6. Batch "TA" 1S or 2S Bistro HD OTSM/NarsilM drivers 15-47.5mm size fit, S2+, C8, H03, MF01, MT03, Q8 Clicky or E-switch
It is described in post 4. I’ll post it here.
Led + comes from battery spring, not a pad.
Thanks JasonWW,Lexel ! Restored my L6
Hi Lexel, will you be making a 17mmmm or 20mm boost drivers for clicky switch lights too? I have a convoy L2 host that I want to run an XHP35 HI on at least 2.5A Turbo, maybe 1.5A sustained high mode.
Hello. I am pretty new to modding lights but have the basic skill set necessary. I want to put a FET driver with NarsilM on my Convoy L6. What will I need exactly? I want one 30mm driver (L6 size right?) with NarsilM and the Low Voltage Protection. That’s 15.5 $ correct? Plus 5$ for shipping tracked and insured. How about springs and wires? What’s the best option for me? Thank you.
It may be a little while before you get a response. Lexel posted elsewhere that he’s having hand surgery done.
If he hasn’t answered yet, you basically have the right idea. 30mm. $15.50 sounds about right. You can reuse the existing led wires if you want or buy extra. You can get a spring if you want or swap the old spring over. He should send you a PM asking for your details and based on your options give you an exact price.
The main thing you need to figure out is what you want as a turn on response. Most NarsilM drivers do two low blinks. You can choose nothing or you can choose turbo. Choosing turbo let’s you use the rear switch to turn on turbo, then you would have to ramp it down or click the side switch.
You can get the standard lvp point and thermal stepdown point. You can reset the thermal stepdown at any time.
Yeah. I saw that last night. That’s ok. I can wait a bit more. Let’s hope everything goes well with him. Thanks.
Thanks Jason. I think I don’t want a instant turbo on when pressing the tail switch. Would annoy me too much. I wanna do a backlight switch mod after it and want to have the ability to lock and unlock the light without being blinded with 7000 lumens everytime.
I wanna swap a xhp70.2 as well but do you think it would be ok to use the stock xhp70 with the lexel driver? Just until I can get my hands on the updated version.
It sounds like you want the main led to do nothing (NO) at turn on. Only your switch lights will come on. That’s how my mini L6 is. It’s a good setup.
You can either add some leds to the stock switch or have Lexel make you a switch with leds on it.
You can use the stock emitter. Simon uses a DTP mcpcb for the L6. With good batteries it should pull about 12A or so. IIRC.
Ooh yes! That’s what I want. Just the light switch turning on. Also asking for a new switch with the leds already on it it’s a neat idea. I really don’t wanna buy a roll of 100 leds. Lol. Do you reckon how much would he charge for a switch with 2 red leds on it?
I thought Lexel’s noble work is temporarily halted or on hold for the time being? The man is going through surgery and we wish him well and fast recovery.
It is. I was made aware of this yesterday night. But it’s ok. I am in no hurry. My L6 is my test subject, if everything goes well I have so many other lights I wanna mod. Next in line is my MF02.
If you want to buy a driver in the meantime, maybe Texas Ace has something for you.
Same here. I would like to order, too.
You don’t have to buy a roll of leds, there are small kits with different colors, like sampler kits, you can buy. The only down side is it comes from China, so it might take 2+ weeks for them to get in.
Lexels L6 switch costs about $3 USD and can have 4 leds on it. Each led has it’s own resistor and he can match the values so all the colors are the same brightness.
Here are some pictures I got from F.i.l.a.s. These are the only pictures I’ve ever seen of his L6 switch. It’s kind of new thing and not well known yet.
You just run one power wire for the leds, one power wire for the switch and one ground wire to it.
Wow 3$. Almost feels like a steal! Hahaha. Yes I am very interested. As long as it feels the same quality as the Stock L6 switch I’ll be definitely getting one of those. Thanks Jason
The problem with Texas Ace is that he ships it from the US. Shipping will be more expensive than the driver it self. I was looking at MTN Electronics and they have the L6 driver even a bit cheaper but shipping alone was 16$. It’s not worth it.
Oh sorry forgot you were from Brazil.
I would just order a driver from Simon itself then.
I want a FET driver with NarsilM. Simon doesn’t make those unfortunately.
Hmmmm.
This is problematic indeed.
