So, perhaps I should solder the spring to the battery top and remove any spring from the driver, just to be sure there is no corrosion build up between the cell and the spring…. (I’ve done that before, by the way)
After three weeks I finally got my Mini GT NW today. Light looks great however there is an issue with it. When in turbo or top of ramp and double click to turbo the beam changes from NW to CW with a purple corona and then smoke starts swirling inside the reflector. Obviously this isnt’t right. I bought from the Group buy here on BLF. Not sure who to contact.
This might be useful to buyers from united states… i recorded banggood shipping time… all free standard shipping. I counted the days when they start shipped.
Flashlights 10 days
Flashlights 11 days
Flashlights 9 days
Flashlights. 14 days ( wild fires delay ? )
Flashlights. 11 days
Yep… there are several of us that bought these through the Pre Buy/Group Buy/whatever it was………. that the shipping time sucked.
No complaint… just fact. It appears that group of packages either was truly on a slo boat or just sat around somewhere for a couple of weeks with no movement.
But… such is life .
At least it arrived in one piece & working.
Got mine today as well. Played around with a charged 30q when I got it. No smoke or unfocused reflector (that sounds horrible, sorry man). It looked great on the wall.
After the included 30q was all charged up I stuck it in my sphere. Only got 1,101 lumens at startup and 1,049 at 30 seconds. Mine is the NW variant.
I did notice the light seems to be made to accept protected cells as the 30q is not as tight end-to-end as other 18650 lights. Springs are not compressed without load, just not as long as I expected.
I may bypass the driver spring to see if it helps.
I’m not really let down too much, as i’m getting 88% of rated output. I’d be happier within 10% though. I’ll try a few other 30q and maybe a vtc5a to see what it might be.
It’s pulling 5.32amps, at start, in turbo.
I did get 134,524 candela at 20’ measured with the same battery fresh off the charger, which is right on par with the claimed 135k (within 1%).
What sphere are you using? Obviously they can vary the output readings.
If your measuring 135kcd from a NW, you have the most powerful NW yet. It kind of suggests your sphere readings are low.
Is the 5.3A at startup? It’s better to measure at 30 seconds or sooner if it stabilizes. Maybe you can squeeze a bit more output with a driver spring bypass.
Are you asking me to compare my TA Lumen Tube to yours? Do you suspect your tube is reading a bit high?
I adjusted my TA Tube to make it read consistently to my Maukka calibration light. I had to reduce my output by more than 32. I had to reduce it by 39.
Your lumen reading is about 12% higher than mine (well within tolerance of the stock TA Tube). It would be best to also compare the amp draws and the candela. If your also drawing 5.5A and had 148kcd, then your tube might be reading a bit high (compared to mine).
If your drawing 6A and get 155kcd, then your lumen numbers might be about the same as mine, your just getting higher output from the light.
I see you just ordered a calibration light from Maukka. Have you received it yet?
This is very easy to do. Most folks on the forum prefer using the Uni-T UT210E meter. There was a group buy as well as coupons a while back. It’s usually around 30 bucks. You can take off a lights tail cap and connect the battery with a loop of wire to the battery tube. Then clamp the meter to the wire. The light works normally and you can measure the amperage. This is how you would estimate output if you didn’t have an integrating sphere.
I have just experienced that kind of behavior from a Sofirn C8T: in low and medium mode, the tint is NW, when set to Highest brightness mode, the tint changes to cool-bluish tint, and there’s smoke swirling inside the reflector… I reported the issue to Sofirn and sent a lot of pictures (even asked me to put more thermal paste beneath the LED board, which I did, but it didn’t solve the problem.) Fortunately, Sofirn send me a replacement LED+board, which I’ve installed on the Sofirn C8T, and now it works properly (no tint shift when changing from medium-to-high modes and no “smoke swirl” in High mode.
I think the issue is the LED is not ‘baked’ properly into the LED board (which I don’t know nor have the equipment and skills to correct that), so the LED gets hot and becomes bluish (purplish in your case) — at least that’s how I understand the issue to be…
When opening the bezel of my GT (in the process of checking a faulty driver switch) the led was sheared off the board by transfer of the twisting action to the reflector and centerpiece. This may or may not be related to what happened to you. Shearing off a led has not happened to me before so it could be that Lumintops reflows are on the edge of not hot enough or too little flux, resulting in insufficient solder joints that apart from being weak may also not transfer the heat well enough.
