Latest and greatest dive lights?
Depends.
Focus angle of the light is important to the requirement for the diver and for the environment. The Great Lakes now, from what I hear, are quite clear. So you may be able to get away with a variety of lights. If you have poor visibility, narrowly focused lights penetrate > better for seeing and being seen + signalling.
Wide focused lights in poor viz situations are kind of a mess, reflecting back like in a snowstorm, illuminating everything in the water but not what you want.
A reality of MOST cheap lights is they have low quality drivers. That translates into a light that is bright to START, and rapidly fades with voltage. You generally have to just up to much more costly lights to get around that issue. Functionally, that may not really be much of an issue on a single dive if you have enough battery to support the draw. But, don’t be taken in by highly exaggerated claims for these lights. Try to get some first hand reports of it.
Some may have poor heat sinking. The higher the output, the better that has to be.
Reliable water tightness is critical of course. That trait usually shows itself soon if it’s inadequate.
Flydiver, thanks for that info, something to think about!
BTW, here is a pic from one of the buyers of the Sofirn SD02 on Aliexpress. He likes the light and I like his set up with his dive helmut.
Sofirn has the SD02 and SD02A (3000K tint). They say the warmer tint of the SD02A works better for underwater?
I notice Boruit also has a so-called ‘diving’ light, which looks very similar to the UltraFire DV-S9:
https://www.aliexpress.com/store/product/2000Lm-Underwater-Diving-80m-Flash-Light-10W-XM-L2-LED-Flashlight-LED-Dive-Torch-Waterproof-Light/1091355_32629403936.html
I wonder if it’s similar to the UltraFire DV-S9 in quality. There are lots of similar-looking designs.
That's another interesting dive light I never saw before. I thought about getting the warmer tint of the SD02A and then decided on the NW tint instead. For the price, it's easier to get another one if I like it.
Boruit? Hahahaha
all of this are cheap swiming lights.
Far from latest and greatest.
Try looking
Light and Motion lights,
Dive Rite lights,
Sealife, Scubapro…
Or other greatest lights.
Enderman, wet connector for charging?
you’ve obviously missed the point. It would be easy for me to go buy something expensive at the dive shop, ( i just dumped $7k outfitting my wife and I) but the value is really lacking in most “dive” lights. Come on, $1500-2000 for a canister light??? Most divers have no choice because they’re not flashaholics. I have options to order direct and cut out the middleman…
buy Dive Rite bx2 handed light. come with battery and charger for 100 usd.
don’t buy world cheapest possible light as Boruit.
The Boruit looks like the same light I mention in my first post as the U’King. It’s pretty much the same design as the DV-S9. Possibly a decent light. Mine worked fine, but I haven’t tested it extensively.
I know the DGX 600 (Dive Gear Express) that I linked to is a ‘cheap Chinese light’ with DGX logo on it. I forget the original brand name but it was pretty common for awhile. I’d strongly suspect the same for the bx2. The issue is sorting out the decent stuff from the crap. I’ve got a good number of cheap dive lights that are only suitable for walking in the rain. For serious diving, I take good lights.
Having said that I took a couple of those really cheap fluorescent yellow/green twist-on type for my trip to the Philippines. They are extremely small and light (serious weight issues with camera gear), and some of them put out a decent light. But, I did some serious touch-up work on the O-ring channel (crappy workmanship), and changed to better O-rings. Even with that one of them ‘seeped’ a couple drops and they were a pain to turn on and off.
Some measure of consistency, reliability, and possible warranty support is what you get from a real dive shop. They’ve done the vetting for you. It’s pretty much that vs. lower price + unknown quality.
Dive gear express NOT dive rite express :wink:
Dive rite are scuba professionas
dgx 600 is same as brynte light and many other brand have same model.
What does this mean?
Sofirn SD01 is the same light as the Thorfire S1
what ever dive light you get, just make sure you get some good silicone grease, to apply to the o-rings frequently
I ordered the SD02 and have a tube of Sil-Glyde ready. The side button on the SD02 I'm not sure how to make water proof other than hope Sofirn did a decent job with it.
Shouldn’t have to lube the side button. It should be a magnetic button or something
Hmm. Thorfire S1 and Sofirn SD01, I suppose shouldn’t be too much surprised as I notice many Thorfire flashlights have look-alike (or exactly the same) models as the Sofirn ones, since it’s said that Sofirn is the OEM manufacturer for Thorfire…
The Sofirn SD02/SD02A looks like a push-button switch, probably not magnetic, I was wondering if it will really be waterproof too…
Has anyone actually bought it for below 20 dollar? I tried, and got 119 dollar on the app
Yes. Corrected. Thanks for jogging my memory about Brynte light being DGX. You can get the Brynte for half or less.
Note - Have a friend with a Dive Rite canister light ($$:money_mouth_face: that was getting a short run time. I checked it out for him. Nice light. Battery was seriously unbalanced with 1 bad cell. I’ve seen a few PCB protection go bad and not do their job which screws up the whole pack. They wanted a small fortune for a simple 5S 18650 flat pack containing Tenergy cells. Bought a Tenergy pack for 1/3 the price, swapped connectors, and it’s doing fine 2 years later. I’ve found some of the high end canisters have great lights, and skimp on the cells and charger.
I can't tell what type of button it is but it doesn't look magnetic from the pics. Maybe I'm wrong. I'll know when it arrives next week.
I can’t comment on the other two, just the DV-S9. It’s sealed hella well with triple O-rings in the tailcap, everything else is Just One Big Tube (ie, no head+tube), and the only other possible point of ingress is at the front lens and bezel. Looks to be well-sealed as I haven’t yet gotten the bezel to loosen, but probably only a single O-ring between bezel and lens might be a weakness under pressure.
If I were doing some serious diving, I’d a) check the thickness of the glass vs water pressure to make sure I don’t go down too deep, and b) if taking it apart, use RTV or something to really seal the lens against the bezel, and then only worry about the bezel-to-body interface. (And let it outgas quite a while so it doesn’t fog the lens/reflector.)
I use YEZL lube-goo on my lights’ threads, as it feels stiff and waxy at first, but smears pretty well, like thick Vaseline™. Over several threads’ worth, it should provide a good seal.
