Well that blows…sorry man…hope it comes soon.
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
Does anybody elses make a ticking sound?
I have not noticed it on mine.
@Delta_V…… Darn… you have had worse luck of any of us it seems. :person_facepalming:
Hopefully it will get there soon.
Brainsick67:Does anybody elses make a ticking sound?
Hmmmm…prob cant hear it outside…but it sometimes does it…then like 3 sec later drops output from turbo.
Newlumen:Yes … I measured my v6 with shockli.
thrunite catapult v6. 2050 @ turn on. 1970 @ 30 sec
Blf gt mini 1390 @ turn on. 1300 @ 30 seconds.is your gt cw or?
Yes it is cw.
JasonWW: Newlumen:I do not know how to measured amp draws nor have a device to do it.
This is very easy to do. Most folks on the forum prefer using the Uni-T UT210E meter. There was a group buy as well as coupons a while back. It’s usually around 30 bucks. You can take off a lights tail cap and connect the battery with a loop of wire to the battery tube. Then clamp the meter to the wire. The light works normally and you can measure the amperage. This is how you would estimate output if you didn’t have an integrating sphere.
I don’t know who posted this to make tail cap measurements one handed.
That looks quite similar to the one shown by djozz in this video (at around 03:40 minutes mark)?
What Anduril setup is good to flash on the GT mini? D1S? GT?
Less than 3 days and the lighted switch on my Mini GT quit working. :person_facepalming:
It got dim first, then flickered from dim to bright for a while; then died. Dead as a door nail……
Anyone else have this problem??
What is the proper course of action to resolve this??
It got dim first, then flickered from dim to bright for a while; then died. Dead as a door nail…… :(Sorry man…mine still works…but when i take the head off i hear a rattle.
if you bought from Neal please write him a mail:
CS@m4dm4x.com
I bought it in the Group Buy, so I’m thinking that was from Neal. Thanks Martin…… :+1:
Sounds odd. That led is mounted to the driver, so it should be getting real good connections unlike the seperate switch on the early Q8’s.
Normally I would say pop the driver out and touch up the solder contacts on each side of the LED, but the glued bezel makes that pretty hard to do.
Since it was flickering, I guess that rules out that it accidentally got turned off in the UI. I remember that happened to some people on a different light and they reset the firmware back to default and it started working again. That’s a very easy thing you can try just for the heck of it.
My bezel was barely glued. I didn’t realize it wasn’t just tight until I looked at the threads.
teacher:Less than 3 days and the lighted switch on my Mini GT quit working. :person_facepalming:
You hear a rattle in the head if you shake it? . :question:
That don’t sound promising……
:+1: … Yep, I guess “odd” is one way to describe it.
And I agree, it “should” be solid as a rock the way it is mounted…. But something ain’t right, cause it don’t work.
Yep I checked, and my bezel is glued tight as a drum. :person_facepalming:
Situations like this, yet another reason I hate glue……
I had also tried the reset…. but no joy.
Oh well… stuff happens. I’ll wait to see what Neal has to say.
Brainsick67: teacher:Less than 3 days and the lighted switch on my Mini GT quit working. :person_facepalming:
Yes…but whwn i press Button down its quiet…and when i put batt in its quiet…odd…
Teacher, fwiw… that 789D fully loaded weighs some 715,000 lbs. The tires are 12’ tall and weigh 6640 lbs EACH, there’s 6 of em at a cost of near $50,000 each to replace!
Give it a Cat scan…
. . . . … Now ‘THAT is a TRUCK’!! A very expensive truck.
Good info Dale.
I wish I owned a couple of those & could have them working 24 x 7 x 365…. that would mean a lot more $$$$$.$$ for lights, guns, fishing toys, & trips to exotic places to use them all. :sunglasses:
Hey DB Custom, did you get Anduril on your GT Mini? What light’s program did you use?
