I want a boost driver, but I’d rather get a lantern this year than 2020, so I’m happy with the PWM driver or the FET driver. I’m ordering 3, so if I can design a boost driver that fits, I will at most break one. I’m sure that if a boost driver does get made, it will be open source, and anyone will be free to make one. Also, what you can afford in qty 5 is not what is affordable to a Chinese mfg. at qty 1000+ when they start counting pennies. I can afford 5 $5 FETs to use on my board for a 10% gain, they can’t.
I’ve spoken out in favour of the linear FET driver because it doesn’t have PWM and gets a few more lumens per watt, but I’m fine with the 7135 version if that has more plus points overall. I still don’t feel the need for a boost driver.
I do have a question about the FET driver tint shift, though. Would the tint ramping capability let people manually correct for the tint shift at a given brightness? Or would the shift be in a different direction to the ramp within the colour space?
Tint is not CCT (color temperature). Tint is a deviation form perfect white light (which can be warm, cool or in between, always on the line of the black body radiator). Tint is when the light has a green tinge or is red-tinted for example.
The lantern will be able to change its CCT, not the tint.
Sort of both. Higher modes tend to be cooler and whiter, while lower modes tend to be warmer and greener. The tint ramping can change the warm/cool balance, but it can’t change the white/colorful balance.
On this diagram, lower current levels tend to make the tint go to the right (warmer) and away from center (farther from the dotted line). Higher current generally makes tint go left (cooler) and toward the dotted line. The tint ramping can adjust things on a left/right axis but not an up/down axis.
For example of how current changes tint, maukka measured the Olight S1 Mini’s tint in different modes. At lower modes, it gets warmer and greener:
To minimize any warm/green shift, the lantern could use PWM at full power to keep the tint as close to white as possible. The lantern could also potentially use 3 emitters per channel instead of 4, to increase the current going to each emitter.
For an example, let’s say the lantern can make 600 lumens and it’s running at 33% brightness on a visually-linear scale. That works out to about 33 lumens total, at ramp level 50 of 150. With a 4000K tint it uses all 8 emitters, at about 4 lm each.
A constant current driver then delivers only about 10 mA to each emitter. On the Olight chart above, this would be somewhere between “moon” and “low”.
A PWM driver instead delivers 350mA to each emitter, producing about 150 lm per emitter, but only for a short time. Visual brightness looks the same, but the tint coordinate would be somewhere between “mid” and “high” on the chart above.
However, the chart shown is for a different emitter, and I don’t have data on the tint shift effect on LH351D. It may behave differently. Most LEDs follow the same general pattern though, where the lowest levels are the least white. When we increase efficiency by using those low levels, we also reduce the quality of light coming out.
So the question is whether to prioritize tint or efficiency.
Since the lantern is using high-CRI emitters, I’ve been assuming that tint is the priority, so an AMC7135-based driver would probably make the most sense for that purpose. But if efficiency is more of a concern, it could definitely use a linear FET driver with medium-CRI emitters. It’ll make significantly more lumens per Watt, delivering higher output and longer runtimes.
I had originally planned for the lantern to use 3 emitters per channel then went to four per channel. If three emitter will work better i can re-design the LED star for a 3 + 3 LED config, but like you said above, there is not much data & tests on how the 351D reacts to higher currents as its such a new LED.
Hey, you’re the one who said boost drivers are ‘right’ AND you’re the one who said boost drivers are ‘easy’. Why would we need a name change if doing it right is easy for you?
Since the lantern is based on the Q8, I am assuming that it can only accept button top batteries right? Or will this lantern be designed with a battery carrier?
I understand the tint shift issue now. I’m unlikely to have a problem with tint shift unless it’s truly dire - CCT and CRI are the things I notice - but I agree that we should have the best quality light for everyone, especially since this is going to be a high CRI lantern (the feature that sold it to me).
If the 7135 driver with high frequency PWM is the favourite among the rest of you to achieve that, then it’s fine by me. High CRI and ramping from 3000K to 5000K are my must-haves; I’m not going to lose any sleep over the odd bit of efficiency here or there.
I must admit, I made an assumption. Usually when people talk about boost or buck drivers, it’s implied that the driver will function in a manner which delivers constant current to the emitters. It’s uncommon for people to talk about the benefits of boost/buck drivers and then use PWM. But the two concepts are indeed independent, and I shouldn’t assume.
It could even be possible to fix the level of boost current firmly in place and then use only one pin per channel to do PWM, turning the boost converters on and off. Maybe even give the boost circuits a regulated voltage source which bypasses the MCU, so it could still measure the battery directly on its VCC pin. I’m not a circuit designer so I’m not sure if it would work, but it seems like it might. And then instead of burning off a volt as heat, it might have a smaller amount of wasted energy.
This isn’t a thing I can make though. So for now I’ll go with the assumption that the driver will be one of the designs Lexel already posted. I’m particularly looking forward to trying out the new flashing connector at the edge of the board.
A few pages back I was going to suggest a poll of people that have gotten a spot on the around 1000 devices spoken for. If that can be done so that each person signed up for the lamp would be notified, it would provide insight on those so far "committed". ID and units "ordered" would distribute the results for multi orders. The poll should provide a place to show how many the participant is intending to buy. The results would be scaled by buy quantity. A good list of possibilities in the poll would allow a sense of what the majority wants.I believe there are a lot of people waiting for these lanterns, but not interested in the technical details. They should be heard.
Personally I am on the side of highest efficiency (e.g., battery run time). No color light changing. No other functions like USB charging ports for cell phones or charging the lamp and poking extra holes in the shell. With stick in rubber covers that will eventually fall off and/or leak. I never really agreed with the non-use of the most efficient power system in the Q8 (I have 3). Nor was I particularly crazy about very complex operational requirements. Yes - you can sort of avoid them, but mis-stepping is also real easy. I think I actually suggested back then that the Q8 be used as the base rather than starting from scratch that the initial device was doing. But the old brain sometimes makes things up. But, for whatever reason, it went in the good direction we see now.
When this project started (I am one of the earlier people signing up for several of the lanterns), my expectation was:
A waterproof lantern
Robust construction
Simple operation
Maximum light duration with the most efficient power system possible (I do care if it goes dark 10% or 20% or more sooner than is necessary)
I think emergency light not beer party (although I see no reason why beer should not be involved)
Preferably with the ability to dim the lamp
No rubber plugged holes for external devices - no external devices or sources
A low intensity visible light in the power button
That was pretty much it. That defines a lantern in my mind. It is actually what I would still generally like.
So there are essentially my poll answers.
A quick other thought - has anyone looked at the effects of low ambient temperatures. I would think that things will get warm quickly, but will all of the pieces work to turn things on in low temperatures (e.g., 0 F). And by that I mean, it is 0 F outside, and the lamp has been sitting unused in the car/garage/front porch for two days.
