folomov EDC-C3 does that - the head has the USB jack, you can take it off the body and it will run from USB.
Though the usb supply you use may limit max output…
also it is kind of expensive. but it can also function as a power bank, with a special cable that it comes with.
Received my Jaxmnve M3 today . Cool little light. Any suggestions as to how to unscrew the bezel . A couple of specks of dirt on the emitter and gasket I’d like to clean up. Must unscrew as they include a spare lens and o ring . Other wise all good. Warm tint. Usb charging , 16340 cell , clip and lanyard all for $13.60. Might share duty as pocket work light with my Sofirn SP10. Oh , magnetic tail cap also.
Never mind about the bezel. Got it off with a rubber band.
Ooooo, thanks for the heads up on the new M3 pro. I stopped carrying the M3 due to no built in charging. I tried the U16, but it’s too big and heavy so I carry the M3 clone.
Now I’m gonna have to get the M3 pro. I still don’t like the press and hold on/off, but at least it’s consistent.
I could probably fit a round magnetic adapter to the M3 pro to make charging easier.
That’s a real good price. I bought 2 of the U16 when they first came out for $20 each. I’ve never seen them get back down to the $20 range since then. Unfortunately, they weigh twice as much as the M3 and are bulkier as well so they are just sitting on the shelf collecting dust.
Got mine today, black with new UI. Warm white is warmer than XML2 4C, may be near 4000k. Standby current is only 0.5µA, lowest current I have seen ever.
I didn’t have high expectations when I ordered mine but I find myself using it often . UI is not terrible. If you turn it off on high, it will memorize that level but if you short click it while off, you can cycle the modes while off . Thus a short press then a long would get you low. 2 short clicks then a long will get you med. A single long click will get you high. Kind of cool. Mine has perfect charging and the LVW works (no LVP).For it’s size, it puts out a decent amount of light. Run times are short though, to be expected with 16340 cell provided.I paid under $10 for it so I give it some slack.
I figured you were one of those guys that value low very much. I need all the light I can get due to retina problem so high and med. are important to me. Just a cute little light overall. I learned something the other day when I set it down on my laptop magnet side down. Don’t do this as the screen went out. Thankfully it turned back on after removing it and turning it on again. The magnetic field affected something inside.
I do like good value for money, but when things irritate me, it’s worth it to get rid of the irritation.
Like right now I need a good, small 90° head light. The Olight H1R seems to be the only choice that meets all my requirements. I may have to bite the bullet and pay the $70.
So $25 is not much at all for the M3 Pro. Plus it’s brighter than the clone. I measure about 400 lumen from the clone. The older M3 gave me 770 lumen. The new version I just ordered is supposed to be a bit brighter than the old version. So maybe 800 lumen. It really is a good little light.
I only switched to the clone because the M3 didn’t have built in charging, but the new one has it. So I’m switching back.
Stop, now you are making me want one and the wife says enough for awhile. I think I will buy Narsil only in the future to make it easier to remember and to teach my wife . Right now the dual switch lights seem easiest to teach novice. On/off at tail and l-m-h on the side . Long click, short click, single, double, triple…Yikes. How did I get on this. Sorry.
