Acebeam X70 - 40000 lm - 8*18650 - Active fan cooling
V54 lights smoke and Vinh doesn’t give a toss about his customers hence always telling them to stay on topic.
There’s no need for this.
You also might get some rude points since it does seem like a pretty rude thing to say.
And we’re up to 60k lumens.
damn…. thats impressive… crazy how is that even possible with 8*18650 Battery(Sony VTC6) ?? i thought that much lumens needs better batteries… JasonWW what u say ?
20A discharge rate per cell at 100LM/W
Don’t you think it was pretty rude in the first place to have multiple offtopic posts in here?
Holy cow from 40k to 60k! I wonder if they are just bumping up numbers on paper after Imalent’s announcement of the MS12. That would ruin Acebeam’s reputation if it doesn’t deliver close to 60k as so many people have TA Lumen Tubes now to confirm those numbers :smiley:
No, off topic conversations are normal here, plus they were friendly. Telling someone to get off the forum is not friendly.
Well there is no way it could sustain 60,000 lumen. That is for sure. 40,000 lumen was borderline sustainable.
Here are my old calculations from my thread on actively cooled lights:
How the heck did I come up with 3.5A per emitter? I don’t have to look at a chart to know that doesn’t sound right. It should be closer to 4.5A.
Anyway, let me plug in 60k lumen to the formula.
60,000 ÷ 12 = 5,000 lumen per emitter. That’s roughly 8A per emitter (conservatively). 96 amps at the 6 volt level or 48 amps at 12 volt level.
48 amps at 13 to 14 actual volts would be 624-672 watts!.
As far as the batteries, it’s using 8 x 18650. If the cells were 4S2P (like the Imalent DX80) that would require at least 24A per cell!. The Sony VTC6 can not handle that amperage and temperature long term due to internal battery temps exceeding 80°C. They could do 24A each for short periods, though.
So my guess is that the X70 could do 60,000 very briefly. Maybe a couple minutes. We are talking very brief extreme turbo.
If we look at the Acebeam X80-GT it does a rated 32,000 lumen using 18 x 50.2 emitters. It only uses 4 cells at 18.6A@12v for about 260W and can sustain that for about 25 seconds. This is using 20A protected Acebeam batteries.
So the X70 would be working each battery even harder. 24A each, whew!
I wonder how this can ever work out. Even submerged in water this should be WAY too much heat generated even for 15 seconds. But I’m sure someone here can do the math.
Just think about the gigantic cpu coolers with triple 140mm fans you have nowadays to keep temperatures below 80°C and they just generate a quarter of the power.
600watts of power? holy cow thats like a mini nuclear power plant in your hands… totally insane of amount of heat generated…. shall be interesting how they solved the cooling inside….
I start to worry this light can be a real dangerous light if they dont put in proximity sensors like olight did and the risk of burning yourself must be also high…
Fortunately most of that power is converted to light instead of heat. My 80+ platinum power supply can run fanless on my overclocked i7 7700k with overclocked GTX 1080 and three harddrives, which produces a couple hundred watts.
You can’t say “most of that power is converted to light instead of heat”. I think only 25% to 30% gets turned into light. The other 70% to 75% is heat.
I think you’re confusing driver efficiency with LED efficiency. A good buck driver might be 92% efficient. So your computer power supply might be pretty efficient, but it’s not the main source of heat.
I stand corrected :+1:
Its official, lights will be available to ship by the end of next month. Preorders are now being taken.
Acebeam page updated. Now its 60k lumens
This light will probably set the bar for a very long time if knowing acebeam and their quality. Now its only wait and see what the actual runtimes will be and how long it can last with 600wats, but damn that much lumens is just insane…
That is the coolest looking light I’ve seen in a long long time. Reminds me of the BTU terminator on steroids.
Solid looking light. If they dropped the price to around $300 I would probably buy it. Too bad acebeam doesn't do group buys.
OK that is pretty awesome right there, these light manufacturers are really pushing the limits big time.
Now I see something a little different, is the flashlight itself actually fan cooled WITHOUT the handle or does the handle add a secondary fan to help with cooling orrrrrrrrr is it just the handle that is the fan cooling?
That is def a new idea you don’t see done much. I wish they would add more mass to the head of these giants to help with heat a little more.
I do wonder tho how much the human eye can tell a difference between 30k and 60k, maybe some of you could have some information on how the human eye handles that levels of brightness
