Mine thrunite v6 measurement are similiar to nkresho. If that is true, mini gt cw have more lumen than nw ā¦ i was told mini gt cw led are high bin. anyone can verify ?
Lux to candela calculation with distance in feet
The luminous intensity Iv in candela (cd) is equal to 0.09290304 times the illuminance Ev in lux (lx),
times the square distance from the light source d2 in square feet (ft2):
Iv(cd) = 0.09290304 Ć Ev(lx) Ć (d(ft))2
Sorry, hosted to imgur, since photobucket and imageshack are garbage nowadays.
My sphere is a semi-copy of the āmatch sphereā Started with a ~17ā bouncy ball, paper macheād it ovfer and over for a few weeks, then did a few layers of fiberglass for strength. Cut it open, sanded the inside and painted it with BaSO4. Two baffles using pingpong balls, also BaSO4 coated, were added. One to catch direct light between the source and the sensor, and a second to catch the primary reflection directly opposed to the source. It uses an interchangeable light plate similar to the newer TA tube design, so each plate can be the right size for the light and I can swap them easily. They are also BaSO4 coated. Sphere is also calibrated with Maukka lights and have a variable multiplier correlated to color temp. Warmer lights get a slightly lower multi, due to how my DrMeter reads.
I think you are making your calculations way more complicated than necessary. I would just use a simpler method such as 10 meters. Thereās no need to reinvent the wheel.
Thanks. Sheās kinda ugly, but does the job well as far as I am concerned. Lumpy like a big black meatball on the outside. Was so sick of paper mache-ing that I didnāt really sand the outside to a body shop quality finish like I originally planned. Business end (inside) is baby-butt smooth.
I canāt understand what your saying here. Are you saying that the Mini GT cool white has more lumen than the Mini GT neutral white?
Where does the Catapult V6 fit in?
Jason, I think heās saying that he gets similar readings as nkresho on the Catapult as a reference to accuracy, then says his mini gt with cw has more lumens than the nw which it should. Given the same power bin a warmer tint will always read lower output.
Nice work nkresho, the complication is that you are using feet instead of simply staying with meters as per the industry standard. Aside from that the calculations are the same. I really donāt see any need to convert with that 0.09 number, as distance is distance regardless what you call it. But then, what do I know? (no answer required, I get itā¦)
<ā zip experience with spreadsheets and/or excel.
So Iām probably going to be the last person from the pre-sale to receive their lightā¦ā¦
Had an ETA of Monday the 27th, and then when Monday came and went, it suddenly changed to stuck in customs. And all of that after the 3 week delay in China.
I have not noticed it on mine.
. @Delta_Vā¦ā¦ Darnā¦ you have had worse luck of any of us it seems. :person_facepalming:
Hopefully it will get there soon.
