The battery is rated at 4000mah. Maybe it’s a Liitokala or Lishen under the wrapper? Those two are basically the same battery and a good choice. Has anyone heard details?
It’s a bit more expensive than I imagined at $41 $35 with no battery and $48 $41 with battery and charger.
Not really. D4S is $48 base model with the 219C or XP-G2 emitters and $66 with the XP-L Hi emitters. The C8F should be able to maintain output better than the D4S although the maximum brightness is lower. I see a $10 coupon at the aliexpress store so you can probably get it cheaper.
They probably adjusted the price in anticipation of the upcoming AliExpress sale event. It shouldn’t be near the price of the Emisar D4S, in my opinion. For a few bucks more, most people here would go for the D4S. If Sofirn is smart, they should keep the price near the original C8F. I hope the host will become available soon.
With all the great features ofvthe D4S, it has TIR optics while I like a good reflector beam much better. So I think this light is in a different class.
I hope that they did the ramping well, at least with the Q8 they should have had a good example.
I don’t know why anybody would compare the C8F to the D4S. The C8F is slimmer, lighter, cheaper and has a reflector style beam pattern with a distinct hot spot and good spill lighting. The D4S does not interest me at all. ¯\/¯
Just like you, djozz, I am more partial to aluminum reflector than TIR optics. I know exactly what the C8F is and what it is not. My point is the $41 - $50 range is pretty crowded nowadays. Many good lights can be purchased (after an appropriate discount) at that price range. The thing is, most people here have already built or owned the original C8F. I for one, is not very keen on getting another C8F. Sure, I’ll buy the host, because I like assembling my own lights and I enjoyed building the last C8F.
Whoop whoop! “List price” for the 18650 version all over the place, depending on which specific listing you look at. I expect the semi-permenant “discount price” will look better.
I’m looking forward to being able to order a bare host.
C8F body is slimmer, but its head diameter is actually larger than D4S.
C8F’s weight is listed as 200g. D4S shipping weight is listed as 187g on Int’l Outdoors - I don’t know if that’s accurate. If so, actual light should weigh even less.
Both C8F and D4S are kind of in between a thrower and a flooder, but yeah, the D4S is going to be a bit more throwy overall.
Current pricing is such that both lights are not far off from each other. Now, if C8F goes on sale for closer to $30, then that’s going to make it significantly more attractive.
I currently don’t own either 21700 nor 26650 cells, so either light would require me to invest in new cell format. Not sure that I care either way.
I already have a C8F and aren’t in any hurry to buy the 21700 version. Looking at the power curves between 18650’s and 21700, quite a few of the curves are very similar, obviously with more capacity.
Once you get to the 15 amp range, the 21700’s do start to shine. I wonder what a FET would pull with 3 XP-L’s in it. The light looks the same, just a fatter tube for the larger cell, tail switch, and an illuminated side switch. Is that about it?
An e-switch tail switch? Outside of the FW3A which uses a double battery tube, I’ve never heard of such a thing. I assume it would have to be a mechanical switch.
If it does limit current, it should be easy to verify. It should also be easy to bypass the rear switch for max current. Then you would need to twist the tail cap for a mechanical lockout.
It’s also possible that Sofirn might offer a “flat” tail cap option later on. I haven’t heard any more about that, though.
