Texas_Ace
(Texas_Ace)
August 4, 2018, 9:19pm
58
talking about the time until the LED is dead or battery life?
The LED life itself is generally far longer then any of us will use a flashlight so it is not something many of us worry about.
Battery life will be less with the XHP70.2 of course since it uses more power.
LichtAn
(LichtAn)
August 5, 2018, 10:34am
59
Someone with a CNC mill could make a nice custom watercooling block from copper.
JasonWW
(JasonWW)
August 5, 2018, 10:51am
60
You don’t need all that. I brazed one together from copper using an oxy-acetylene torch 17 or 18 years ago, back before you could buy them. Heck, for the last 15 years now you could just buy a copper water block. Get a bucket of water, put a little antifreeze in it to block algae growth, drop in a submersible pump and away you go. Keep the flow rate high and it will take a very long time before the reservoir starts to warm up. Almost completely silent as well.
LichtAn
(LichtAn)
August 24, 2018, 5:28pm
61
Guys what’s the best XHP70.2 emitter for ending up with a nice neutral white without much tint shift after dedoming ?
Texas_Ace
(Texas_Ace)
August 24, 2018, 5:31pm
62
I have yet to find an XHP70.2 that does not have significant tint shift with dedoming.
To end up with a NW tint after the de-dome always ends up with a green tint shift in my experience.
I don’t even mess with de-doming them anymore on my own lights.
LichtAn
(LichtAn)
August 24, 2018, 5:43pm
63
Texas_Ace:
OK, this sounds really serious.
Without dedoming the CRI90 emitters seem to be the best choice right? Or do they all have the same shift pretty much?
If you want a good tint after de-doming you need to use a very reddish tint (under the BBL) before de-doming.
To reduce the greenish/yellowish corona you need to remove all excess Phosphor after de-doming.
Texas_Ace
(Texas_Ace)
August 24, 2018, 5:53pm
65
The only 90CRI XHP70.2’s I have seen were warm white ~3000k. Have you seen cooler 90cri LED’s?
Even the 80cri is 4000k. The 4000k 80cri does minimize the green tint shift my is still gets pretty warm / yellow.
It really depends on if you are sensitive to green / yellow hues. I am very sensitive so I don’t bother with de-doming. Others do not mind at all.
LichtAn
(LichtAn)
August 24, 2018, 6:06pm
66
The_Driver:
If want a good tint after de-doming you need to use a very reddish tint (under the BBL) before de-doming.
3A/3D for 5000K according to https://www.cree.com/led-components/media/documents/ds-XHP702.pdf right? Is this completely independent of the CRI value?
Texas_Ace
(Texas_Ace)
August 24, 2018, 6:14pm
67
Yeah, it has nothing to do with the CRI.
An A or D tint is best for sure but The ones I have tried still went a bit green, just less then some other tints.
LichtAn
(LichtAn)
August 24, 2018, 6:15pm
68
OK thanks. I’ll try to get some of these. 13$ at fasttech…wow
2R and 2U would be even better.
LichtAn
(LichtAn)
September 29, 2018, 8:49pm
70
I read somewhere that after slicing the dome, you should remove the rest of the silicone surrounding the die to reduce the tint shift in the corona. Can’t remember where I read that though. Does that make sense?,
Texas_Ace
(Texas_Ace)
September 29, 2018, 9:02pm
71
LichtAn:
That was KB that said that and it does seem to work for him, although I think he said that is also can tint shift cooler around the edges after doing that just to a much lesser extent?
Overall that is only for the very advanced modders among us.
LichtAn
(LichtAn)
September 30, 2018, 9:34am
72
Texas_Ace:
LichtAn:
Because of the precision needed or what do you mean? What if I remove in safe regions and leave a bit of safety margin?
Texas_Ace
(Texas_Ace)
September 30, 2018, 3:37pm
73
Yeah, it is very easy to mess it up and kill the LED. Removing only some of the phosphor next to the die I don’t think would be worth it but I have not tried it myself.
You can always try it and see what you think.
LichtAn
(LichtAn)
September 30, 2018, 5:41pm
74
Guess I’m in the for the risk, as soon as everthing arrives. At the end of the day, it’s just a dead emitter. :money_mouth_face:
Texas_Ace:
Era of dedoming and slicing will be over sooner than you think guys :+1:
LichtAn
(LichtAn)
October 2, 2018, 6:49am
76
So what’s the upcoming Era about? Glueing silicone domes on domeless LEDs?
