Perhaps a battery-tube design like Haikelite uses it would be possible too. But 8P and 2S4P Battery-Configurations are impossible with the design from Haikelite.
I only want to give you some inspirations. I am shure, you will use the best design, which is easy to produce and althogh easy to change battery-configurations / battery-voltage and to use different emitter-heads with it.
For Now, the threads of the Haikelite Battery-Tubes are the same as on the Q8. And they sell them together with flashlights as 4S or 2S2P. But they give no contact to the battery+ brass ring on the Q8-driver.
I thought about it, but I like 3*18650 more than 1*26650. And for batteries, more sparing conditions of work. I look closely to Fireflies ROT66, but its price is much larger than Q8.
As it seems to me 4*18650 goes beyond ergonomics. Q8 it is so successful that I have recommended it to my friends many times, but personally I’m somewhat uncomfortable.
Yeah, Neutral would be better for me as well. But, assuming Sofirn keeps the same mod-ability that the original Q8 has, it should be possible to change to whatever CCT is desired. If it’s the same size PCB, then even the size of the emitter can be changed by using a led4power Q8 MCPCB.
Seems pointless to even discuss right now. The only change they said they have made is putting in HI leds instead of HD. None of the other more interesting changes are even designed yet… If someone wants a neutral Q8 there is already the real original Q8 with HD leds that had an excellent combination of flood and throw already.
The only CW lights, which I are in, are of CRI 90 or above. Unfortunately there is no 90 CRI option for first gen. XPL in either HD or HI. There is no second generation XP-L (XP-L2) HI, and XP-L2 kinda sucks regarding tint consistency. I'd hope for an XHP35 90 CRI 5700K version of the Q8 (maybe 6500K is also fine, but 90 CRI is required for me).
I would really appreciate a 3 batteries tube/carrier working with the new Q8. Maybe another one with a down-compatibility to the BLF-Q8 with a different end (positive contact to the driver).
Neutral white 90 CRI for the leds, preferably not Cree because most have a “rainbow effect”.
