or maybe paint a āblack dotā on the globeā¦ā¦ the lockout is cool too! :+1:
I decided to try a white GITD paint dot on the white globe just above the switch.
I like itā¦. It shows up good when the light is on but is subtle when the light is off.
And it glows for a while after turning the light off. I plan on putting a coat of clear
fingernail polish on it to keep it in place.
