A constant current boost driver can be PWM’d. Some of them can also change the LED drive current without using PWM. As I stated, the use of a boost driver doesn’t cause any tint shift issues that weren’t there before.
I thought you meant to say that with GA and Vf of 2.82, average efficiency of linear driver would barely scrap 70% over entire discharge.
Now I think you meant over the first 1/3 of discharge.
Is that correct? If no, could you clarify how did you come up with the number? It’s quite different from mine.
Fair enough. The BLF GT uses both methods — current control for 10% to 100% power, and PWM below 10%. But it needs two pins to control one power channel… one for current and one for on/off. That’s what the lantern was going to do while using DEL’s design, before the tint ramping was added.
I’m guessing that a boost design for the lantern would keep the cells in a 4P configuration, but the emitters would be two channels each configured as 2S2P? That should keep the voltages far enough apart for a boost to work. And then instead of burning off excess voltage, the driver’s heat would instead come from voltage conversion.
You should try compensating in software instead. You could recover a pin and the drain of the voltage divider. And you no longer need the magic circuitry for VCC either.
I trust ToyKeeper’s opinion on stuff like this and based on her list alone, it looks like the AMC driver has more pros than the FET driver.
However, it seems like the majority of votes so far have been for the FET driver. I’m not knowledgeable enough to understand why.
Can anyone explain their reasoning for wanting the FET over the AMC?
I voted before seeing all the details. I still wonder how/if we can be assured of getting the “raptor claw” AMC chips. I am only think I know what I have read on here, and my impression is that one can not guarantee getting these parts in general. But that may be if one is buying in small quantity from Chinese stores. Lexel thought the FET was a better choice, and he has lots of experience designing drivers, so there is something to be said for that as well.
Two established, experienced people, two different points of view. :question:
Good work Toykeeper. Lexel mentioned he can make a prototype or two at a cost, or it may be possible Barry can get one or two built to send to you for testing.
Agree on that to go with the the standard FET (or AMC) over a Boost driver for this application, as with four high capacity cells and the lower amp loads the efficiency wont be that big of a concern.
You don’t actually need an extra pin for measuring VCC, have a look at AN2447
This way we could still have the button lighted from the MCU.
Regarding the app note, you don’t even need to use division (which is a lot of code) if all you care about are a couple of thresholds and not the actual VCC value.
Ah yes I hadn’t considered that. However, you don’t need to regulate VCC, you only need to regulate the high voltage of the PWM outputs used for the DAC… I’ll have to think about that.
As Lexel noted, making it work properly would require more pins than we have. It also would require redesigning the MCPCB. Maybe some other things too.
More pins means changing the type of MCU, which means rewriting pretty much all the low-level code. That will probably have to happen eventually, but I’m not sure now is the right time. At minimum, it would be a significant delay for this project.
I have a different question about the layout though. There are several ground vias directly under the BAT+ ring. They’re masked, but I wonder if there might still be any risk of shorting ground to BAT+ through those vias. I’m not sure how much the mask protects against that. Is that likely to be a problem?
I was talking about the first 3rd of the battery. In the case of barely getting to 70% that was a case where the lantern was running at like 1/4rd power also.
I would suggest two strings of 4 LEDs. One for each color temp. That way the current is the same in each LED and binning variances can’t lead to one pulling more current than the others. A 2S2P battery configuration would be better than 1S4P, but that complicates the battery situation by using unprotected batteries in series which is ill advised.
Why does everyone want to toss an additional 20-30% of the battery life at lower brightness levels (not that much on high)? The reasons you cite for efficiency not being a big concern actually are reasons why the efficiency is even worse in this lantern than lights pulling more current with fewer batteries. The low LED current means lower forward voltages. This means more power is burned off in the driver. The four batteries in parallel mean the per cell current draw is quite low meaning the cell voltage sags less and stays at a high voltage longer meaning more power is burned up in the driver.
Boost drivers aren’t hard. I don’t understand why everyone is scared of them or doesn’t want to use them.
