13638 posts / 0 new
Eraursls1984
delusional wrote:
My imagination says that what’s causing the delay is heat management. They gotta keep this thing from being a self-torching-torch, leaving scorch marks on everything it touches, and occasionally burning down someone’s house. No joke. It will be powerful enough to start fires under the right conditions. The overheat protection must be reliability tested to a high degree. Sick
If they can keep the heat genie in the bottle, the light will be as popular as the A6, if not more. …And that’s another reason for Lumintop to be extra cautious. If they get it right it’s a giant feather in their cap, and thousands of flashlight enthusiasts recommend Lumintop to others… If they screw it up, it’s a Buster Douglas hit to their reputation, difficult to recover from. It’s kinda make-or-break for them.
Furthermore… I’m pretty sure this is Lumintop’s first light with a triple-star. I’m sure they wanted to do this eventually, but we are pushing them into new territory.
Heat is the only thing stopping me from adding several units to my order. I want to see how safe it is, in the real world.
In the meantime, Lumintop is entirely correct to take as much time as they deem necessary to complete this project in a safe manner.
P.S. I wouldn’t be surprised if they cannot hit the price point mentioned in post #1.
If that’s the case they could just crank the thermal regulation all the way down from the factory.
cabfrank
Last seen: 10 hours 16 min ago
I like your Buster Douglas reference. I think they will hit the target price, or get real close, because there is also the Emisar quad to compete with.
gottawearshades
Last seen: 1 day 16 hours ago
Still optimistic.
If this light happens, I would buy a second one.
PS: This thread, and the BLF lantern thread, make fascinating reading—smart people putting their heads together and working for no reward at the end but a flashlight they still have to buy. I admire the work y’all are putting in on this.
JasonWW
JasonWW's picture
Last seen: 30 min 50 sec ago
gottawearshades wrote:
Still optimistic.
What do you mean? Of course it will happen.
I would not listen to Delusional’s post. I think he’s wrong about the heat causing a delay. Lumintop is not even in charge of that area. The thermal management is programed by ToyKeeper and she has that under control. Plus it’s user adjustable. You can adjust it to heat up more or less depending on your needs.
I think he’s also wrong about it hurting Lumintops reputation if they get something about the light wrong. They will catch it and it will be corrected. Should be no big deal.
Prices are not fixed yet, but since we are this far along and they still think they can sell it for $30, I don’t see any reason why it would go up. It’s a small light so shipping costs should already be known. I can’t think of any other factors to make the price go up.
TheShadowGuy
ToyKeeper wrote:
If it were up to me, I’d make the next one a single-emitter model with 18350 or 16340. Basically a clone of the Olight S-Mini, with better emitter choices and fancier firmware.
I would love an S-Mini with better emitter choices and firmware! Love
gottawearshades
Point taken. I suck at optimism. It’s my Russian soul.
Still optimistic.
nvanlaar
nvanlaar's picture
Last seen: 5 days 18 hours ago
I think the delay is getting the tube-in-tube durability figured out. Is there a reason they don’t just epoxy the tube inside the other tube so there is no movement or chance for wear between the two causing shorts? Do we need the inner tube to come out for any reason other than the cool factor?
“Facts don’t care about your feelings.”
~Ben Shapiro
Firelight2
Firelight2's picture
Last seen: 1 hour 56 min ago
The tube-in-tube design with just anodizing to insulate them never seemed wise.
A better way of doing it is how Liteflux did it in the LF2XT: Have 2 tubes – an inner aluminum tube nesting inside an insulating plastic tube. With 2 tubes, there is zero chance of wear causing a short. And the tubes do not need to be thick… very thin aluminum and plastic tubes should work fine.
ToyKeeper
ToyKeeper's picture
Last seen: 11 hours 4 min ago
If I understand correctly, yes, that is why proto2 wasn’t the final version.
It’s not a problem with the inner tube rubbing against the outer tube. The issue is the inner tube rubbing against the driver retaining ring. And to fix that, I think the gap between them has been widened.
The proto2 lights work fine after putting a strip of Kapton tape around the front end of the inner tube, but it shouldn’t need that. So a revised CAD model was sent, and is being produced.
FWIW, the prototypes so far are:
  • Proto0: Made by Fritz on his lathe.
  • Proto1: Made by Lumintop, had several issues to fix.
  • Proto2: Made by Lumintop, fixed all significant issues except one.
  • Proto3: Being made now.
Firmware is pretty stable, but I think Lumintop opted for the safer of two thermal options — the method which drops to the 8×7135 level at the slightest hint of overheating while the FET is active. Normal regulation is used below that level. Specifically:
  • Ramp level 1 to 65: No thermal regulation, not bright enough to need it.
  • Ramp level 66 to 130: Full thermal regulation.
  • Ramp level 131 to 150: Stays at requested level until overheating is detected, then smoothly drops to level 130. Will not attempt to regulate back up above level 130. This is basically a temperature-based step-down with a smooth edge.
With default settings, level 130 is the ramp ceiling. So every default level except turbo has thermal regulation, and turbo has a temperature-based step-down.
Additionally, there is some extremely paranoid thermal code in muggle mode:
  • Overheating shouldn’t be possible at muggle-mode levels, but if overheating is detected somehow, assume something has gone seriously wrong. Drop to the lowest muggle brightness.
I think the plan is to test proto3 whenever it arrives, confirm everything works, and then start production.
Firelight2
Awesome! Thanks for the update ToyKeeper. Thumbs Up
d_t_a
Last seen: 12 hours 12 min ago
Great to hear those, especially the detailed info about the thermal configuration.
But the ‘default’ thermal configuration above can be overridden by the user?
ToyKeeper
ToyKeeper's picture
The user can calibrate the sensor and set a different temperature limit. The user can also change the ramp floor and ceiling levels. However, the level at which the thermal algorithm changes is hard-coded. Changing that requires reflashing the firmware.
pinkpanda3310
pinkpanda3310's picture
Last seen: 4 hours 7 min ago
Let’s hope proto 3 = production light Blushing
DoubleU
Last seen: 8 months 3 weeks ago
ToyKeeper, is it possible to buy the driver and tail switch for this light by themselves? I’m interested in playing around with the electronics without waiting for the production lights to ship.
JasonWW
JasonWW's picture
I’m just curious what you would do with them since they won’t fit any other light.
DoubleU
I will just hook it up at my bench. I’ve never played with a light with an electronic tail switch and a ramping driver, I’m curious to see how it works.
DavidEF
DavidEF's picture
Last seen: 2 days 7 hours ago
It will work like any other combination of driver with e-switch and ramping firmware. Having the e-switch in the tail is only special inside the flashlight. On the bench, it won’t be in the tail anymore, just a standard e-switch setup.
- The YKK Philosophy
Kindle
Kindle's picture
Last seen: 6 hours 18 min ago
i <3 u
18350 please
deleted-200707
unsubscribed
I have less interest in Lumintop than they have in their customers
maukka
maukka's picture
Last seen: 3 hours 35 min ago
chinooker wrote:
unsubscribed
I see you really dislike Lumintop, but couldn’t find the reason in your recent posts. What gives?
caplang
Last seen: 1 year 1 month ago
Guess it’s related to how Lumintop handled GT issues. He wrote exactly the same on that thread.
JasonWW
JasonWW's picture
9 threads, actually.
teacher
teacher's picture
Add 1 more & make it 10. Facepalm He even put one in the BLF Ultimate Lantern Project thread. Big Smile
odriewniffe
Last seen: 4 weeks 59 min ago
I’m in for one.
teacher
teacher's picture
gottobegeek wrote:
Interesting discussions but, I am going to unsubscribe from this thread.
When and if any light is produced and ready for purchase I guess I will get the email….assuming I am still alive, lol.
Bye-bye….. Wink
SamHaLeKe
SamHaLeKe's picture
Last seen: 3 months 4 days ago
This is going to be an amazing BLF/TLF flashlight
#510 on the list ...
Looking forward to the Proto3 feedback!
Cheers
Yakuzoko
Yakuzoko's picture
Now I know this has been briefly discussed already, but I really would like to ask for an optional deep carry clip.
I agree that it would look pretty out of place and weird, maybe even destroy the minimalist aesthetic, but for me it adds a lot to usability as an EDC light, and it’s still optional. The aesthetics of this light in regard to taper and finish seem to be fairly contested anyways. (BTW, has a final decision about finish been made already?)
Even if it costs far more than it’s production costs, I’d get one and I think most people appreciating deep carry would be willing to lay down 5 bucks or so for a decent clip. It also isn’t too hard to design, manufacture and doesn’t have to be fitted to the light for shipping.
(Also, as this would be an option that some really value and some don’t care about at all, maybe make it titanium and more expensive?)
Any arguments against this that I’ve missed? Would love to hear what you think about this.
Also, has Lumintop said anything about 2 emitter choices already?
One more suggestion @ToyKeeper: The beacon mode is pretty nice for having you remind you of tasks that you have to do periodically. However when N clicks corresponds to seconds, the maximum I’d bother to set is 30 seconds or so. How about a kind of timer, where you can set minutes as well?
Anyways, really appreciate all the work everyone is putting into this, thank you all so much Thumbs Up
ToyKeeper
ToyKeeper's picture
Looking at the code, it occurs to me that the maximum delay it’ll allow is 65 seconds. It uses a 16-bit integer for the number of milliseconds to wait, and that maxes out at 65.535 seconds.
The timer is not very accurate though. In reality, it could be anywhere from 60 to 70 seconds. And it doesn’t actually sleep between pulses, so it still uses a milliamp or so while waiting. It’s not really designed well for use as a timer with long intervals.
There is a compile-time option to allow it to ‘tick’ every half-second while asleep, which is a far more efficient way to measure time while off, but it’s even less accurate… and it’s not quite half a second. More like every 0.512 seconds, plus or minus 15%. It allows aux LEDs to blink while the light is asleep, on lights which have that, but it’s still not great for long-interval beacons.
OTOH, candle mode is okay for timing things in very rough half-hour increments. It may take anywhere from 27 to 33 minutes per cycle, but if that’s acceptable, and if half-hour time slices are acceptable, it can be used as a timer. I find it’s nice in the bath, for example. When the candle goes out, it’s time to get out of the tub.
adam7027
Last seen: 1 hour 23 min ago
I am a very late comer, but nevertheless, interested in 1-3 depending on price and final specifications.
JaredM
JaredM's picture
Last seen: 51 min 6 sec ago
Kindle wrote:
i <3 u
18350 please
+100
As long as the head mates to the 18650 body tube as well, though! This is exactly what I’m wanting next too. Previously, I’ve been considering machining a new, longer bezel ring for the 3A to accommodate a KD reflector (might try polishing one too). I was planning on desoldering ~2-3 of the 7135s to better suit the single emitter current ranges as well. Lastly, add an off center hole for the wires and voila!
