surprisingly, to me, the 16340 protected and unprotected are the same length (in inches), or 0.25 mm longer for protected.
The 18350 difference is much greater (IF the linked specs are accurate)
This store is currently shipping the Keeppower UH1835P to Brazil and I imagine other countries where shipping is often unavailable, I’ve bought keeppwers from them before (currently unwrapped and returned to unprotected panny-B state)
These cells are now in stock from nkon.nl, a highly reputable European vendor (no affiliation).
They do however state that the cells are 39 mm long. Which makes me wonder if they’ll fit properly in my Emisar D4?
The springs should have enough play, but I’ll hold my order until I at least get home and try to cram a measured battery with a spacer in there!
Or can anyone verify that these cells will work in a D4?
HKJ states 35 mm though, and “highly reputable” is the least of his accolades. But different batches, different specs? Fake cells? Or just misspelled on nkon?
I’ll be back with a solution to the conundrum when I have it, unless solved by another.
Nice cells, allowing small lights with multiple emitters to shine, the closely resemble the Vapcell 18350 purple.
Still, the Aspire cells were even better but extremely hard to gome by………
The Aspire, Vapcell, and this Keeppower are same cell, all made by the same factory. Yongdeli New Energy Battery. Tony, the owner of Aspire E-Cig is part owner in the battery factory. At least he was a year ago.
I have now received my five batteries. They are indeed about 35 mm long.
The measurement of 39 mm corresponds to Keeppowers protected 18350 cells, so the error was probably made by looking at the wrong specs, but has since been corrected.
The cells arrived in retail boxes of two, including a case for two 18350 or 18500. With a bit of cutting they can be made to fit three 18350s though! (And the fifth cell came in another of the same case, even though I ordered several other cases, one of which was used to package the two HG2s I also bought).
Furthermore, the Keeppower case for one 18650, which is apparently made with protected cells in mind, can just about fit two of these cells, with a very thin insulator! With a little bit of cutting it should be possible to fit a somewhat thicker piece of plastic in between, making it a very compact case for the job!
No, I’m more after a “spacer”, or something to hold the cells in place, as the case is on the large side and they will rattle and move if there’s only one in there. Yes, “insulator” may have been a bad choice of word, but it was natural in the circumstance.
I ordered two of Keepower (UH1835P) cells on May 2021 from a different Aliexpress seller. The cells looks different from HKJ’s review and appears to be the same as the one sold on Convoy store.
Both of my cells show very high self-discharge rate. One lost 0.20v from full in 26 days and the other in 20 days. I am not sure if these cells generally show very high self-discharge rate, but I have not yet come by other information that shows otherwise.
However, the cells seem to pump the high current it claims.
Barkuti, good to see you on here again. I have a couple of those that I got a year or so ago from either Illumn or Liion Wholesale here in the US…looks like the same cell (same model, same button). I have not see the self discharge in my pair that Limsup did. I don’t use them a lot but have been impressed with what they can deliver. I only have maybe 8 or 9 cycles on them so I can’t offer anything there.
For the love of God, for the love of God… That you are saying there is terrible.
Long ago I once tested a bunch of old laptop pack scavenged 18650s for self discharge, leaving them to rest for a couple weeks after being charged in parallel to a non-stressful voltage level (can't recall the exact figure, but fairly sure it was between 3.8 and 3.9 V). Some of the cells in that laptop pack were initially found slightly below 2 V, and besides a capacity check I did that self-discharge test to determine which cells to discard. I discarded a couple cells which lost very few mV, keeping only the ones whose voltage was rock solid set at the initial value.
I do not expect any decent quality li-ion cell to lose any significant amount of energy from self discharge, that is the reason I think what you say is really piss poor performance. Comparatively speaking, low self-discharge NiMH cells do a lot better than that!
Hello :-) Correllux. Yes, I do no longer post here very often; I don't feel the need and I certainly have much more imperative things to spend my time at now.
Its nice to hear that their discharge performance is good, but I have binned cells with much less self-discharge rate if I am to take Limsup's figures seriously… I certainly do not want to buy cells like that.
So, could you make a test for me? Correllux or whoever is willing to who purchased the cells from a reliable provider (I really hope Simon gets top quality cells). A simple test like charging a cell or cells to 3.8 - 3.9 V, measuring their voltage at rest and noting it down, and a week later repeating this last step. One week of wait time can be enough to check if there is any discernible loss of voltage and energy in the cells.
I can probably do that but it might have to wait until this weekend. I don’t have a bench supply so I’ll have to eyeball the display on my MiBoxer and pull them. I’ll try a 0.2C charge and take voltage right off the charger and after an hour…unless you’d like some specific procedure.
0.2C charge? That's 220 (200?) mA for a ≈1100 mAh capacity cell, which model of MiBoxer do you have? This is slightly off topic, but the second channel in my Lii-500 suffered a malfunction months ago and ended up literally cooking one of my AAA Ni-MHs, as it didn't terminate and kept pumping the full current until I stopped it many hours later. The cell ended up so hot that its wrap melted and there was plastic debris over the positive terminal of the charger. :FACEPALM:
It does not really matter which device you use to charge the cells, so eyeballing the charging voltage in your MiBoxer is fine; just let it charge the cells until you see ≈3.9+ V on its display. Since the voltage is measured somewhere in the charger's PCB, the voltage at the cell terminals will be slightly lower because charging current times rail and contacts resistance is a voltage difference. So, you will measure slightly lower voltage at the cell terminals once removed from the charger. I suppose you have some decent multimeter. O:)
Measuring the resting voltage after an hour or a little more off the charger is adequate. Thanks.
Ouch about the melted wrap on your cell! I watch my NiMH cells carefully…actually just recently started to use a slightly higher charge current for them than I traditionally have. I usually use the Maha for those, though, but the MiBoxer seems to do ok. I have the first version of the C4-12 that had the single grey button (the second version had two yellow buttons). I’ve been really satisfied with it other than the IR readings (typical, though) and I don’t usually let it run automatic since it likes to choose high currents if the cell’s IR is low. I’d buy another if MiBoxer were still in the charger business…I’m hoping the new Vapcell S4+ will have improvements and take 26800 cells.
This charger will let you select 200, 300, 500….on up. I think it might even do 100 on li-ion but maybe not (it will for NiMH though). Pretty versatile. Yes, I do have a decent meter that I trust for 1/100th of volts…lately I use it more than my others. It’s the Brymen-made EEVBlog unit from a few years ago. Nice features and more accuracy than I usually need…well suited for general electrician and automotive use and enough features/quality to handle the majority of hobby and electronics uses.
I put the cells on my desk at home so I won’t forget about this.
