That’s fine, but it’s not needed for most since a wide range of temps are covered. Those with the ability can, and those that can’t still have a good range. With the ramping, even with swapping the LED’s you get a more versatile light.
The Nichia E21A is the better choice. It has a similar CRI (R9080), a tint under the BBL or on it, is available with every conceiveable CCT (2000K-6500K) and is more powerful compared to the Optoslis (less LEDs required). Here are Maukkas tests. This would require the use of a pcb with a special insulation material that has a low thermal resistance like Clemence and led4power use (should not be a problem cost wise since we need to get a pcb made anyhow). It would have the added benefit that we can put the FET onto this pcb to improve its heatsinking substantially (like led4power does). In my eyes this is the most elegant design.
As djozz has already mentioned tint is more important than ever higher cri ratings. The E21 R9080 LEDs offer a great tint.
The Optisolis’ lower output / lower max amps can be fixed by using more of them. Spreading the emitting surface is not a problem for a lantern….quite the opposite in fact.
That said, I’m not voting for any emitter change, I’m fine with LH351* as well as E21 / Optisolis.
You can’t really see the difference between R9080 and R9090. Thats a tiny difference.
Also, the 5000K Optisolis that Maukka tested was above the BBL. So even these aren’t perfect.
Yes, but if we don’t use a boost driver we would have to put all those LEDs in parallel. Since they all have slightly different Vfs they would all be driven at different currents. With so many LEDs in parallel the lifetime of some of them might be reduced.
Pretty cool to use Optisolis leds. Half a year ago I suggested using a bunch of 3030 midpower leds and did not get much acclaim. In the current phase I do not think it is a good idea to change the led choice anymore. I hope that Sofirn can get their hands on some good tinted LH351D’s
I’m signed up for several lanterns and am really looking forward to these. The biggest thing I care about is durability since these will be used for camping and will be bumping around in trucks offroad, etc. I don’t need the power bank, I don’t need tint shift, I don’t need a lot of the cool options and features that will come with this lantern (although I’m not against them either). What I do want is durability first and foremost.
GhostofHarry, added you to the interest list at number 975
You definitely did, and I definitely didn’t add your second light, until you reminded me. Your second is number 976 on the interest, sorry for the oversight. :disappointed:
I don’t care about powerbank function, charging function is nice to have but I can live without it, tint change is also nice but warm tint is just as good, ramping is essential, no preset modes without ramping please. Two - or more - memorized modes is very nice to have… I used that with T1, one mode for “locator” use and a second for general use for example but all memorized modes should be user selectable using ramping (eg change preset by click, click and hold to change - ramp - brightness of current mode, click to go to next mode, click and hold to program that mode and so on.
you are number 923 on the interest list. The version in the OP has not been updated since your request, but you are on the master list for 1 presently.
You can check the “live” version of the list anytime in the links below.
It has both smooth ramping and stair-step ramping with discrete levels. In both cases, you can set the brightness of the lowest and highest levels, and for stepped mode you can also set the number of steps. This is in addition to remembering which brightness was last used. So… basically, it remembers one level automatically, and you can also tell it two or more other levels to use.
