A few pages back I was going to suggest a poll of people that have gotten a spot on the around 1000 devices spoken for. If that can be done so that each person signed up for the lamp would be notified, it would provide insight on those so far "committed". ID and units "ordered" would distribute the results for multi orders. The poll should provide a place to show how many the participant is intending to buy. The results would be scaled by buy quantity. A good list of possibilities in the poll would allow a sense of what the majority wants.I believe there are a lot of people waiting for these lanterns, but not interested in the technical details. They should be heard.
Personally I am on the side of highest efficiency (e.g., battery run time). No color light changing. No other functions like USB charging ports for cell phones or charging the lamp and poking extra holes in the shell. With stick in rubber covers that will eventually fall off and/or leak. I never really agreed with the non-use of the most efficient power system in the Q8 (I have 3). Nor was I particularly crazy about very complex operational requirements. Yes - you can sort of avoid them, but mis-stepping is also real easy. I think I actually suggested back then that the Q8 be used as the base rather than starting from scratch that the initial device was doing. But the old brain sometimes makes things up. But, for whatever reason, it went in the good direction we see now.
When this project started (I am one of the earlier people signing up for several of the lanterns), my expectation was:
A waterproof lantern
Robust construction
Simple operation
Maximum light duration with the most efficient power system possible (I do care if it goes dark 10% or 20% or more sooner than is necessary)
I think emergency light not beer party (although I see no reason why beer should not be involved)
Preferably with the ability to dim the lamp
No rubber plugged holes for external devices - no external devices or sources
A low intensity visible light in the power button
That was pretty much it. That defines a lantern in my mind. It is actually what I would still generally like.
So there are essentially my poll answers.
A quick other thought - has anyone looked at the effects of low ambient temperatures. I would think that things will get warm quickly, but will all of the pieces work to turn things on in low temperatures (e.g., 0 F). And by that I mean, it is 0 F outside, and the lamp has been sitting unused in the car/garage/front porch for two days.
Do you remember what number you were on the list? ( nobody should be removed unless it was accidental. ) message sbslider to get re-added if needed, as he is handling the interest list.
Indeed the original V1 started out to be a simple lantern with 4 modes & long run-times, and good light tint, but over time it got developed into a more versatile design. Once we get the current V2 into production, we may work on a simpler, lower cost basic version of the same lantern for those who need just a simple, reliable off-grid light that will run for days with no bells & whistles for those seeking a “base model” so to speak.
It’s weird because there were more people? Maybe people backed out? I was 928, lol. So it looks like it’s an improvement? Add me back please
Looks like maybe people took things too serious. I’m not expecting the PERFECT lantern, lol. Just an improvement of what is out there. From what I’ve read I’m pretty excited. Beside, the “ultimate” lantern won’t be that way for long. Every light eventually gets dethroned. The lumen race, size race, etc. Nobody holds it long…
That is critical. Tint above the BBL can be very unpleasant for staying longer periods of time, and it makes foods and people uglier. If we are building the “ultimate” light we should strive towards getting the best output available. And that includes below BBL tint, and R9 values above 90. This chosen led has tint in the green, and R9 values that are between 60-70 as far as I can see Samsung LH351D color testing - #4 by maukka which is not ideal for a BLF lantern, since we are choosing the parts.
Since we are set on these leds, at least we can try to find some some samples from Samsung that are lower in the BBL which will boost the R9 values a bit, and make the light more pleasant for longer usage.
It’s simply impossible to build the perfect lantern for everyone. Some want the longest possible runtime, others the best tint & cri and we need to find a good compromise. But I like the idea to build an enthusiast variant with all the great features (like tint ramping, powerbank,…) And a simpler base Version for the one who don’t need this.
Concerning the driver I want the highest efficiency that is possible without significantly influencing the light quality.
The thing with the boost driver, which would work the most efficient and I would love to see it happen, is that someone must design it (Sofirn won’t I’m sure), with all requirements like: for Sofirn affordable parts and able to run TK’s UI. If someone can do that now I think it is a good idea. If a boost driver development remains on the level of a theoretical discussion for too long it just delays the design of the lantern and in the end the boost driver may not even happen after all.
That is what makes the Lexel design so attractive: we suggest it, he just makes it, it is there and can be used. Same for Toykeepers firmware: we discuss what we would like for it and she already wrote the firmware, with smart features added that we even did not think of. And both have skills that Sofirn lacks so both BLF and Sofirn profit from the cooperation.
In my opinion, without the most efficient driver possible, this lantern may still be called the ‘ultimate’ lantern .
I wanted to say something like this last night, but couldn’t find a good way to put it, so I set it aside and went to bed. I’m glad you’ve said it for me
So far, it has a single tint value which applies to all modes and can be changed at any time.
I haven’t even thought about making the tint change based on which ramp it’s using. The main fancy bit I thought about doing, perhaps, is dedicating one of the 256 tint values to “automatic” — warmer at low levels and cooler at high levels. In particular, it might be a nice thing to do in candle mode. But I haven’t tried that so I don’t know if it would be worthwhile.
Benidin added to interest list for a third lantern at number 971. Your other two are at 453 and 454. These numbers are not really important, and will likely go away soon. huey18 is generating a bot to automate this list keeping. Until it is done I am doing it manually.
I still have not sent an updated interest list. You can see the interest list anytime you like. Will likely send an updated list to DBSAR in the next couple days.
I sent an updated interest list to DBSAR today, so if you don’t like looking at the links above, I imagine in a day or two he will update the interest list in the first thread post.
I’m really hoping these are available during this seasons fall/early winter camping season! Summer camping is a no-go here. Too humid. Good luck sleeping in 85+ weather with 98% RH.
so finally added thermal viases, 1A and 1W is pretty much fine as it was, but if people want to go higher they need more cooling on the MOSFETs
also rearranged the common ground for the OPAs and MCU
Looking good! Any thoughts or ideas on what the maximum “factory” amp draw on high is set? assuming it will depend on the sense-resistor ohm value? Also the button LED still has ability to change or be programmed from TK’s UI?
