What kind of jst connector are you using exactly? What is it’s maximum width ignoring any notches on the side (can be sanded off)?
I need to know what diameter hole in the (C8TT) head is needed to fit it through as I assume that you will offer preassembled drivers with wires.
led4power
(led4power)
August 21, 2018, 6:24pm
602
JST SH connector. You need 5.5mm or better 6mm hole.
led4power:
Shorts specs:
*0.7mOhm FET, bottom pcb and fet drain is soldered directly to brass case, this eliminates additional contact resistances (those can be higher than FET resistance itself) which are present in classical PCB-retainer tailcap
*ultra-capacitor as auxiliary supply - practically unlimited life,reliable,fast charge, no need to replace it unlike coin batteries
*0-600uA Constant current channel for illumination LEDs
*Press-button momentary switch
*Configuration mode - adjustable illumination brightness, switch UI style, lockout, short-long time threshold set, factory reset.
Switch style 1 works like this: short click changes mode (short-long time threshold can be adjusted in config. mode,default is 0.4sec), long click turns flashlight off. From off, flashlight is turned on at switch press.
Switch style 2 works in the opposite way, short click is on-off, long click cycles through modes.
Entering into config. mode is done by holding switch from off for few sec and entering password after that, config. mode is very similar to LD-x4 config. mode, with table based menu/sub-menu.
For now I plan to have versions for Convoy S, M, C8 lights (with rubber tailcap), and EE X6 lights, also can be other lights which have compatible Convoy/X6 tailcap parts.
I can make custom versions for some other lights if there is enough interest.
Style 2 ui is gonna work great for me. This is amazing stuff. I’m definitely taking one so my shopping cart is parked for now on your site.
led4power
(led4power)
August 24, 2018, 7:54am
604
Got some 6x optics, problem with 7x ANNA is that central optics must be shorted by few mm by drilling or similar tools to make room for wires.
Also yesterday tried this C8 with DD on high option enabled, just to see what is max. practical output.
Luxmeter with CC @18A showed 380lux at start, with DD on high enabled output increased to 450lux at start, or about 6000lm OTF. Not bad for 90CRI.
This means max. current is about ~24-25A with VTC5A. Light heats up noticeably faster vs. CC @18A.
Hopefully I can mod your parts for Manta Ray C8.2.
I am waiting for some parts in your shop, such as Luxeon V 90CRI, C8 Spacer, possibly fitting Momentary Tailcap-Switch and so on.
When did you think, you will get the Luxeon V 90CRI?
led4power
(led4power)
August 24, 2018, 11:27am
606
You mean Luxeon MZ 90CRI? Luxeon V is still not released in 90CRI.
For now I will only have spacers and tailcaps for Convoy C8 and EE X6, next possible candidate is Sofirn C8F 21700 host.
led4power:
Luxmeter with CC `18A showed 380lux at start, with DD on high enabled output increased to 450lux at start, or about 6000lm OTF. Not bad for 90CRI.
This means max. current is about ~24-25A with VTC5A. Light heats up noticeably faster vs. CC `18A.
It looks much better than with empty optics. Will it be available in your store?
And what will be the price for spacer for C8?
led4power
(led4power)
August 27, 2018, 7:50am
609
I will offer 6x ANNA within C8 DIY kits for now, I have limited number of them. Price of spacer is yet to be determined, I will have first batch this week.
Buoyen
(Buoyen)
August 30, 2018, 6:29pm
610
The LD-B4HV. Can someone tell me what the different connection points in this image are: Capture hosted at ImgBB — ImgBB
+ battery power is on the back side
battery power is on the edge (I)
A is + LED, B is - LED and C is gate?
This driver should turn on when connected to power (without switch) ?
contactcr
(contactcr)
August 30, 2018, 6:45pm
611
The last page of this PDF has what you need:
Buoyen
(Buoyen)
August 30, 2018, 6:52pm
612
Ok, wasn’t sure since that is not exactly the same driver.
But then I guess my A is A in the datasheet (LED +). My B is S in the datasheet (LED - ). My C is G in the datasheet (gate) like I thought.
Thank you!
contactcr
(contactcr)
August 30, 2018, 6:56pm
613
Buoyen:
Thank you!
I glanced at your picture but there are indeed a few differences mentioned on the product page as well. Maybe it’s best to wait for LED4Power to confirm.
led4power
(led4power)
August 31, 2018, 6:12am
614
Buoyen, I sent you answer over email.
Hi Neven, can you already estimate when the new e-switch driver for Convoy C8F 21700 will be ready for sale?
Best regards, Thomas
led4power
(led4power)
September 1, 2018, 9:09am
617
Hm, I didn't mention any e-switch driver for C8F? Do you mean subZero FET switch for C8 (which uses e-switch)?
The_Driver1
(The_Driver)
September 1, 2018, 10:01am
618
When will the following things be available:
- 30A driver
- Luxeon MZ LEDs on PCB
led4power
(led4power)
September 1, 2018, 5:00pm
619
MZ leds - next week 100%
-18,24,30Amp drivers, FET switch,spacers - next week 95%
F.i.l.a.s
(F.i.l.a.s)
September 1, 2018, 5:04pm
620
What driver do you recommend for C8, 1x Luxeon MZ, Fet switch?
