@ BlueSwordM and fixed it, thanks for the explanations. I definitely have noticed that LEDs get way less lumens/mA (or lumens/W) when they are driven very hard. But I was under the belief (perhaps, or likely wrong) that at lower drive currents, the lumens/mA curve was pretty constant. So with 4 LEDs each drawing 350mA (fairly low current) the efficiency of the 4 7135s can be no worse than the efficiency of a single FET. But at lower currents, if the switching performance of the 7135 is lousy (sounds like a great BLF improvement project!!) then I can see where the efficiency of the single FET would be better.
Me thinks so
The_Driver: The_Driver:Why not a MOSFET based linear driver with higher efficiency in the low modes like the LD4 and texas commander drivers?
Nobody thinks this is a good idea? Less components and higher efficiency.
Someone has to design it. Designing parts of this lantern has been slow sofar, only now even the driver takes final form and I believe it is nice that it is being done at all and that it will have nice options and firmware. And an even more efficient driver without PWM like you suggest (I agree that for a relatively low-powered light like the lantern a FET-based lineair driver would be a suitable application) would require lots of extra expertise and time. Apart from that, I wonder if you could get output and tint ramping done without old-school PWM?
Isn’t Texas Commander the right driver?
please put me on the list for one…
djozz: The_Driver: The_Driver:Why not a MOSFET based linear driver with higher efficiency in the low modes like the LD4 and texas commander drivers?
We need a dual channel version of that.
unsubscribed
I have less interest in Lumintop than they have in their customers
Huh? Lumintop isn’t building the lights, it’s Sofirn actually.
Then I’m happy and disregard my Lumintop warning.
unsubscribed
I don’t know what Lumintop did to offend you, but it would be great if you could stop spamming every single thread. If you have something to say, make your own thread and say it.
Kingjohn added to the interest list at number 957
first request was just 2x4AMC driver
added Powerbank stuff
CC regulated MOSFETS
7135s removed
CC regulated without PWM added
LDOmadded
indicator Led removed for voltage divider
7135s removed
LDOmadded
Wow. I’m up for that one!
Looks like the surgery didn’t slow you down? Very impressive. Thanks for your all your efforts!
Nice! Thanks Lexel!
WOW :+1:
Nice job, Lexel! Thanks!
If I could buy these guys a beer I would buy them a bar. Thank you all for making this come true!
Lexel, what is the lowest possible current with that FET driver?
its one Channel PWM and should not suffer from low PWM cycle like AMCs are so 0.4%
I am not sure which current we get with lowered MCU voltage
from 5V as DELs driver was designed, here we got 2.8V we should get about 60%
Not sure which current he calculated, need to be tested
Sign me up.
Do we have any price estimations?
