Hotrod headlamp
38 posts / 0 new
lohtse
lohtse's picture
very interested where this goes…
Caving, Climbing, Mountaineering, Kayaking, Diving etc any time anywhere!!! If you in the UK let me know and lets Play!
Current lighting
Olight X7R,M2R,S1 Baton,S10R Baton 3m,S2R 2, I1R EOS,SofirnC8T,Lenser P7'2,Lenser P14,BLF A6,Fenix HL50,HM50R,HL55,CL05,HL05,CL09,CL25,Nitecore HC30,HC65,NU12,NU32,Astolux K1,Petzl E-light,Tikka Xp3,XP3LED,DUO,Atomlight,Xtar Warboys H3,PL47 Manker E03H and many Chinese ones
pinkpanda3310
pinkpanda3310's picture
Last seen: 3 days 12 hours ago
I attempted to change the optic since that was pretty easy right…. riiiight. The only other triple optic I had was one that was supplied with a triple led on star from kaidomain.
It didn’t fit and at first I thought it was because of the different diameter (thicker) legs
After dremeling down the legs I then I discovered it was also a different height Facepalm
I think the led holes are also a different diameter
So it looks like this will be staying as a super flooder.
RotorHead64
RotorHead64's picture
Last seen: 9 months 3 weeks ago
Nice work man. Cool stuff!
So how does the kaidomain optic compare to the carclo in terms of beam profile? Not talking about this particular light just wondering if you’ve checked and compared before.
chops728
What optic do you have —- I have had great success with sanding (1000 grit) and polishing the 10511 optic—when sanding kind of use your finger tip in the center—the optic is slightly dimpled in the center
pinkpanda3310
I just recently got the kd optics and haven’t tried them at all so I can’t say.
That would be an option I would try if I had a spare. Not keen on screwing it up and waiting a few weeks for the next order to come in Sick
Niko
Last seen: 2 days 21 hours ago
My opinion, you glued driver on wrong side. This not have sense.
Upside will coolnig fet and better read temperature.
Nice crazy design Smile
Lexel
Lexel's picture
Last seen: 6 min 12 sec ago
actually the fet laughs at currents like 10A, 140mW loss
AMCs generate more heat
also temp stepdown with long heat path on lower modes will be closer to case temp
turbo will be higher
