Golisi S6 Smart charger now is available for pre-order on Heavengift!
GOLISI S6 is a highly intelligent charger designed in response to customers who are in search of professional level of fast charging products.
Its UL certificated adapter supports fast charging when charge 3 batteries on the “2A” slots at the same time.
S6 is compatible with Ni-mh/ Ni-cd, and 3.6V/3.7V cylindrical rechargeable batteries of lengths ranging from 32mm to 70mm, such as 18650, 20700, 21700, 26650, 18500 etc.
Output current: Li-ion batteries– 2A x 3pcs on “2A” slots , 1A x 4~6pcs
Output: For li-ion batteries: 2A x1pc, 1A x 2pcs, 0.5A x 3~4pcs; other batteries: 0.5A
The “2A” slot supports 2A fast charging
Compatible batteries: 18650, 26650, 20700, 21700, AAA, AA, Ni-cd, Ni-md batteries.
Almost all cylindrical batteries batteries ranging 32~70mm in length and up to 32mm in diameter
Package: 99.9% packing materials are made of recyclable and biodegradable materials.
CE, RoHS, EMC, FCC, WEEE, LVD, ETL (cord) certificated
Golisi Needle 2 Smart USB Charger — Get it on Heavengift.com
The Golisi Needle 2 is a compact charger with 2 slots. It has a USB power port for 1A charge.
And it’s compatible with almost all types of cylinder-shaped rechargeable batteries. You can charge two batteries at the same time.
S32 Capacity: 3200mAh / 30A CDR, Max 40A/ 3.7V
Safety protection: Based on UL1642 standard, no leaking or explosion in extreme tests of over–charging, short circuit, over discharging, high temperature
Capacity:2600mah, constant discharging: 25a. real rates
Certificates: CE, ROHS, FCC, MSDS, WEEE, UN38.3, IEC62133, drop test, sea / air shipping safetly report
Mooch bench test: Click here
Vaping mods recommend: Geekvape aegis, Geekvape Ahena squonk ,Wismec DNA200, Sigelei Spectrum
