What did you mod today?
what did you use for your centering ring?
A piece of acrylic, turned on the lathe. Itā€™s mostly for visual guidance during centering though, I only had a 16mm star where a 20mm would be the right size, so that was a bit tedious.
It doesnā€™t have to bear any load since the LED pill rests against the reflector flange.
It also helps keeping any dirt from getting inside.
My switch spring was a bit stiff and a bit long. Plus when I was testing out the light, I put the battery in through the head side and screwed in the head. I found that my flat top of my battery was crushed a little bit. I donā€™t think itā€™s something to be alarmed about but nevertheless itā€™s deformed a little bit, fortunately itā€™s only cosmetic. However, I can see if you have a long stiff spring on the tail side that it would be easy to crush the battery a little bit if youā€™re not careful.
I modded my Emisar D1S into a single-mode light! :person_facepalming:
Since I was reflashing AndĆŗril onto the GT mini that arrived today, I opened the D1S to update it, too.
I tested it before reinstalling the reflector, and all was well. After reassembling the front end, it wouldnā€™t power on.
It turns out my emitter board solder joints were slightly too large and positioned too far toward center. Both shorted against the reflector.
With the reflector removed, the light comes on when power is applied. I got it to ramp up and down slightly a couple of times, but itā€™s now a single-mode driver.
I hooked it back up to the PC and the ATtiny85 is still responsive. I reflashed AndĆŗril in case it was corrupted but that hasnā€™t helped.
It seems to be stuck at a moderate output level, not turbo.
Iā€™ve already emailed Hank asking how to order a replacement driver, but does anyone knows what component(s) Iā€™ve damaged?
Replace the FET. Itā€™s an Infineon Mosfet. BSC009NE2LS5IATMA1 Infineon Technologies | Discrete Semiconductor Products | DigiKey
Thanks, KB! :+1:
Looks like Iā€™ll be putting together a Digi-Key orderā€¦ :smiley:
EDIT: Or, maybe not. Theyā€™re on backorder at DK. Mouser too.
Do you live in the U.S? I have plenty of them!
You can use these too, just as good, and cheaperā€¦https://www.arrow.com/en/products/psmn1r7-25yldx/nexperia I have plenty of them tooā€¦ yeah I roast a few now and againā€¦
Itā€™s up to youā€¦. :wink:
Thatā€™s very nice of you, especially since I still owe you for the 70.2 MCPCB you sent me! :smiley:
I see that the FET you linked from Arrow is a ā€˜4-pin and tabā€™ layout.
Is that a suitable replacement for the 8-pin one on the Emisar driver? What orientation would I mount it in?
Iā€™m a bit in over my head as far as driver design and theory is concerned. :slight_smile:
Yes it works, solder across the back, Tab is ground. Same with the 4 pins in the rear of the Infineon, (underneath the FET) the large base is ground. It will all become clear when you remove the old FET.
Thanks, I removed the old FET and see what you mean.
I also readied a piece of 30 AWG Kynar wire to replace the trace that I ripped off of the board. :person_facepalming: Itā€™s the one that connects the pin 1 of the FET to R3 and R4.
Iā€™m trying my darnedest to kill this driver! Iā€™ll report back in a couple days when a new FET arrives. :slight_smile:
I reflowed Samsung LH351C emitters on my otherwise stock Emisar D4 with Nichia 219C LEDs that I managed to dedome from heat. I felt that my stock Nichia LEDs were tinted green. I thought that the Samsung LH351C would be better but they seem to have the same green tint maybe not quite as bad. Puts out 2400 lumens OTF at turn on, 2200 at 20 seconds, not very impressive and they seem to heat up just as quickly as the Nichia 219C, probably beacause of the lower forward voltage.
Do you have the original CRI80 219C or the later CRI90 219C model with reduced current?
The later 90CRI model.
What is the diameter of the D1S driver? Based on the picture, Iā€™m guessing 20-22 mm?
ToyKeeper states it is slightly over 22mm.
Thanks. If a replacement driver canā€™t be acquired from Hank, I think Iā€™ll consider TA 22mm driver.
Petzl Tikka XP
Luxeon RX0HW -> Cree XP-G3 S5 tc 5000k
^ wow, 4 times the output with an emitter swap!
Are those the 5000K 90CI LH351C emitters from Arrow? That is a disappointing first result from this led, at this current a lower performance than 219C and not a great tint.
Correct, it is those same emitters.
