I think you are making your calculations way more complicated than necessary. I would just use a simpler method such as 10 meters. There’s no need to reinvent the wheel.
Thanks. She’s kinda ugly, but does the job well as far as I am concerned. Lumpy like a big black meatball on the outside. Was so sick of paper mache-ing that I didn’t really sand the outside to a body shop quality finish like I originally planned. Business end (inside) is baby-butt smooth.
I can’t understand what your saying here. Are you saying that the Mini GT cool white has more lumen than the Mini GT neutral white?
Where does the Catapult V6 fit in?
Jason, I think he’s saying that he gets similar readings as nkresho on the Catapult as a reference to accuracy, then says his mini gt with cw has more lumens than the nw which it should. Given the same power bin a warmer tint will always read lower output.
Nice work nkresho, the complication is that you are using feet instead of simply staying with meters as per the industry standard. Aside from that the calculations are the same. I really don’t see any need to convert with that 0.09 number, as distance is distance regardless what you call it. But then, what do I know? (no answer required, I get it…)
So I’m probably going to be the last person from the pre-sale to receive their light……
Had an ETA of Monday the 27th, and then when Monday came and went, it suddenly changed to stuck in customs. And all of that after the 3 week delay in China.
I have not noticed it on mine.
. @Delta_V…… Darn… you have had worse luck of any of us it seems. :person_facepalming:
Hopefully it will get there soon.
