(prototype) the GT Mini
received mine (from the group buy) today!
something to fiddle with when it gets dark…
is your gt cw or?
I don’t know who posted this to make tail cap measurements one handed.
So I’m probably going to be the last person from the pre-sale to receive their light……
Had an ETA of Monday the 27th, and then when Monday came and went, it suddenly changed to stuck in customs. And all of that after the 3 week delay in China.
Well that blows…sorry man…hope it comes soon.
Does anybody elses make a ticking sound?
I have not noticed it on mine.
@Delta_V…… Darn… you have had worse luck of any of us it seems. :person_facepalming:
Hopefully it will get there soon.
Hmmmm…prob cant hear it outside…but it sometimes does it…then like 3 sec later drops output from turbo.
Yes it is cw.
That looks quite similar to the one shown by djozz in this video (at around 03:40 minutes mark)?
What Anduril setup is good to flash on the GT mini? D1S? GT?
Less than 3 days and the lighted switch on my Mini GT quit working. :person_facepalming:
It got dim first, then flickered from dim to bright for a while; then died. Dead as a door nail…… :frowning:
Anyone else have this problem??
What is the proper course of action to resolve this??
Give it a Cat scan…
if you bought from Neal please write him a mail:
CS@m4dm4x.com
I bought it in the Group Buy, so I’m thinking that was from Neal. Thanks Martin…… :+1:
Sounds odd. That led is mounted to the driver, so it should be getting real good connections unlike the seperate switch on the early Q8’s.
Normally I would say pop the driver out and touch up the solder contacts on each side of the LED, but the glued bezel makes that pretty hard to do.
Since it was flickering, I guess that rules out that it accidentally got turned off in the UI. I remember that happened to some people on a different light and they reset the firmware back to default and it started working again. That’s a very easy thing you can try just for the heck of it.
My bezel was barely glued. I didn’t realize it wasn’t just tight until I looked at the threads.
You hear a rattle in the head if you shake it? . :question:
That don’t sound promising…… :frowning:
:+1: … Yep, I guess “odd” is one way to describe it. :frowning:
And I agree, it “should” be solid as a rock the way it is mounted…. But something ain’t right, cause it don’t work.
Yep I checked, and my bezel is glued tight as a drum. :person_facepalming:
Situations like this, yet another reason I hate glue…… :wink:
I had also tried the reset…. but no joy. :frowning:
Oh well… stuff happens. I’ll wait to see what Neal has to say. :slight_smile:
