*BLF LT1 Lantern Project) (updated Nov,17,2020)
Toykeeper maybe forward that information to Barry so he can inform the engineers who are working on the lantern production prototype that it can be modified that way. I already sent them the LED pad 2-channel design for that part.
I got my right hand today hurt bad
But I can try to get it, hopefully the antibiotics wirk or they ha e to cut my right pointer ng finger open and I will be handicapped a lot longer
Problem is what is U3 for?
No files to start wirh so modding my Q8 driver
Lexel, DEL describes the driver board a little bit in post 736. After the images, at the bottom of the post, it tells what U3 is among other things. Here’s the relevant text:
From here:
U3 is a precision DC opamp and does the closed-loop current control for the LED driver (driving a meaty FET in linear mode). A sense resistor creates the feedback signal. The MCU (a venerable tiny85) generates the reference signal. Driver dropout should be < 150 mV, giving regulated control down to about 3.2 V.
U4 is an all-in-one power-bank chip from TI’s BQ24 or BQ25 series (currently looking at the BQ25895, it is also used in the higher end Xiaomi power banks).
That sucks Lexel. must be really frustrating. hope you get better soon.
DBSAR, did you had the time to measure the lens/globe/diffuser cup?
not yet, but will as soon as i can… ( been overloaded with errands & work the last week.
I’m interested in this - please add me to the list.
Same here Lexel. I hope it’s nothing serious.
I will be out of town for a few days without internet, until i return on Tuesday August, 28th. I will catch up then!
  • Den
cat bite seriously infercted if antibiotic dont help next days they have to cut my pointing finger open at the joint
ouch* hope it heals up soon for you.
I still have itchy spots which crust over then thicken and split open on my arm from a cat bite 5 years ago. Sounds worse than it is, but the point is don’t underestimate animal bites, some of the bacteria they can carry are nasty.
Ditto
What sort of people does Barry have working for him if they need to be spoon fed everything? Are they simply a build to print contract manufacturer that makes flashlights?
got so far today
power bank added tomorrow
alsom thought if the driver comes from production with 16 AMCs and they got solder bridge to configure more or less than 4
Lexel did in 2 hours what I couldn’t do in 2 months. Thanks so much for the help!!
Well, he has already been making a lot of driver designs, so he has plenty of starters to make this from. Changing a few things here and there doesn’t take very long. But, the point remains, and I agree - he’s awesome! Thanks from me too, Lexel!
Wow awesome work on this!
I like the idea of having solderable bridges for the 7135s, ( as in comes from the factory with 4-7135s in stock output level, but modders could easily bridge a trace to increast the output to 6 or 8 AMCs or less)
ill be in for one, since I seem to be BLF-afflicted
