(prototype) the GT Mini
Give it a Cat scan…
if you bought from Neal please write him a mail:
CS@m4dm4x.com
I bought it in the Group Buy, so I’m thinking that was from Neal. Thanks Martin…… :+1:
Sounds odd. That led is mounted to the driver, so it should be getting real good connections unlike the seperate switch on the early Q8’s.
Normally I would say pop the driver out and touch up the solder contacts on each side of the LED, but the glued bezel makes that pretty hard to do.
Since it was flickering, I guess that rules out that it accidentally got turned off in the UI. I remember that happened to some people on a different light and they reset the firmware back to default and it started working again. That’s a very easy thing you can try just for the heck of it.
My bezel was barely glued. I didn’t realize it wasn’t just tight until I looked at the threads.
You hear a rattle in the head if you shake it? . :question:
That don’t sound promising…… :frowning:
:+1: … Yep, I guess “odd” is one way to describe it. :frowning:
And I agree, it “should” be solid as a rock the way it is mounted…. But something ain’t right, cause it don’t work.
Yep I checked, and my bezel is glued tight as a drum. :person_facepalming:
Situations like this, yet another reason I hate glue…… :wink:
I had also tried the reset…. but no joy. :frowning:
Oh well… stuff happens. I’ll wait to see what Neal has to say. :slight_smile:
Yes…but whwn i press Button down its quiet…and when i put batt in its quiet…odd…
Teacher, fwiw… that 789D fully loaded weighs some 715,000 lbs. :wink: The tires are 12’ tall and weigh 6640 lbs EACH, there’s 6 of em at a cost of near $50,000 each to replace!
:open_mouth: . :open_mouth: . :open_mouth: . :open_mouth: . :open_mouth: … Now ‘THAT is a TRUCK’!! A very expensive truck. :wink:
Good info Dale.
I wish I owned a couple of those & could have them working 24 x 7 x 365…. that would mean a lot more $$$$$.$$ for lights, guns, fishing toys, & trips to exotic places to use them all. :sunglasses: :beer: :wink:
Hey DB Custom, did you get Anduril on your GT Mini? What light’s program did you use?
I think I used the newest D1S Anduril, from July or something. Will have to look it up…
Hey guys, what would be the best protected cell that actually fit in GT mini?
Maybe the Keeppower 3120mAh…
But most will run unprotected.
Yes. Keeppower 3120 mah will fit in the mini gt.
Thats why i said it, you dnt need to say it again…OK…just messing…i got them also…great cells…
A protected cell won’t run the GT mini the way it’s intended to be run though, best results come from a non-protected high discharge cell. The driver has built-in protections so everything is still safe and secure.
Sure, a protected cell will limit performance, but The GT-mini is an XP-L HI light that was originally specced with a ~4.5A regulated buck driver. The impact is going to be less significant/obvious than it would be with a triple, or something with a low Vf emitter.
It looks like the difference between the protected and unprotected versions of that cell are ~10mOhm. That’ll be, what, maybe 10-15% of output? It may be unacceptable when hot-rodding, but hard to notice in practice.
Accidentally drove into an open pit mine, in the middle of the night, in Wyoming. Suddenly found ourselves surrounded by these things.
I think it was the North Antelope Rochelle mine just south of Gillette Wyoming.
