The tube-in-tube design with just anodizing to insulate them never seemed wise.
A better way of doing it is how Liteflux did it in the LF2XT: Have 2 tubes - an inner aluminum tube nesting inside an insulating plastic tube. With 2 tubes, there is zero chance of wear causing a short. And the tubes do not need to be thick… very thin aluminum and plastic tubes should work fine.
If I understand correctly, yes, that is why proto2 wasn’t the final version.
It’s not a problem with the inner tube rubbing against the outer tube. The issue is the inner tube rubbing against the driver retaining ring. And to fix that, I think the gap between them has been widened.
The proto2 lights work fine after putting a strip of Kapton tape around the front end of the inner tube, but it shouldn’t need that. So a revised CAD model was sent, and is being produced.
FWIW, the prototypes so far are:
Proto0: Made by Fritz on his lathe.
Proto1: Made by Lumintop, had several issues to fix.
Proto2: Made by Lumintop, fixed all significant issues except one.
Proto3: Being made now.
Firmware is pretty stable, but I think Lumintop opted for the safer of two thermal options — the method which drops to the 8x7135 level at the slightest hint of overheating while the FET is active. Normal regulation is used below that level. Specifically:
Ramp level 1 to 65: No thermal regulation, not bright enough to need it.
Ramp level 66 to 130: Full thermal regulation.
Ramp level 131 to 150: Stays at requested level until overheating is detected, then smoothly drops to level 130. Will not attempt to regulate back up above level 130. This is basically a temperature-based step-down with a smooth edge.
With default settings, level 130 is the ramp ceiling. So every default level except turbo has thermal regulation, and turbo has a temperature-based step-down.
Additionally, there is some extremely paranoid thermal code in muggle mode:
Overheating shouldn’t be possible at muggle-mode levels, but if overheating is detected somehow, assume something has gone seriously wrong. Drop to the lowest muggle brightness.
I think the plan is to test proto3 whenever it arrives, confirm everything works, and then start production.
The user can calibrate the sensor and set a different temperature limit. The user can also change the ramp floor and ceiling levels. However, the level at which the thermal algorithm changes is hard-coded. Changing that requires reflashing the firmware.
ToyKeeper, is it possible to buy the driver and tail switch for this light by themselves? I’m interested in playing around with the electronics without waiting for the production lights to ship.
I will just hook it up at my bench. I’ve never played with a light with an electronic tail switch and a ramping driver, I’m curious to see how it works.
It will work like any other combination of driver with e-switch and ramping firmware. Having the e-switch in the tail is only special inside the flashlight. On the bench, it won’t be in the tail anymore, just a standard e-switch setup.
Now I know this has been briefly discussed already, but I really would like to ask for an optional deep carry clip.
I agree that it would look pretty out of place and weird, maybe even destroy the minimalist aesthetic, but for me it adds a lot to usability as an EDC light, and it’s still optional. The aesthetics of this light in regard to taper and finish seem to be fairly contested anyways. (BTW, has a final decision about finish been made already?)
Even if it costs far more than it’s production costs, I’d get one and I think most people appreciating deep carry would be willing to lay down 5 bucks or so for a decent clip. It also isn’t too hard to design, manufacture and doesn’t have to be fitted to the light for shipping.
(Also, as this would be an option that some really value and some don’t care about at all, maybe make it titanium and more expensive?)
Any arguments against this that I’ve missed? Would love to hear what you think about this.
Also, has Lumintop said anything about 2 emitter choices already?
One more suggestion @ToyKeeper: The beacon mode is pretty nice for having you remind you of tasks that you have to do periodically. However when N clicks corresponds to seconds, the maximum I’d bother to set is 30 seconds or so. How about a kind of timer, where you can set minutes as well?
Anyways, really appreciate all the work everyone is putting into this, thank you all so much :+1:
